  <title>R-pod Owners Forum : over inflated tires</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Reviews and General Information : over inflated tires</description>
  <pubDate>Sat, 24 Oct 2026 05:02:38 +0000</pubDate>
  <lastBuildDate>Mon, 01 May 2017 07:35:07 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=9847</WebWizForums:feedURL>
   <title>over inflated tires :   Originally posted by Happy...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9847&amp;PID=92349#92349</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 9847<br /><strong>Posted:</strong> 01 May 2017 at 7:35am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Happy Tripping</strong></em><br /><br />I tried a search with the miserable 'search' function - no results, so ...<div><br></div><div>I recently went to my friendly neighborhood rv store, asked them to grease the bearings and inflate the Class C tires (I know - lazy, but it sure was convenient) for the coming year.</div><div><br></div><div>After my first trip I checked the tires (I know, I should have done it daily- this had better teach me) and the pressure was around 65 psi.</div><div><br></div><div>From the internet, tires can be safely over inflated, maybe it's even good in certain situations, but I feel pretty obviously this is too high by far (Class D level).</div><div><br></div><div>Comments on over inflating tires??</div></td></tr></table><br><br>You should be set at 50psi. The 65 psi won't harm anything over the course of a single trip. Over time, you will see excessive wear in the center of the tread. Just drop it back to 50psi, and camp on..&nbsp; ;)<br>]]>
   <pubDate>Mon, 01 May 2017 07:35:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9847&amp;PID=92349#92349</guid>
   <title>over inflated tires :  Always put your trailer tires...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9847&amp;PID=92341#92341</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2715" rel="nofollow">ToolmanJohn</a><br /><strong>Subject:</strong> 9847<br /><strong>Posted:</strong> 01 May 2017 at 5:08am<br /><br />&nbsp;Always put your trailer tires at maximum cold inflation pressure, whatever the side wall says. If it says 50 psi, do it.<div><br></div><div>When towing, it's also a good idea to inflate the rear tow vehicle tires +5 psi over the recommended cold tire pressure. This helps with stability.</div>]]>
   <pubDate>Mon, 01 May 2017 05:08:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9847&amp;PID=92341#92341</guid>
   <title>over inflated tires : ok, be sure to check your tires...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9847&amp;PID=92334#92334</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5077" rel="nofollow">osage</a><br /><strong>Subject:</strong> 9847<br /><strong>Posted:</strong> 30 Apr 2017 at 10:03pm<br /><br /><div>ok, be sure to check your tires when they are cold. as you drive and the tires get hot the pressure will rise</div><div>so if they are 50psi when cold they may go up 10psi when hot&nbsp; someone correct me if I'm wrong which I am 90% of the time</div>]]>
   <pubDate>Sun, 30 Apr 2017 22:03:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9847&amp;PID=92334#92334</guid>
   <title>over inflated tires : For reasons I can&amp;#039;t recall...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9847&amp;PID=92332#92332</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1653" rel="nofollow">Tars Tarkas</a><br /><strong>Subject:</strong> 9847<br /><strong>Posted:</strong> 30 Apr 2017 at 8:55pm<br /><br />For reasons I can't recall right now, I keep the tires on my pod at 50#.&nbsp; Pretty sure they're C rated and they call for 50# on the sidewall.&nbsp; In my opinion airing them up to 65# is probably okay but not good for any reason I can think of.&nbsp; I wouldn't want to run them at that pressure for any length of time; it would probably eventually cause premature wear in the middle of the tread.&nbsp; Short term, it's unlikely there is any harm done.<br><br>TT<br><br><br><br><br><br><br>]]>
   <pubDate>Sun, 30 Apr 2017 20:55:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9847&amp;PID=92332#92332</guid>
   <title>over inflated tires : I tried a search with the miserable...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9847&amp;PID=92329#92329</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2821" rel="nofollow">Happy Tripping</a><br /><strong>Subject:</strong> 9847<br /><strong>Posted:</strong> 30 Apr 2017 at 7:50pm<br /><br />I tried a search with the miserable 'search' function - no results, so ...<div><br></div><div>I recently went to my friendly neighborhood rv store, asked them to grease the bearings and inflate the Class C tires (I know - lazy, but it sure was convenient) for the coming year.</div><div><br></div><div>After my first trip I checked the tires (I know, I should have done it daily- this had better teach me) and the pressure was around 65 psi.</div><div><br></div><div>From the internet, tires can be safely over inflated, maybe it's even good in certain situations, but I feel pretty obviously this is too high by far (Class D level).</div><div><br></div><div>Comments on over inflating tires??</div>]]>
   <pubDate>Sun, 30 Apr 2017 19:50:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9847&amp;PID=92329#92329</guid>
