  New Posts New Posts RSS Feed: 2010 Rpod 177 Manual Slide Out Operation
PENP View Drop Down
Post Options Post Options   Quote PENP Quote  Post ReplyReply Direct Link To This Post Topic: 2010 Rpod 177 Manual Slide Out Operation
    Posted: 21 Jul 2025 at 12:07pm
New to the Forum.
Camping from decades (more overlanding)... new with an Rpod.
I just bought it and trying to renovate it all possible to its new years.
Where is the 2010 Rpod 177 Manual Slide Out Operation, in case you are out there and the system does not work with the battery, and so related.
Thank you, Al.
gpokluda View Drop Down
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2025 at 10:45am
There us no, easy way to manually operate the slide in the event it fails. There are several YouTube videos but this is the overview.
If the slide is in and it will not operate, you will need to remove the slide seal and side trim to access the slide motor upper mounting bolt. There us a motor on each side of the slide. Removing the bolts will allow you to move the motor to the side and pull/push the slide out.
If the slide is out, then you can access the the upper motor mounting bolt, remove it am repeat the process above.
Gpokluda
2017 Rpod 179(sold 2023)
2022 Escape 5.0TA
2022 Ford F150 4X4 3.5EB
Honda SCL500
PENP View Drop Down
Post Options Post Options   Quote PENP Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2025 at 12:59pm
I will crawl under the slide (kitchen) when is out and check.
Mine works good...I just wanted to know if suddenly I am boondocking and it stops working, then the trouble begins. I never had a slide and I am not sure if it is legal to drive with the slide out, taking in account that this one is not much on the outside; but again the question is thinking in case of an emergency the day you do not expect it.
Thank you.
GlueGuy View Drop Down
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2025 at 12:22pm
If it gets stuck in the out position, the solution for Schwintek units is to pull the covers off both sides, and disconnect both motors. You can then manually push it in. At that point you need to insert a board (or two) that are just long enough to prevent the slide from sliding out on its own. Not ideal, but do-able with some major caveats.
PENP View Drop Down
Post Options Post Options   Quote PENP Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2025 at 1:24am
Since I asked I have been watching this guy who repair slides:
https://www.youtube.com/@AZExpert/search?query=slide
He is an experienced RV technician with useful content, and it is good to be ahead of the possible trouble.
I have been reinforcing with extra wood all under the bed and under the seats. Hard to believe they did it like that. Also many factory holes not sealed. Will keep looking; basically I will remodel every where it can be done.
Thank you.
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2025 at 9:25am
Sounds like a fun project. Keep us posted on your progress.
Gpokluda
2022 Escape 5.0TA
Honda SCL500
PENP View Drop Down
Post Options Post Options   Quote PENP Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2025 at 1:21pm
I am waiting for parts I ordered.
- The two exhausts on the roof are completely broken, so I guess when it rains some water goes through it. They should come today. I found aluminum ones, probably to last forever:
https://www.amazon.com/dp/B0DQQ2343L?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
- Also will cover the shower so I can open it when it rains:https://www.amazon.com/dp/B000UUMM6K?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
- I am thinking to add a new axle, as one side I see like 5 degree angle in the tire at the bottom, still after changing the bearings; and the spindle is fine, so probably the torsion arm is getting old. I am in contact with Lipper for that matter.
- I will add solar, and this is something I have done for years in a small off road trailer I have, in a van I converted in the past, and in my own Silverado I have 3 solar panels over a rack I built. It will be a challenge because it is round on the top...but I will find the way.
- Added already a box in the front with Camco gas tank cover.
- Added 2 x 200 AH Lithium (I had them from another project), but I installed them under the passenger seat inside the Rpod (Dinette); and the solar system will be there as well.
- I want to paint the center-outside of the Rpod, the re-seal everything, so I can give maintenance to the AC without worrying for leaks.
This week should come all the seals for the slide. They are not super bad, but better than have surprises. This pod all in it works but the guy that had it was not up to maintenance, as you can see in the roof no cover for the exhausts. You can see the two black pipes.
-Right now I am ending a second hand painting inside the Rpod, except the kitchen. I will give it three times, but these panels are not so friendly to the paint, they are special ones against humidity with some vinyl over the lauan wood, but little by little is sticking there. Already looks like there is more light inside.
- I will add Led lights except the bathroom...we are getting old. We know it because at night the light bothers a little bit when suddenly on.
-I may replace the toilet with composting, in my experience from the past I think it is the best; of course it is just my opinion, and we use it mostly just for my wife and me. I understand that when you have a big family that could be an issue.
- I already painted underneath the trailer half way to all metals...need more paint.
- I will be busy, and my vacation ends next Thursday.
Busy... busy.
PENP View Drop Down
Post Options Post Options   Quote PENP Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2025 at 1:24pm
Forgot!... adding a camera to the back, and lights to the front. Will use the battery=now-tool-box I installed at the front, from Harbor Freight.
