TV Mount for Rpod 179 - Event Date: 25 Apr 2022 |
Post Reply
| Author | |
pearlhiggy
Joined: 25 Apr 2022 Location: Brockport, NY Online Status: Offline Posts: 18 |
Post Options
Quote Reply
Calendar Event: TV Mount for Rpod 179Posted: 25 Apr 2022 at 6:39pm |
Well, i've only had my camper 3 weeks and the TV fell off the wall. The bracket that is holding it up came out of the wall. It is mounted on the wall facing the bed on the right had side when you stand at the bed.
Does anyone have any ideas as to where or how I can re-mount it so that it is secure? All suggestions are welcome. Thank you.
The Higgins' Girls,
Pearl, Zoey Marie & Riley Ann 2017 Rpod 179 |
Pod People
Joined: 22 Sep 2011 Location: Chapel Hill,NC Online Status: Offline Posts: 1097 |
Post Options
Quote Reply
Posted: 25 Apr 2022 at 10:29pm |
We reinforced the tv mount on our 179. the first thing you have to do is remove the tv and it's mounting bracket. then , you separate the tv from the tv mounting bracket. I made 2 pieces of 3/16" metal rectangles that are 9"x14". Put both metal plates together along with the tv wall mount plate and drill them at the same time with the bolt pattern from the tv mount. I put one plate on each side of the wardrobe wall where the tv mounts and also put the tv mount on the outside metal reinforcement plate. Thus, you will a "sandwich" which consists of tv mounting plate, metal reinforcing plate on the outside of the wall and the second metal reinforcing plate on the inside of the wardrobe. I connected them with bolts, washers ,nuts and lock washers that go all the way through the wall, Once you get a metal plate on the inside and a metal plate and tv mounting bracket on the outside, you can tighten everything. this wall in the wardrobe is hollow except for the solid corners. so, you cannot tighten the bolts too much or you will simply crush the wall between the metal plates. Once all of the bolts are as tight as you feel comfortable with, attach the tv to the tv mounting bracket. here is a picture inside the wardrobe-- you can't see the outside because the tv mounting bracket covers the metal reinforcing plate. I hope this helps-I know it may sound complicated. Feel free to email with questions travel safe Vann
pearlhiggy
Post Options
Quote Reply
Posted: 26 Apr 2022 at 1:46am |
Thank you so much. I was wondering if I would be able to get to the area where the TV bracket was from inside the closet. Your instructions help a great deal.
Thank you again.
The Higgins' Girls,
GlueGuy
Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2783 |
Post Options
Quote Reply
Posted: 26 Apr 2022 at 11:28am |
On our 179, we put in a different mount so it could swing around the opposite direction. When we took out the old mount, we discovered there wasn't much "meat" there to screw into, so I just added a little piece of plywood as a backer.
Mooree
Joined: 17 Jan 2022 Location: USA Online Status: Offline Posts: 25 |
Post Options
Quote Reply
Posted: 28 Jun 2023 at 9:11pm |
Determine the ideal location for attaching your TV mount. Consider factors such as the viewing angle, available space, and accessibility to power outlets. If you intend to watch TV while lying down or reclining, set it above eye level.
Post Reply
