  <title>R-pod Owners Forum : Tow vehicle</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Wish List : Tow vehicle</description>
  <pubDate>Fri, 23 Oct 2026 08:55:45 +0000</pubDate>
  <lastBuildDate>Mon, 10 Sep 2018 10:32:54 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=9559</WebWizForums:feedURL>
   <title>Tow vehicle : I tow my R-Pod 180 with a 2005...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=114802#114802</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8763" rel="nofollow">Shane</a><br /><strong>Subject:</strong> 9559<br /><strong>Posted:</strong> 10 Sep 2018 at 10:32am<br /><br />I tow my R-Pod 180 with a 2005 Dodge Durango with a V-8, 5.7 liter Hemi.  Ii feels like I am not pulling anything behind me unless I hit a bump.]]>
   <pubDate>Mon, 10 Sep 2018 10:32:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=114802#114802</guid>
   <title>Tow vehicle : We have a 2013 Honda Ridgeline...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=103012#103012</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2642" rel="nofollow">JandL</a><br /><strong>Subject:</strong> 9559<br /><strong>Posted:</strong> 17 Dec 2017 at 6:04pm<br /><br />We have a 2013 Honda Ridgeline to pull our 177 and it works. On some hills we have to slow down but that has never been a problem with us. The rear seats are very comfortable if you have extra people along.]]>
   <pubDate>Sun, 17 Dec 2017 18:04:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=103012#103012</guid>
   <title>Tow vehicle : I began towing our 2017 RP-179...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=102998#102998</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6182" rel="nofollow">PodWa</a><br /><strong>Subject:</strong> 9559<br /><strong>Posted:</strong> 17 Dec 2017 at 11:56am<br /><br />I began towing our 2017 RP-179 with a 2005 Dodge Dakota, 4.7L V8. &nbsp;The combination handled just fine and worked great under "normal" conditions. &nbsp;I felt that the 235 HP and 285 ft/lbs of torque was not quite enough for towing the pod in our mountainous western terrain. &nbsp;We really noticed it going over the coastal range from Portland, OR, to the coast. &nbsp;I mean, it was OK, but just did not have enough oomph to be comfortable. &nbsp;It required high RPM and low speed to pull the hills and we felt we were a wart on the keister of progress. &nbsp;This spring we switched to a 2017 Ram 1500 with the 5.7L Hemi. &nbsp;Its 395 HP and 410 ft/lbs of torque combined with the eight speed transmission really worked well when we travelled from Spokane to Yellowstone over those steep mountain passes. &nbsp;The engine/trans combination gets over 19 MPG when not towing and we averaged about 13 MPG over 1400 miles while crossing the high mountains twice. &nbsp;We travel the freeways at 65 MPH which seems reasonble on the high speed insterstate highways out here. &nbsp;Handling was excellent, even during a few hundred miles of towing without using our WDH. &nbsp;I hope this information is helpful to you.]]>
   <pubDate>Sun, 17 Dec 2017 11:56:26 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=102998#102998</guid>
   <title>Tow vehicle : Considering a Honda Ridgeline...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=102851#102851</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7106" rel="nofollow">LvyaRain</a><br /><strong>Subject:</strong> 9559<br /><strong>Posted:</strong> 11 Dec 2017 at 8:50am<br /><br />Considering a Honda Ridgeline to pull the R-Pod. <br>Has anyone had experience with pulling an Rpod with the Honda Ridgeline?&nbsp; <br>Towing capacity for the Ridgeline is 5000 lbs, so it could pull an RPod. <br><br><br>]]>
   <pubDate>Mon, 11 Dec 2017 08:50:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=102851#102851</guid>
   <title>Tow vehicle : We&amp;#039;ve had 3 different Tacomas...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=97532#97532</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 9559<br /><strong>Posted:</strong> 06 Aug 2017 at 11:11am<br /><br />We've had 3 different Tacomas over the years, and we've found that the rear springs get "soft" after a bit. On two of them we added super-springs, which helped out a bunch, especially when hauling any weight. If yours already has the super springs, then I might suggest updated shocks to dampen out any of the bounce.&nbsp;<div><br></div><div>I've hauled well over 2,500 lbs in the box (not trailer) in a couple of our Tacomas, so I know they can handle weight. Also, they don't seem to run out of steam until they get up to ~~ 7,000 feet or so. We think they are great vehicles.</div>]]>
   <pubDate>Sun, 06 Aug 2017 11:11:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=97532#97532</guid>
   <title>Tow vehicle : I&amp;#039;m towing along my 180 Pod...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=97506#97506</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7439" rel="nofollow">DavMar</a><br /><strong>Subject:</strong> 9559<br /><strong>Posted:</strong> 05 Aug 2017 at 9:09pm<br /><br />I'm towing along my 180 Pod just fine with my Tacoma. Just set ECT and manually shift the automatic over into 5th gear most of the time and I've had no problems pulling the mountains in NC, WVA. VA, and PA this summer. Sure sometimes I think a bigger truck with a larger engine would make towing easier, maybe, but so far so good. I would though like to figure out how to take some of the "bounce" out of towing. I use a WD hitch and anti-sway bar along with Super Springs Sumo Shock helpers but still to bouncy at times. Thinking maybe upgrading the shocks might help because I don't really want to deal with air bags, any thoughts????&nbsp;]]>
   <pubDate>Sat, 05 Aug 2017 21:09:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=97506#97506</guid>
   <title>Tow vehicle : Ok </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=97487#97487</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6392" rel="nofollow">Bugout</a><br /><strong>Subject:</strong> 9559<br /><strong>Posted:</strong> 05 Aug 2017 at 1:14pm<br /><br />Ok]]>
   <pubDate>Sat, 05 Aug 2017 13:14:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=97487#97487</guid>
   <title>Tow vehicle : Bugout,Here you are again trashing...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=97483#97483</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2419" rel="nofollow">chiman</a><br /><strong>Subject:</strong> 9559<br /><strong>Posted:</strong> 05 Aug 2017 at 11:24am<br /><br />Bugout,<br><br>Here you are again trashing the new Tacoma.&nbsp; As I said in earlier posts, I tow a new 180 with a new Tacoma and it tows just as well as my Tundra I had with the 4.6 engine.&nbsp; I have air bags on Tacoma and tow with out a WDH but use a sway control.<br>Either you were not set up right to tow the Tacoma or you didn't know how to use the ECT mode on the Tacoma.<br>Maybe you should just stop trashing the Tacoma and just be happy with the 4.6 Tundra you apparently have now.&nbsp; I'll tow just as well and get better MPG than the Tundra.<br>Chiman<br>]]>
   <pubDate>Sat, 05 Aug 2017 11:24:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=97483#97483</guid>
   <title>Tow vehicle : Can wait to get it out on the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=97470#97470</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1100" rel="nofollow">Leo B</a><br /><strong>Subject:</strong> 9559<br /><strong>Posted:</strong> 05 Aug 2017 at 8:52am<br /><br /><img src="https://www.rpod-owners.com/smileys/smiley36.gif" border="0" alt="LOL" title="LOL" />&nbsp;Can wait to get it out on the beach at Cape Hatteras. Looking forward to surf fishing those hard to get to spots.<div>Looking for a beach up here to practice on<img src="https://www.rpod-owners.com/smileys/smiley4.gif" border="0" alt="Big smile" title="Big smile" /></div>]]>
   <pubDate>Sat, 05 Aug 2017 08:52:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=97470#97470</guid>
   <title>Tow vehicle : Congrats Leo! That&amp;#039;s great!I&amp;#039;m...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=97468#97468</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2297" rel="nofollow">fwunder</a><br /><strong>Subject:</strong> 9559<br /><strong>Posted:</strong> 05 Aug 2017 at 8:19am<br /><br />Congrats Leo! That's great!<div><br></div><div>I'm sure your wife will appreciate you throwing those big fish in the back of the truck instead of the back of the van!&nbsp;<img src="https://www.rpod-owners.com/smileys/smiley1.gif" border="0" alt="Smile" title="Smile" /></div><div><br></div><div>fred</div>]]>
   <pubDate>Sat, 05 Aug 2017 08:19:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=97468#97468</guid>
   <title>Tow vehicle : Thanks David, looking forward...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=97400#97400</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1100" rel="nofollow">Leo B</a><br /><strong>Subject:</strong> 9559<br /><strong>Posted:</strong> 03 Aug 2017 at 5:30pm<br /><br /><div>Thanks David, looking forward to it!</div><div>We have kept the Grand Caravan. But now we will be exploring those spots "down the beach" at Capre Hatteras that have the real big fish<img src="http://www.rpod-owners.com/smileys/smiley14.gif" border="0" alt="Approve" title="Approve" /></div><div>&nbsp;</div>]]>
   <pubDate>Thu, 03 Aug 2017 17:30:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=97400#97400</guid>
   <title>Tow vehicle :  Originally posted by Leo BWe...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=97393#97393</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2" rel="nofollow">Guests</a><br /><strong>Subject:</strong> 9559<br /><strong>Posted:</strong> 03 Aug 2017 at 2:40pm<br /><br /> <table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Leo B</strong></em><br /><br />We just upgraded to an F -150 Super cab with the 5.0 in it. Can't wait to see how it tows.</td></tr></table> <br /><br /><br />I predict 2 things:<br /><br />1. You will like it and,<br />2. You will have one of those "Ah ha" moments (so that's what the folks with the full size V8 vehicles are talking about).  Though your Caravan is no slouch.<br /><br />Congratulations!  <img src="https://www.rpod-owners.com/smileys/smiley1.gif" border="0" align="middle" /> ]]>
   <pubDate>Thu, 03 Aug 2017 14:40:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=97393#97393</guid>
   <title>Tow vehicle : We just upgraded to an F -150...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=97390#97390</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1100" rel="nofollow">Leo B</a><br /><strong>Subject:</strong> 9559<br /><strong>Posted:</strong> 03 Aug 2017 at 1:27pm<br /><br />We just upgraded to an F -150 Super cab with the 5.0 in it. Can't wait to see how it tows.]]>
   <pubDate>Thu, 03 Aug 2017 13:27:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=97390#97390</guid>
   <title>Tow vehicle : I pull with 2017 F150 2.7L ecoboost....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=97379#97379</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2744" rel="nofollow">2rsinapod</a><br /><strong>Subject:</strong> 9559<br /><strong>Posted:</strong> 03 Aug 2017 at 8:15am<br /><br />I pull with 2017 F150 2.7L ecoboost. Best tow vehicle I've ever had. 6 speed tranny with tow mode works great. 8K km trip to Newfoundland averaged about 16 L/100 kms.(17.75 MPG imp. or 14.7 MPG US). As low as 12 L/100kms to high of 20L/100kms, depending on hills and wind of course. ]]>
   <pubDate>Thu, 03 Aug 2017 08:15:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=97379#97379</guid>
   <title>Tow vehicle :   Originally posted by BugoutThanks...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=94020#94020</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 9559<br /><strong>Posted:</strong> 26 May 2017 at 9:48pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Bugout</strong></em><br /><br />Thanks for 4.6 &nbsp;info. I don't think I want 5.6 trying to stay on budget.ford looked good but want a v8 .plus long term Toyota man</td></tr></table>We pull with a Ford F-150 with the 3.5L EcoBoost. It has power to spare, and pulls the R-pod like it is nothing. It has &gt; 10,000 lb towing capacity.]]>
   <pubDate>Fri, 26 May 2017 21:48:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=94020#94020</guid>
   <title>Tow vehicle : The 5.7 Tundra comes with a complete...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=91019#91019</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6357" rel="nofollow">bigbearcraig</a><br /><strong>Subject:</strong> 9559<br /><strong>Posted:</strong> 11 Apr 2017 at 6:38pm<br /><br />The 5.7 Tundra comes with a complete tow package including hitch, brake controllers, and wiring.  The 5.7 also has better resale value too.]]>
   <pubDate>Tue, 11 Apr 2017 18:38:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=91019#91019</guid>
   <title>Tow vehicle : Towed for the first time today....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=90764#90764</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6392" rel="nofollow">Bugout</a><br /><strong>Subject:</strong> 9559<br /><strong>Posted:</strong> 08 Apr 2017 at 1:55pm<br /><br />Towed for the first time today. I can now say.you don't even know it's back there&nbsp;]]>
   <pubDate>Sat, 08 Apr 2017 13:55:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=90764#90764</guid>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=90429#90429</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 9559<br /><strong>Posted:</strong> 03 Apr 2017 at 3:44pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Bugout</strong></em><br /><br />Thanks for 4.6 &nbsp;info. I don't think I want 5.6 trying to stay on budget.ford looked good but want a v8 .plus long term Toyota man</td></tr></table><br><br>F 150 has several engine options, including a V8. The coyote 5.0 rocks.. BUT DO NOT discount the 3.5 ecoboost without driving one. Really.<br>]]>
   <pubDate>Mon, 03 Apr 2017 15:44:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=90429#90429</guid>
   <title>Tow vehicle : I did it 2017 Toyota Tundra.new...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=90425#90425</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6392" rel="nofollow">Bugout</a><br /><strong>Subject:</strong> 9559<br /><strong>Posted:</strong> 03 Apr 2017 at 2:53pm<br /><br />I did it 2017 Toyota Tundra.new baby loves her gas.]]>
   <pubDate>Mon, 03 Apr 2017 14:53:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=90425#90425</guid>
   <title>Tow vehicle : Thanks for 4.6 info. I don&amp;#039;t...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=90051#90051</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6392" rel="nofollow">Bugout</a><br /><strong>Subject:</strong> 9559<br /><strong>Posted:</strong> 28 Mar 2017 at 10:34am<br /><br />Thanks for 4.6 &nbsp;info. I don't think I want 5.6 trying to stay on budget.ford looked good but want a v8 .plus long term Toyota man]]>
   <pubDate>Tue, 28 Mar 2017 10:34:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=90051#90051</guid>
   <title>Tow vehicle : If you are going Tundra, get the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=90041#90041</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3036" rel="nofollow">texman</a><br /><strong>Subject:</strong> 9559<br /><strong>Posted:</strong> 28 Mar 2017 at 9:30am<br /><br />If you are going Tundra, get the&nbsp; 5.7 ltr V8.&nbsp; i still get 12-15 mpg pulling the pod and sometimes better.<br>]]>
   <pubDate>Tue, 28 Mar 2017 09:30:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=90041#90041</guid>
   <title>Tow vehicle :  We towed our RP175 for about...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=90027#90027</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=647" rel="nofollow">Kickstart</a><br /><strong>Subject:</strong> 9559<br /><strong>Posted:</strong> 27 Mar 2017 at 9:48pm<br /><br /><div>We towed our RP175 for about two and a half years with our 4.6 Tundra. It did a fantastic job over all of the passes and foothills of Washington State. Towing mpg with the RPod was between 10 and 15 mpg--usually 12 to 13. The 2010 to 2013 4.6 Tundras were a little higher rated for towing (8200 lbs for mine) than the newer ones. I dunno why. I'm now towing up to 5000 lbs. wet weight with our Kodiak. Towing the big climbs of Colorado, Utah, and Arizona was no problem for the 4.6 at this weight. I always lock out overdrive 6th and sometimes 5th while towing.</div><div><br></div><div>P/S I also towed with a Tacoma, and it did OK, but got a little worse towing mpg than the Tundra 4.6, and couldn't come close to the towing ability of the 4.6. I know that the 5.7 Tundra is a horse for pulling, but most people don't give the 4.6 enough credit, as long as you keep it at a reasonable pulling weight.</div>]]>
   <pubDate>Mon, 27 Mar 2017 21:48:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=90027#90027</guid>
   <title>Tow vehicle : All so saw that post </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=90016#90016</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6392" rel="nofollow">Bugout</a><br /><strong>Subject:</strong> 9559<br /><strong>Posted:</strong> 27 Mar 2017 at 6:09pm<br /><br />All so saw that post]]>
   <pubDate>Mon, 27 Mar 2017 18:09:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=90016#90016</guid>
   <title>Tow vehicle : Not happy with Tacoma. Run bad...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=90015#90015</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6392" rel="nofollow">Bugout</a><br /><strong>Subject:</strong> 9559<br /><strong>Posted:</strong> 27 Mar 2017 at 6:07pm<br /><br />Not happy with Tacoma. Run bad . Shift bad. It got go &nbsp;the best time is now.trade in]]>
   <pubDate>Mon, 27 Mar 2017 18:07:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=90015#90015</guid>
   <title>Tow vehicle :  Check out &amp;#034;apltrez&amp;#034;...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=90013#90013</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 9559<br /><strong>Posted:</strong> 27 Mar 2017 at 5:55pm<br /><br /><br />Check out "apltrez" post from 2 days ago, another Tacoma post, and I believe labeled Chevy Colorado.  He sent me a PM.]]>
   <pubDate>Mon, 27 Mar 2017 17:55:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=90013#90013</guid>
   <title>Tow vehicle : think of a new tv not happy with...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=90010#90010</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6392" rel="nofollow">Bugout</a><br /><strong>Subject:</strong> 9559<br /><strong>Posted:</strong> 27 Mar 2017 at 5:41pm<br /><br />&nbsp;think of a new tv not happy with Tacoma. Looking at new tundra 4.6 v8 tow package any thoughts&nbsp;]]>
   <pubDate>Mon, 27 Mar 2017 17:41:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9559&amp;PID=90010#90010</guid>
