  New Posts New Posts RSS Feed: 190 blank tank drain pipe fell off while driving
npalumbo89 View Drop Down
Post Options Post Options   Quote npalumbo89 Quote  Post ReplyReply Direct Link To This Post Topic: 190 blank tank drain pipe fell off while driving
    Posted: 25 Sep 2022 at 2:34pm
Made it through the 4th camp without any issue only to discover after parking that the black pipe that runs from the tank to the valve broke away from the tank and had been dragged along for who know how long of the 110 mile drive back. No major bumps along the way or mishaps on the road so I’m
Not sure what happened here. Any idea on if it’s an easy fix? I I’ve only had the 190 since the end of July. This is a bummer.
Nicholas Palumbo
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2022 at 4:59pm
I thought I had pictures in my mods, but I could not find them. Go to your local auto parts store. Get a muffler hanger. With a worm-drive clamp, clamp it around the black water drain pipe (once you get it repaired/replaced). Shorten the rubber part as needed, drill through it and using self-drilling/tapping bolts, bolt it to the frame in place of the flimsy strap. Don't feel alone. I had this happen to me twice. The factory installed a second flimsy strap. Both gave way. There won't be a third time.
Post Options Post Options   Quote npalumbo89 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2022 at 7:53pm
Okay good to know. Oddly this wasn’t even the strap or metal hanger that broke. Those are still in tact. The break happened right where that pipe connects to the tank itself. That has completely broken off and the hanger was the only thing that saved it lol
Nicholas Palumbo
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2022 at 8:57pm
Okay, did the pipe break, or did it slide out of the seal that holds it in? Mine is an elbow that is pushed into a gasket and then is held on by a clamp. I guess I should check mine to make sure it isn't coming out while the tank is empty. Then I can make sure the clamp is tight and hopefully avoid what you experienced. Yours is the first instance of that type of failure that I have read about. Not to say it has not happened before, but the hanger is much more common.
Post Options Post Options   Quote npalumbo89 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2022 at 9:20pm
https://photos.app.goo.gl/vcpNPYJd9zQ474fC7
Let me know if the link works. I wasn’t able to upload my photo to this response for some reason. It appears it’s an elbow that connects to the tank. I don’t see a clamp though. Maybe that broke away or wasn’t there to begin with. Can’t tell if the elbow has simply fallen out or the plastic around the tank has broken cleanly. I’ve only taken this thing out 4 times since buying new.
Nicholas Palumbo
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2022 at 10:27pm
As you can see, mine has a worm drive hose clamp. Was the pipe totally separated or partially attached when you discovered it? If it was totally separated, it could have fallen off. If it was partially attached still, then it may not have been installed at the factory. If your 'Pod is still under warranty, check with your dealer about repair. If you are doing it yourself, then add a hose clamp when you reassemble it. I don't know what kind of sealant that was used, but apparently it is insufficient by itself.
Post Options Post Options   Quote npalumbo89 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2022 at 10:51am
Okay I gotcha. Yeah that was no where to be seen. I discovered it when I was just about to back in and park. It had been detached completely and dragging for an unknown amount of time
By the metal hanger on the valve end. I reached out to the dealer already. I honestly can’t say for sure if that clamp was on there or not to begin with. Thank you for the photo and information!
Nicholas Palumbo
lostagain View Drop Down
Post Options Post Options   Quote lostagain Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2022 at 2:22pm
Fred & Maria Kearney
Sonoma 167RB
Our Pod 172
Post Options Post Options   Quote npalumbo89 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2022 at 8:19am
Thanks for the link!
I've brought it to the dealers attention and to be checked out on an upcoming recall visit for the front window. I may attempt to fix it myself if its as simple as installing a hose clamp. Thanks again!
Nicholas Palumbo
