RKS1 ![]() Newbie ![]() ![]() Joined: 29 Jun 2020 Location: Pottstown PA Online Status: Offline Posts: 8 |
![]() Posted: 26 Jul 2020 at 4:19pm |
hello everybody:
I am new to RVing, hence this question. I am plugged into house outlet (20 amp). I want to check make sure everything works right. My A/C is not acting properly. Starts then shots off after a couple of minutes. My guess is I need to be hooked to a 30 amp outlet for the A/C to work. I am I close to sounding right.
Kent
1nana2many ![]() Groupie ![]() ![]() Joined: 05 Apr 2018 Location: NE Kansas Online Status: Offline Posts: 62 |
You are correct, it pulls too much especially if there are other things on the same circuit. My husband says it may run for a while, but might also melt the adaptor plug.
2016 RP179= O.D. (Olive Drab) 2008 Coachman Captiva 1993 Jayco 1206 popup 2016 F150 Supercrew |
Thank you. Had a feeling that was the issue. t did not melt the plug. I liked out it just blow a fuse.
Thank you
Kent and Amy |
Kent
I don't know how you are hooked to that 20A 120 circuit. But that AC requires some power, I wouldn't advise normal ops the way you are doing it. Best to have a 30A circuit and your power cable.
The a/c only uses about 15A while running so it shouldn't be a problem to run it from a 20A circuit as long as there is nothing else on that circuit (in the house or trailer) at the same time. Shot off all the other breakers in the trailer panel.
Don't worry about melting the plug, the circuit breaker in your home panel will trip first. But, you should be sure to use a heavy gauge extension cord (at least 12 gauge, NOT a cheap 14 gauge one) and keep the length as short as possible.
That is a short term solution. Long term I agree with the other comments, install a dedicated 30A RV outlet if possible. I do understand that that might now be practical or cost effective in every situation. |
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6463 |
A 15A outlet will definitely trip the breaker. It might not be immediate, but it will trip. A 20A breaker should not trip provided nothing else is on that circuit at the same time. Make sure your water heater is shut off for AC power. Running it on propane would be okay. Same with the refrigerator. If your battery is low, your converter will pull significant power until it is charged so that would be a factor also. I agree that a 12 gauge cable should be the minimum for running the RPod from a 20A outlet. You can tell a 20A outlet if the house is up to code in that it will have a different shaped outlet than the 15A outlets. It will have little T slot on one side instead of two parallel slots. Ultimately, having an RV outlet installed will be better. If you have an electrician install one, make absolutely sure that he/she is installing a 110V 30A RV outlet and not a 220V dryer outlet. Verify the installation with a meter before you plug your RPod into that outlet.
