  New Posts New Posts RSS Feed: Do we really need to winterize these things?
Topic ClosedDo we really need to winterize these things?
Bhfromme View Drop Down
Direct Link To This Post Topic: Do we really need to winterize these things?
    Posted: 27 Aug 2017 at 6:18pm
Okay from the stupid question department, I'm wondering do we really need to winterize the Pod?
We plan to use it through most of the winter. Why can't I just drain everything and keep the lines open to allow for expansion so if there is any water hanging around in low places it'll just freeze but not do any damage. Correct?
Yes I'm new to this. But I'm not new to winter. If the lines are open and I keep a good charge in the battery I'm good to go. Right?
Bill and Female Companion aka She Who Must be Obeyed
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 27 Aug 2017 at 6:31pm
It just takes a little bit of water in the pump or the toilet valve to crack them.  Some people think blowing out the lines is sufficient but after replacing my toilet valve I'm a believer in antifreeze.
Winterizing isn't that much trouble.
TT
FJ Cruiser
Old & out-to-play View Drop Down
Direct Link To This Post Posted: 27 Aug 2017 at 8:05pm
Winter means different things depending on where you live.  As a kid I spent years in Subury, Ontario in Canada.  Winters were brutal with week's at a time well below zero.  20 years ago we built a home north of Los Angeles in the mountains.  We had snow that would last for 2-5 days, temps at freezing point at night but warm days...no sustained periods of freezing.  In both cases you would need some type of winterizing but in Southern California it would be minimal compared with Sudbury.
If you're in Maine off the coast I'm thinking Tars is right, "winterizing isn't that much trouble".  You might consider also removing the battery keeping it in a warmer environment on a trickle charger.
Old and in the way so now it's time to play
Direct Link To This Post Posted: 27 Aug 2017 at 8:38pm
In northern Michigan winters can get pretty 'cool'.  It is not uncommon to have a cold spell in January where we hit -15 or colder for a few days or more.  Except for the first winter (2011) we have always used an air compressor to blow out our water lines, I limit the pressure to 60 psi and it takes about 1 to 1.5 minutes to blow out everything and that is going over everything twice.  No problems ever encountered.  The first couple years I even pulled out the check screen by the water pump to see how much water may be lurking inside as well as open the low point drains . . . they were clean and dry as a whistle.  Since then I blow the lines out and call it good then use about 1 pint of the pink rv antifreeze for the 3 traps on our 177.
Direct Link To This Post Posted: 28 Aug 2017 at 5:09am
We have some pretty cold winters, we follow a similar procedure as Jato. On our 9th year of owning rpods and have never had a problem(knock on wood).
Once you get a system down winterizing takes less than an hour. Better safe than sorryApprove
riotkayak284 View Drop Down
Direct Link To This Post Posted: 28 Aug 2017 at 3:51pm
One additional item that I use, is the antifreeze helps to keep the system free of bad stuff. Stuff that requires the disinfection of the system. It also does provide some protection for seals and such.
ToolmanJohn View Drop Down
Direct Link To This Post Posted: 28 Aug 2017 at 8:53pm
RV Antifreeze. Cheap, easy to do. Protects the system components. Pour it into the traps of the shower, sink, and leave some in the toilet bowl.
DO NOT put it through the water heater. You must drain the water from the tank, and bypass the tank, before introducing antifreeze into the lines.
After getting antifreeze though-out the water lines (pink coming out of all faucets, toilet, outside rinse port) then drain it through the low point drains. All you really-need is some in the traps, and leave some in the toilet to keep the valve wet.
2013 R-Pod 177 (SOLD)
2013 VW Touareg TDI
spydie View Drop Down
Direct Link To This Post Posted: 28 Aug 2017 at 11:50pm
I used to put anti-freeze through the lines like ToolmanJohn, but found out like many others on here that just blowing out the lines (I read someplace once that you shouldn't use over 40lbs air pressure), draining the water heater, pouring anti-freeze in the shower and sink drain p-traps and leave a little in the toilet bowl is all I do.  Don't forget to open the outside shower faucets when blowing out the lines.  Been doing that about 18 years now and no problems with weather below zero for a week or so at a time
2018 R-pod 176
2017 RAM 1500 5.7L Hemi
