  <title>R-pod Owners Forum : Dutch Oven - Storing</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Cook'n With Gas : Dutch Oven - Storing</description>
  <pubDate>Fri, 23 Oct 2026 10:15:34 +0000</pubDate>
  <lastBuildDate>Tue, 08 Dec 2009 00:30:24 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=936</WebWizForums:feedURL>
   <title>Dutch Oven - Storing : It is important when storing...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=936&amp;PID=8477#8477</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=431" rel="nofollow">rpodcamper.com</a><br /><strong>Subject:</strong> 936<br /><strong>Posted:</strong> 08 Dec 2009 at 12:30am<br /><br /><p>Itis important when storing your Dutch ovens to keep the lid cracked sothat air can circulate into it. This can be accomplished by laying apaper wick, made from a napkin or paper towel folded accordion style,across the rim of the oven leaving a small amount outside, and thensetting the lid down on top of it. The wick also acts to draw anymoisture out of the oven. If air cannot circulate into the Dutch oven,the oil used to protect it will turn rancid and will permeate the poresof the metal with a sour odor. <b>DO NOT</b> cook anything in a rancid oven, you will not be able to         stomach the food! A rancid oven must be stripped of its protective coating and then be re-seasoned again.</p>      <p>Whenstoring my Dutch ovens I like to put them in a protective cover to keepthem from collecting dust, and to keep anything that might brush upagainst them from getting dirty. The covers also help protect theoutside finish on the ovens from being scratched up in transit whencamping or transporting ovens.</p>      <a name="N&#111;no"></a>]]>
   <pubDate>Tue, 08 Dec 2009 00:30:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=936&amp;PID=8477#8477</guid>
