  New Posts New Posts RSS Feed: Bed plywood
Bed plywood
CathaleenH View Drop Down
Post Options Post Options   Quote CathaleenH Quote  Post ReplyReply Direct Link To This Post Topic: Bed plywood
    Posted: 13 Jan 2024 at 1:13pm
Hi! I am a new owner of a very used 2017 178. I bought it for a really good price knowing it needed work, but I keep uncovering things. This one I knew going in…the previous owner threw out the plywood supporting the bed because it had water stains.
What plywood thickness should I use to replace it? I’m sure this a serious newbie question and I am full of these type of questions!Smile
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2024 at 2:39pm
You should not need to have anything over 1/2 inch. Thicker and it will be quite heavy to lift. Thinner, and it would not be rigid enough. This is supposing that the framework to support the plywood is still there and in good shape.
Post Options Post Options   Quote CathaleenH Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2024 at 10:11am
Thank you! This very helpful.
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2024 at 4:29pm
We purchased a 177 back in January 2011, and still own it.  It came with 1/4" luan under the mattress.  Not very thick but as StephenH states, as long as the supports are in good shape, you will be fine.  The mattress was one thing we traded out after 3 sleeps on it, it was already collapsing in the middle.  We purchased a 6" Eurotop and still use it today as it is still just as firm and comfy as the day we received it.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2024 at 9:54pm
The Cherokee Grey Wolf has 1/2" plywood.  The 2016 R-Pod 179 had 1/2" also IIRC. It might have been 3/8, but it definitely was thicker than 1/4"
