  <title>R-pod Owners Forum : R-Pod Battery Life</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : R-Pod Battery Life</description>
  <pubDate>Thu, 29 Oct 2026 12:41:03 +0000</pubDate>
  <lastBuildDate>Mon, 10 Apr 2017 22:26:38 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=9669</WebWizForums:feedURL>
   <title>R-Pod Battery Life : I second the clamp meter. You...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9669&amp;PID=90956#90956</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6778" rel="nofollow">Danielw1</a><br /><strong>Subject:</strong> 9669<br /><strong>Posted:</strong> 10 Apr 2017 at 10:26pm<br /><br />I second the clamp meter. You should be able to check each wire at a time with all appliances off and find if something is drawing current. I have a fluke clamp meter that will read D.C. Amps and it is well worth having. I also use it every time my wife kills her car battery to tell her the alternator is working, you left something on!<br />Your problem could be as simple as a loose wire or a couple strands grounding out that are drawing steady current but not blowing a fuse. ]]>
   <pubDate>Mon, 10 Apr 2017 22:26:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9669&amp;PID=90956#90956</guid>
   <title>R-Pod Battery Life : Thanks Gary from McCall and Charlie...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9669&amp;PID=90929#90929</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6807" rel="nofollow">kpetit</a><br /><strong>Subject:</strong> 9669<br /><strong>Posted:</strong> 10 Apr 2017 at 6:34pm<br /><br />Thanks Gary from McCall and Charlie from FL.<br>You guys make it sound pretty simple to trouble shoot.&nbsp; I will give this a try. Fingers crossed!<br>Kevin<br>]]>
   <pubDate>Mon, 10 Apr 2017 18:34:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9669&amp;PID=90929#90929</guid>
   <title>R-Pod Battery Life : IMHO all campers ought to have...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9669&amp;PID=90893#90893</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1573" rel="nofollow">CharlieM</a><br /><strong>Subject:</strong> 9669<br /><strong>Posted:</strong> 10 Apr 2017 at 2:31pm<br /><br /><font size="3">IMHO all campers ought to have a good clamp on digital meter capable of measuring DC current and AC/DC voltage. This allows you to tell at a glance what current is going into or out of you battery as well as the voltage right at the battery terminals. The one I like and use is&nbsp;<a href="http://www.sears.com/craftsman-professi&#111;nal-true-rms-ac-dc-clamp-ammeter/p-03473756000P?plpSellerId=Sears&amp;prdNo=1&amp;blockNo=1&amp;blockType=G1" target="_blank">http://www.sears.com/craftsman-professional-true-rms-ac-dc-clamp-ammeter/p-03473756000P?plpSellerId=Sears&amp;prdNo=1&amp;blockNo=1&amp;blockType=G1</a><br><br>It costs $90 from Sears but is the cheapest I can find that measures a usable range of DC Amps. The 40A range lets you see most of the normal loads plus look at the higher charging currents from various charging schemes. Don't be tempted by cheaper so called clamp meters. The only measure AC Amps, not DC Amps. With this meter you can see what is drawing current when everything is supposed to be off. You can also tell if and how well the converter/charger is working. If all checks out well it's probably the battery.<br></font>]]>
   <pubDate>Mon, 10 Apr 2017 14:31:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9669&amp;PID=90893#90893</guid>
   <title>R-Pod Battery Life : Hi kpetit,  If it was me, I...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9669&amp;PID=90891#90891</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6680" rel="nofollow">McCall</a><br /><strong>Subject:</strong> 9669<br /><strong>Posted:</strong> 10 Apr 2017 at 2:11pm<br /><br /><p style="margin: 0px; font-size: 11px; line-height: normal; font-family: Helvetica; color: rgb60, 60, 60; -webkit-text-stroke-width: initial; -webkit-text-stroke-color: rgb60, 60, 60;"><span style="font-kerning: n&#111;ne">Hi kpetit,</span></p><p style="margin: 0px; font-size: 11px; line-height: normal; font-family: Helvetica; color: rgb60, 60, 60; -webkit-text-stroke-width: initial; -webkit-text-stroke-color: rgb60, 60, 60; min-height: 13px;"><span style="font-kerning: n&#111;ne"></span><br></p><p style="margin: 0px; font-size: 11px; line-height: normal; font-family: Helvetica; color: rgb60, 60, 60; -webkit-text-stroke-width: initial; -webkit-text-stroke-color: rgb60, 60, 60;"><span style="font-kerning: n&#111;ne">If it was me, I would try this when the camper is home.&nbsp; After fulling charging the batteries, disconnect from shore and pull all the fuses and trip all the breakers.&nbsp; Then I would slowly start adding the fuses back (maybe an hour between each) while watching the voltage on the batteries.&nbsp; If there is a problem area, you should see a quick drop in voltage.&nbsp; That may give a hint as to where the problem is.</span></p>]]>
   <pubDate>Mon, 10 Apr 2017 14:11:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9669&amp;PID=90891#90891</guid>
   <title>R-Pod Battery Life : We bought an R-Pod in 2014 and...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9669&amp;PID=90889#90889</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6807" rel="nofollow">kpetit</a><br /><strong>Subject:</strong> 9669<br /><strong>Posted:</strong> 10 Apr 2017 at 1:59pm<br /><br />We bought an R-Pod in 2014 and have really enjoyed the use.&nbsp; Originally, we did not have a problem with the battery life but over the last 14 months we have recharged the battery before trips and it seems to drain out in about 24 hours.&nbsp; Refrig is on propane and we really do not use a ton of lights,etc.&nbsp; It has been very frustrating to troubleshoot this.&nbsp; We purchased new 6 volt deep cycle golf cart batteries (Interstate) thinking this was the solution and to no avail.&nbsp; Same result. It appears something is shorting out the battery life as we have a full charge going in and again only have about a full day of use before it drains out.&nbsp; We mostly dry camp so has become pretty frustrating. I end up user jumper cables from the truck to keep a charge going or else we would be toast.<br><br>Any constructive thoughts would be very appreciative.&nbsp; I have very limited experience with electrical matters so please take that into consideration.<br>]]>
   <pubDate>Mon, 10 Apr 2017 13:59:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9669&amp;PID=90889#90889</guid>
   <title>R-Pod Battery Life : Yep. It&amp;#039;s dead. </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9669&amp;PID=90888#90888</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2297" rel="nofollow">fwunder</a><br /><strong>Subject:</strong> 9669<br /><strong>Posted:</strong> 10 Apr 2017 at 1:48pm<br /><br />Yep. It's dead.]]>
   <pubDate>Mon, 10 Apr 2017 13:48:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9669&amp;PID=90888#90888</guid>
   <title>R-Pod Battery Life :    </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9669&amp;PID=90887#90887</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6807" rel="nofollow">kpetit</a><br /><strong>Subject:</strong> 9669<br /><strong>Posted:</strong> 10 Apr 2017 at 1:46pm<br /><br />]]>
   <pubDate>Mon, 10 Apr 2017 13:46:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9669&amp;PID=90887#90887</guid>
