  <title>R-pod Owners Forum : Axle seals</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Axle seals</description>
  <pubDate>Thu, 29 Oct 2026 08:49:06 +0000</pubDate>
  <lastBuildDate>Wed, 05 Apr 2017 09:29:16 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=9551</WebWizForums:feedURL>
   <title>Axle seals : The repack on bearings , I think,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9551&amp;PID=90531#90531</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6583" rel="nofollow">apltrez</a><br /><strong>Subject:</strong> 9551<br /><strong>Posted:</strong> 05 Apr 2017 at 9:29am<br /><br />The repack on bearings , I think, has more to do with amount and type of miles. In my case, I heard some occasional sounds from the trailer brakes I didn't like so in getting to the brakes, it made sense to inspect, repack, I also changed to a Moly type bearing grease and then of course new seals. I also cleaned the brakes and will adjust as needed.<br><br>The axle mystery/saga is now resolved. I do have a Lippert axle, not a Dexter. I can only assume that along the way the PO replaced them with Timken bearings and some other seal. They are in great shape and are marked as Timken USA so I will continue to use them.<br>]]>
   <pubDate>Wed, 05 Apr 2017 09:29:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9551&amp;PID=90531#90531</guid>
   <title>Axle seals : I have a 2015 178, it has a Dexter...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9551&amp;PID=90527#90527</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 9551<br /><strong>Posted:</strong> 05 Apr 2017 at 8:35am<br /><br />I have a 2015 178, it has a Dexter axle.]]>
   <pubDate>Wed, 05 Apr 2017 08:35:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9551&amp;PID=90527#90527</guid>
   <title>Axle seals : Do the bearings need repacked...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9551&amp;PID=90520#90520</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6778" rel="nofollow">Danielw1</a><br /><strong>Subject:</strong> 9551<br /><strong>Posted:</strong> 04 Apr 2017 at 10:17pm<br /><br />Do the bearings need repacked that soon?]]>
   <pubDate>Tue, 04 Apr 2017 22:17:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9551&amp;PID=90520#90520</guid>
   <title>Axle seals : Yep, that&amp;#039;s what I read in...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9551&amp;PID=90506#90506</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6583" rel="nofollow">apltrez</a><br /><strong>Subject:</strong> 9551<br /><strong>Posted:</strong> 04 Apr 2017 at 8:20pm<br /><br />Yep, that's what I read in googling. I got infor on where Dexter stamped the axle with name and numbers and the fact that Dexter generally has an "upward bow" in the center of the axle.&nbsp; Gonna check on it tomorrow.<br><br>GG<br>]]>
   <pubDate>Tue, 04 Apr 2017 20:20:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9551&amp;PID=90506#90506</guid>
   <title>Axle seals : They have been known to use Dexter...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9551&amp;PID=90503#90503</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3238" rel="nofollow">Podster</a><br /><strong>Subject:</strong> 9551<br /><strong>Posted:</strong> 04 Apr 2017 at 7:42pm<br /><br />They have been known to use Dexter as well.&nbsp;<div><br></div><div>There should be an ID tag of sorts on the axle itself.&nbsp;</div><div><br></div><div><a href="https://www.google.com/search?q=trailer+axle+ID+tag&amp;espv=2&amp;source=lnms&amp;tbm=isch&amp;sa=X&amp;ved=0ahUKEwj9gZDSiYzTAhVH7WMKHVINDOgQ_AUIBygC&amp;biw=1164&amp;bih=835#tbm=isch&amp;q=lippert+axle+tag&amp;*" target="_blank">trailer axle ID tag - Google Search</a>&nbsp;</div><div><br></div><div><br></div>]]>
   <pubDate>Tue, 04 Apr 2017 19:42:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9551&amp;PID=90503#90503</guid>
   <title>Axle seals : Okay. Now I am really confused....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9551&amp;PID=90492#90492</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6583" rel="nofollow">apltrez</a><br /><strong>Subject:</strong> 9551<br /><strong>Posted:</strong> 04 Apr 2017 at 4:10pm<br /><br />Okay. Now I am really confused. After taking my hub of, removing the dust seal and bearings, cleaning it all up, I can find nothing that indicates that my axle is a Lippert. Bearings are Timken made in USA....a good thing...dust seal is an oddball and hub is some other brand. I stopped at the local Holiday World...they are an RPOD dealer.... and they sent me to their bearing supplier who matched the seal. <br><br>Either my'16 178 is an odd ball or someone changed bearlings before I got it. Both my dealer and his bearing supplier liked Timken Bearings because they are USA and they never had problems.<br><br>a great mystery.<br><br><br>]]>
   <pubDate>Tue, 04 Apr 2017 16:10:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9551&amp;PID=90492#90492</guid>
   <title>Axle seals :   I use OEM parts anytime the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9551&amp;PID=90312#90312</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3238" rel="nofollow">Podster</a><br /><strong>Subject:</strong> 9551<br /><strong>Posted:</strong> 02 Apr 2017 at 6:21am<br /><br /><div>I use OEM parts anytime the process involves a tear-down that I do not want to repeat, prematurely.&nbsp;</div><div><br></div><div>If I can do a simple parts R &amp; R, aftermarket may be OK.&nbsp;</div><div><br></div><div>I also believe there is no money to be saved on tires or brake components.&nbsp;<img src="https://www.rpod-owners.com/smileys/smiley1.gif" border="0" alt="Smile" title="Smile" /></div><div><br></div><div>I'm sure there are success stories out there that include using after market seals. I don't have time to sort out what and if I have the right seal. There is really no reason not to use OEM.&nbsp;</div><div><br></div><div>I get the wrong part quite often from local auto parts stores so I'm not a big fan of trying to eyeball a seal that appears to be correct. I suppose a trailer outfit would be a better choice, but I don't have one conveniently located.&nbsp;</div><div><br></div><div>I simply remove the guess work by going OEM and can have it shipped to the front door.&nbsp;</div><div><br></div><div>I leverage the shipping cost by ordering multiples along with any associated components.&nbsp;</div>]]>
   <pubDate>Sun, 02 Apr 2017 06:21:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9551&amp;PID=90312#90312</guid>
   <title>Axle seals : I have read through the maintenance...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9551&amp;PID=89922#89922</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6583" rel="nofollow">apltrez</a><br /><strong>Subject:</strong> 9551<br /><strong>Posted:</strong> 26 Mar 2017 at 11:28am<br /><br />I have read through the maintenance manual that folks have been posting to here. In particular I am curious about seals for the axles. I have a '16 Rpod 178and I want to inspect the brakes and repack the bearings. Normally I would take the old seal to NAPA and get a match and install the. However it appears<br><br>everything I have read here shows folks using the&nbsp; original? Leipert seals.<br><br>Is there a reason for this or would other brands that are a match work?<br><br>Thanks <br>Greg<br>]]>
   <pubDate>Sun, 26 Mar 2017 11:28:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9551&amp;PID=89922#89922</guid>
