  <title>R-pod Owners Forum : Dutch Oven - Facts</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Cook'n With Gas : Dutch Oven - Facts</description>
  <pubDate>Fri, 23 Oct 2026 06:39:31 +0000</pubDate>
  <lastBuildDate>Tue, 08 Dec 2009 00:32:10 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=937</WebWizForums:feedURL>
   <title>Dutch Oven - Facts : Never allow cast iron to sit in...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=937&amp;PID=8479#8479</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=431" rel="nofollow">rpodcamper.com</a><br /><strong>Subject:</strong> 937<br /><strong>Posted:</strong> 08 Dec 2009 at 12:32am<br /><br /><ol><li>Never allow cast iron to sit in water or allow water to stand in it. It will rust despite a good coating.</li><li>Neveruse soap on cast iron. The soap will get into the pores of the metaland won't come out very easy, but will return to taint your next meal.If soap is used accidentally, the oven should be re-seasoned, includingremoval of the present coating.</li><li>Do not place an emptycast iron pan or oven over a hot fire. Aluminum and many other metalscan tolerate it better but cast iron will crack or warp, ruining themetal.</li><li>Do not get in a hurry to heat cast iron, you will end up with burnt food or a damaged oven or pan.</li><li>Never put cold liquid into a very hot cast iron pan or oven. They will crack on the spot!</li></ol>]]>
   <pubDate>Tue, 08 Dec 2009 00:32:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=937&amp;PID=8479#8479</guid>
