| Author |
Don Halas
Topic: Reversed Battery Cables Posted: 13 Apr 2018 at 5:39pm |
In my euphoria of opening the Pod for the season I hooked up the battery terminals backwards.
I figured that out when the slide wanted to move opposite the switch settings.
So, I changed it back and everything appears to be ok except the radio is not lighting up. I've checked the control panel and don't see any of the LED's lit. I reset all the breakers but still nothing on the radio. I've also pushed the radio power button, but nothing.
Anyone have any guidance here? And if I've blown the radio any suggestions on a step up from the Jensen AWM 968?
Thanks in advance.
Posted: 13 Apr 2018 at 6:00pm |
Some info:
Radio will not turn ON
· Try the reset button.
· Check fuse.
· Check 12V+ on battery wire to radio (YELLOW wire).
· Check 12V+ on accessory wire to radio (RED wire).
· Check Ground.
Jensen Response:
If you have verified that there is proper 12 volt power going directly to the AWM968, please try a factory reset on the radio. You can do this bypressing and holding the AUDIO button to access the System Menu. The"BEEP" setting will display. Quick press the AUDIO button to accessthe "RESET" option. Press the VOL/PUSH/ENTER control to rest theE2PROM to factory default setting.
Tars Tarkas
Posted: 13 Apr 2018 at 6:05pm |
Isn't there a fuse or breaker in the converter that blows the instant the battery is connected incorrectly?
TT
FJ Cruiser
Don Halas
Posted: 13 Apr 2018 at 6:11pm |
Thanks.
I found some information on another forum and downloaded the manual (thanks Mcarter you were two steps ahead of me).
There is a reset button on the panel an a 10 amp fuse in the wiring harness. The forum post suggested the fuse fixed his dilemma.
Again, grateful for the quick response. I'll post tomorrow what my outcome is.
Thanks
Posted: 13 Apr 2018 at 6:12pm |
I think the 40A fuses do exactly that, some called them the "reverse hook-up" fuses. They blow to protect 12V electronics, not sure why slide works backwards, have to think about that.
Posted: 13 Apr 2018 at 6:14pm |
Don, check those 40A fuses too.
Posted: 14 Apr 2018 at 7:27am |
Originally posted by mcarter
I think the 40A fuses do exactly that, some called them the "reverse hook-up" fuses. They blow to protect 12V electronics, not sure why slide works backwards, have to think about that. |
A) The 40A fuses work to protect the converter, nothing else. So if the battery(ies) are hooked up backwards, BUT the converter doesn't get plugged in, they will be fine. AND even if you do blow them, the power from the battery will still be available. Only the converter/charger is removed from the system. B) 12v DC.. Direct Current. Run it backwards through a motor, the motor turns the other way.
Posted: 14 Apr 2018 at 8:46am |
THANKS Furpod, tracking.
Don Halas
Posted: 14 Apr 2018 at 2:45pm |
Thanks all.
Here's the results. It was the fuse. A 10 amp mounted near the wiring assembly on the back. I also had to replace the two 40 amp fuses that furpod mentioned that product the converter.
Another issue, theres a black assembly that goes behind the toilet. It broke, presumably because of winter frost. So now I need to replace it also.
Thanks for all who jumped on to assist me. Much appreciated. Happy Camping all!
Posted: 14 Apr 2018 at 4:53pm |
Don,
Are you talking about the toilet flush valve? Is so see this:
Thetford toilet flush valve leaking.
Toilet flush valve on 2012 r-pod 177 Thetford rv toilet failed and started to leak.
Replaced valve without removing the toilet.
Kneel down in front of toilet and when you look down back of the toilet you see the flush valve.
1 disconnect supply hose from the bottom of the valve.
2 remove on the right side of the valve body a brass phillips screw, connects valve to rear of the toilet, use stubby phillips screw driver to remove.
3 valve locks on the left side in a small groove and held by plastic pin, pull valve body out.
4 disconnect metal wire connected to flush handle, pull wire up from handle.
New valve
1 connect metal flush handle wire.
2 lock left side of valve in to groove and pin location.
3 screw brass screw back into rear of the toilet.
4 install new rubber gasket inside supply hose connector.
5 connect supply hose to bottom of valve and tighten
6 turn on pump, check for leaks.
