  <title>R-pod Owners Forum : Outside door for under-bed storage area, 171</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Wish List : Outside door for under-bed storage area, 171</description>
  <pubDate>Sat, 24 Oct 2026 15:09:30 +0000</pubDate>
  <lastBuildDate>Tue, 15 Dec 2009 10:14:43 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=964</WebWizForums:feedURL>
   <title>Outside door for under-bed storage area, 171 : Good point. Since there is only...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=964&amp;PID=8614#8614</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 964<br /><strong>Posted:</strong> 15 Dec 2009 at 10:14am<br /><br /><P>Good point.&nbsp; Since there is only a thin piece of wood separating the outside storage area from the rest of the storage under the queen bed, a standard key and a serated knife would get you inside the 171.</P>]]>
   <pubDate>Tue, 15 Dec 2009 10:14:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=964&amp;PID=8614#8614</guid>
   <title>Outside door for under-bed storage area, 171 : One of the under bench storage...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=964&amp;PID=8610#8610</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=204" rel="nofollow">Tusten Traveler</a><br /><strong>Subject:</strong> 964<br /><strong>Posted:</strong> 15 Dec 2009 at 9:39am<br /><br />One of the under bench storage areas in the 174&nbsp;is accessible from the inside as well as the outside which makes me concerned about a small person with a standard key being able to get inside while we are away. That brings me back to the discussion about changing out the lock on the outside sorage doors- or at least placing a bolt on bench from the inside.]]>
   <pubDate>Tue, 15 Dec 2009 09:39:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=964&amp;PID=8610#8610</guid>
   <title>Outside door for under-bed storage area, 171 : The left-rear storage area under...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=964&amp;PID=8605#8605</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 964<br /><strong>Posted:</strong> 15 Dec 2009 at 8:46am<br /><br /><P>The left-rear storage area under the queen bed on the 171 is hard to get to.&nbsp; Lifting the bed is a pain.&nbsp; I'd like another door on the outside like the rear storage area has on both sides.&nbsp; Or, extend the rear storage area on that side so that area is part of it.&nbsp; So instead of a "L" shaped storage area accessible from the inside, take the small leg of the "L" and make it part of the outside storage area.</P>]]>
   <pubDate>Tue, 15 Dec 2009 08:46:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=964&amp;PID=8605#8605</guid>
