  <title>R-pod Owners Forum : brake wires loose</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : brake wires loose</description>
  <pubDate>Thu, 29 Oct 2026 12:41:08 +0000</pubDate>
  <lastBuildDate>Tue, 21 Mar 2017 14:28:49 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=9477</WebWizForums:feedURL>
   <title>brake wires loose : Hey y&amp;#039;all, thank you for...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9477&amp;PID=89603#89603</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4328" rel="nofollow">jimhibb</a><br /><strong>Subject:</strong> 9477<br /><strong>Posted:</strong> 21 Mar 2017 at 2:28pm<br /><br />Hey y'all, thank you for your help and suggestions. talked to a service tech where I bought the TT, it doesn't make any difference which wire goes where. Furpod you had it right - good job. got the wires connected and we are ready to travel. this is a great forum and a great resource, thank you.<div>Jim</div>]]>
   <pubDate>Tue, 21 Mar 2017 14:28:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9477&amp;PID=89603#89603</guid>
   <title>brake wires loose : It&amp;#039;s actually a simple electromagnet..I...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9477&amp;PID=89529#89529</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 9477<br /><strong>Posted:</strong> 20 Mar 2017 at 12:30pm<br /><br />It's actually a simple electromagnet..I do not believe they are current dependent. ie: the +/- don't matter, that's why both wires are the same color.<br>]]>
   <pubDate>Mon, 20 Mar 2017 12:30:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9477&amp;PID=89529#89529</guid>
   <title>brake wires loose : thanks for the reply furpod, I...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9477&amp;PID=89524#89524</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4328" rel="nofollow">jimhibb</a><br /><strong>Subject:</strong> 9477<br /><strong>Posted:</strong> 20 Mar 2017 at 11:36am<br /><br />thanks for the reply furpod, I wish it was that simple. I have 2 green wires coming out of the passenger side brake back plate and 1 white wire with a black stripe and a black wire with 2 white stripes that I need to connect to the green wires... the tt is a 2015 rp178... very confusing... I thought of connecting them up to see what would happen but I'm not sure if that would cause more problems<div><br></div><div>Mike that is what I intended to do, thanks for the encouragement...</div>]]>
   <pubDate>Mon, 20 Mar 2017 11:36:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9477&amp;PID=89524#89524</guid>
   <title>brake wires loose : Also suggest you replace the tie...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9477&amp;PID=89380#89380</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 9477<br /><strong>Posted:</strong> 17 Mar 2017 at 5:41pm<br /><br />Also suggest you replace the tie wraps with a heavier grade, after your repairs.  Some heavy duty tie wraps will give you more confidence in the hook up.]]>
   <pubDate>Fri, 17 Mar 2017 17:41:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9477&amp;PID=89380#89380</guid>
   <title>brake wires loose : It&amp;#039;s the same on both sides,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9477&amp;PID=89374#89374</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 9477<br /><strong>Posted:</strong> 17 Mar 2017 at 3:35pm<br /><br />It's the same on both sides, so white to white and black to black<br><br>They get hit by road debris etc, and sometimes pull loose.<br>]]>
   <pubDate>Fri, 17 Mar 2017 15:35:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9477&amp;PID=89374#89374</guid>
   <title>brake wires loose : I have just noticed that brake...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9477&amp;PID=89372#89372</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4328" rel="nofollow">jimhibb</a><br /><strong>Subject:</strong> 9477<br /><strong>Posted:</strong> 17 Mar 2017 at 2:31pm<br /><br />I have just noticed that brake the wires on the back of my passenger side wheel are not connected. I do not know which wire to reconnect to which wire... Help please<img src="https://www.rpod-owners.com/smileys/smiley9.gif" border="0" alt="Embarrassed" title="Embarrassed" /><div>jim</div>]]>
   <pubDate>Fri, 17 Mar 2017 14:31:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9477&amp;PID=89372#89372</guid>
