  <title>R-pod Owners Forum : Fire Starters - Sawdust</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Fire Starters - Sawdust</description>
  <pubDate>Fri, 06 Nov 2026 22:25:45 +0000</pubDate>
  <lastBuildDate>Tue, 08 Dec 2009 13:32:46 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=943</WebWizForums:feedURL>
   <title>Fire Starters - Sawdust : Packing materials to start a fire...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=943&amp;PID=8508#8508</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=431" rel="nofollow">rpodcamper.com</a><br /><strong>Subject:</strong> 943<br /><strong>Posted:</strong> 08 Dec 2009 at 1:32pm<br /><br />Packing materials to start a fire is often forgotten or messy.Here is a fire starter that works every time and can be stored inyour camp box for years if needed. Go to your local cabinet shop andask for a coffee can full of saw dust from under their table. Uponarriving home melt a cube of wax. Put saw dust in a paper bag. When thewax is melted over very low heat, pour over saw dust and shake bagwell. Once mixed, press the mixture into paper egg cartons. Make surethe mixture is pressed firmly in to each egg holder and as full aspossible. (Wetting your hand prior to pressing will keep wax off yourhands be careful not to burn yourself) Let cool. Cut egg carton inindividual egg holders. Each fire starter will burn a good 10 minutesand only requires one match to light.]]>
   <pubDate>Tue, 08 Dec 2009 13:32:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=943&amp;PID=8508#8508</guid>
