  New Posts New Posts RSS Feed: Battery charging
Topic ClosedBattery charging - Event Date: 10 Oct 2017
Uncle Hamish View Drop Down
Direct Link To This Post Calendar Event: Battery charging
    Posted: 11 Oct 2017 at 10:51am
I don't have a generator. If I leave it plugged into my tow vehicle with it running, will it charge the battery and if so, how long for a full charge? It's an r-pod 180. Thanks!
Direct Link To This Post Posted: 11 Oct 2017 at 1:01pm
It may, or may not charge that way. Depends on how your truck is set up.
BUT even if it does, it will charge fairly slowly.
Use jumper cables, and hook straight to the battery from the trucks battery and start your truck, it will charge pretty fast like that.
GlueGuy View Drop Down
Direct Link To This Post Posted: 11 Oct 2017 at 1:04pm
Depends on:
  1. State of charge (or discharge) of the battery
  2. Size of the battery (or batteries)
  3. Tow vehicle capability
Direct Link To This Post Posted: 11 Oct 2017 at 1:29pm
Thanks!
sailor323 View Drop Down
Direct Link To This Post Posted: 11 Oct 2017 at 5:06pm
If the battery is completely discharged and if the TV is set up to send a charge via the Bargman connector, and depending on the output of your alternator, it could take hours.  You can speed that up a bit by using a good set of jumper cables from the TV to the battery.  I charged a completely discharged battery (225 amp hour capacity) via the Bargman, 65 amp alternator--took over 2 hours
Direct Link To This Post Posted: 11 Oct 2017 at 5:25pm
All good info! Thanks a ton y'all!!!
Direct Link To This Post Posted: 11 Oct 2017 at 5:26pm
PS. Safe to assume this bargman is the big round 8-9 pin connector on my TV???
Direct Link To This Post Posted: 11 Oct 2017 at 5:43pm
7-pin, but, yes.  Smile
Direct Link To This Post Posted: 11 Oct 2017 at 5:48pm
Thanks again folks!
mcarter View Drop Down
Direct Link To This Post Posted: 11 Oct 2017 at 5:59pm
Think it is a the 1:00 position on TV connector. You should check to ensure you have battery voltage there. If you don't it is either not hooked up or not enabled. The other cheap thing I did was buy a relatively cheap digital LED ammeter gauge, that plugs into 12V accessory outlet. That tells me the status of battery charging as I tow. I wanted more accurate info than the standard ammeter gauge in dash.
