  <title>R-pod Owners Forum : R -pod awning</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Campers Flea Market : R -pod awning</description>
  <pubDate>Sat, 07 Nov 2026 00:52:54 +0000</pubDate>
  <lastBuildDate>Mon, 10 Apr 2017 20:42:24 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=9671</WebWizForums:feedURL>
   <title>R -pod awning :   Originally posted by richarddDoes...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9671&amp;PID=90950#90950</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 9671<br /><strong>Posted:</strong> 10 Apr 2017 at 8:42pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by richardd</strong></em><br /><br />Does anybody know if the awning on the 2017 can be ordered to retrofit a 2016?</td></tr></table><br>No, it can't be retrofit to a 2016. The reason is that the 2017 models have a reinforced wall to which the awning bolts. The 2016 models lack this reinforcement. The only way to retrofit the awning is to replace the whole wall with a new one that has the reinforcement.<br><br>Ours will be getting this modification due to the accident which took place in December. In order to repair the damage, the whole wall will be replaced. We will have a unique 2016 RP-179 when it is done, because it will have the awning installed when we go to pick it up from the factory.<br><br>If you are interested in the details of the accident, see "<a href="http://www.rpod-owners.com/forum_posts.asp?TID=9133&amp;OB=ASC" target="_blank">I wrecked our escaPod</a>."<br>]]>
   <pubDate>Mon, 10 Apr 2017 20:42:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9671&amp;PID=90950#90950</guid>
   <title>R -pod awning : No. The 2017 R-Pod walls and roof...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9671&amp;PID=90922#90922</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5021" rel="nofollow">TheBum</a><br /><strong>Subject:</strong> 9671<br /><strong>Posted:</strong> 10 Apr 2017 at 6:12pm<br /><br />No. The 2017 R-Pod walls and roof were reinforced to support the awning.]]>
   <pubDate>Mon, 10 Apr 2017 18:12:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9671&amp;PID=90922#90922</guid>
   <title>R -pod awning : Does anybody know if the awning...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9671&amp;PID=90911#90911</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6516" rel="nofollow">richardd</a><br /><strong>Subject:</strong> 9671<br /><strong>Posted:</strong> 10 Apr 2017 at 5:43pm<br /><br />Does anybody know if the awning on the 2017 can be ordered to retrofit a 2016?]]>
   <pubDate>Mon, 10 Apr 2017 17:43:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9671&amp;PID=90911#90911</guid>
