  <title>R-pod Owners Forum : CLEAN!!!</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Miscellaneous / Off-topic : CLEAN!!!</description>
  <pubDate>Sat, 24 Oct 2026 04:50:44 +0000</pubDate>
  <lastBuildDate>Thu, 14 Dec 2017 19:17:20 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=9314</WebWizForums:feedURL>
   <title>CLEAN!!! :
 Originally posted by SC for...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=102950#102950</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5684" rel="nofollow">patrick_dube</a><br /><strong>Subject:</strong> 9314<br /><strong>Posted:</strong> 14 Dec 2017 at 7:17pm<br /><br /><div>
<table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by SC for Huskers</strong></em><br /><br />Patrick_dube,  by any chance did you find out what kind of sealant to use?  My external shower area is also cracked. My Pod is a 2017 172, Must be a common problem. Thanks ahead of time.</td></tr></table>
</div><div><br></div><div>I used Grocel PoflexRV (available at Amazon). Could'nt find a tan version, so I bought a white one. I should've bought a black version as it blends more with the trim pieces.</div>]]>
   <pubDate>Thu, 14 Dec 2017 19:17:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=102950#102950</guid>
   <title>CLEAN!!! : Patrick_dube,  by any chance did...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=102889#102889</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6578" rel="nofollow">SC for Huskers</a><br /><strong>Subject:</strong> 9314<br /><strong>Posted:</strong> 12 Dec 2017 at 4:01pm<br /><br />Patrick_dube,  by any chance did you find out what kind of sealant to use?  My external shower area is also cracked. My Pod is a 2017 172, Must be a common problem. Thanks ahead of time. ]]>
   <pubDate>Tue, 12 Dec 2017 16:01:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=102889#102889</guid>
   <title>CLEAN!!! : The external shower area is cracked...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=95855#95855</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5684" rel="nofollow">patrick_dube</a><br /><strong>Subject:</strong> 9314<br /><strong>Posted:</strong> 02 Jul 2017 at 7:28pm<br /><br />The external shower area is cracked a bit. What sealant should I use? Looks like it's transparent...]]>
   <pubDate>Sun, 02 Jul 2017 19:28:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=95855#95855</guid>
   <title>CLEAN!!! : My method was to inspect the sealant...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=89056#89056</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 9314<br /><strong>Posted:</strong> 09 Mar 2017 at 8:30am<br /><br />My method was to inspect the sealant already there. If it looked intact, I did not mess with it. If it was cracked, I cleaned the old sealant in that area plus some of the surrounding area with denatured alcohol, then applied new Dicor sealant to the cracked area to fill the cracks. This seems to be a good way to seal without using large amounts of sealant.<br><br>When I installed, and recently removed, the vent cover, I just removed enough sealant around the screw holes to fit the brackets, cleaned the areas, and sealed them. When I remove the brackets, I did likewise to seal the screw holes and around where the brackets were. I removed the cover since our escaPOD will be going to the factory for repairs and I wanted to remove as many non-stock items as I could before it leaves here.&nbsp;]]>
   <pubDate>Thu, 09 Mar 2017 08:30:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=89056#89056</guid>
   <title>CLEAN!!! : We purchased our Dicor on Amazon...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=89045#89045</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 9314<br /><strong>Posted:</strong> 08 Mar 2017 at 10:14pm<br /><br />We purchased our Dicor on Amazon back in June 2016.&nbsp; Had to buy a two-pack for 24.00 - that included shipping.&nbsp; We did as StephenH stated per instructions; use denatured alcohol and then apply the Dicor.&nbsp; Even after 5 years the majority of the sealant looked pretty good.&nbsp; Ended up using almost 1 tube to do everything.]]>
   <pubDate>Wed, 08 Mar 2017 22:14:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=89045#89045</guid>
   <title>CLEAN!!! : Last time I got some, it was a...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=89042#89042</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 9314<br /><strong>Posted:</strong> 08 Mar 2017 at 9:55pm<br /><br />Last time I got some, it was a Camping World. I have seen it for sale on Amazon also.]]>
   <pubDate>Wed, 08 Mar 2017 21:55:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=89042#89042</guid>
   <title>CLEAN!!! : where did you buy the Dicor&amp;#039;s...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=89035#89035</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5077" rel="nofollow">osage</a><br /><strong>Subject:</strong> 9314<br /><strong>Posted:</strong> 08 Mar 2017 at 5:39pm<br /><br />where did you buy the Dicor's &nbsp;sealer?]]>
   <pubDate>Wed, 08 Mar 2017 17:39:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=89035#89035</guid>
   <title>CLEAN!!! : I just resealed my 178 it took...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=89030#89030</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6392" rel="nofollow">Bugout</a><br /><strong>Subject:</strong> 9314<br /><strong>Posted:</strong> 08 Mar 2017 at 3:17pm<br /><br />I just resealed my 178 it took 6 tubs of shelf leavening seam sealer.went right over the old.]]>
   <pubDate>Wed, 08 Mar 2017 15:17:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=89030#89030</guid>
   <title>CLEAN!!! : Dicor&amp;#039;s instructions are...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=89029#89029</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 9314<br /><strong>Posted:</strong> 08 Mar 2017 at 2:58pm<br /><br />Dicor's instructions are to use denatured alcohol to clean off the old sealant and to apply new sealant over the old sealant. You don't need to remove the old sealant unless you want to.]]>
   <pubDate>Wed, 08 Mar 2017 14:58:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=89029#89029</guid>
   <title>CLEAN!!! : We scraped off the old, wiped...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=89023#89023</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1100" rel="nofollow">Leo B</a><br /><strong>Subject:</strong> 9314<br /><strong>Posted:</strong> 08 Mar 2017 at 10:12am<br /><br />We scraped off the old, wiped it down clean and then resealed it with the new sealer.]]>
   <pubDate>Wed, 08 Mar 2017 10:12:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=89023#89023</guid>
   <title>CLEAN!!! : If the lap sealant looks &amp;#034;ifffy&amp;#034;,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=89021#89021</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2715" rel="nofollow">ToolmanJohn</a><br /><strong>Subject:</strong> 9314<br /><strong>Posted:</strong> 08 Mar 2017 at 9:49am<br /><br />If the lap sealant looks "ifffy", do you scrape the old stuff off and reseal (caulk gun???) with the same stuff, or do you go over the old stuff?]]>
   <pubDate>Wed, 08 Mar 2017 09:49:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=89021#89021</guid>
   <title>CLEAN!!! : Ditto!!   </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=89019#89019</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1100" rel="nofollow">Leo B</a><br /><strong>Subject:</strong> 9314<br /><strong>Posted:</strong> 08 Mar 2017 at 7:03am<br /><br />Ditto!!]]>
   <pubDate>Wed, 08 Mar 2017 07:03:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=89019#89019</guid>
   <title>CLEAN!!! : Yeah correct!   </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=89016#89016</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6573" rel="nofollow">ClariceRoberts</a><br /><strong>Subject:</strong> 9314<br /><strong>Posted:</strong> 08 Mar 2017 at 4:10am<br /><br />Yeah correct!]]>
   <pubDate>Wed, 08 Mar 2017 04:10:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=89016#89016</guid>
   <title>CLEAN!!! :   Originally posted by ronahueI...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=88157#88157</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 9314<br /><strong>Posted:</strong> 18 Feb 2017 at 8:04pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by ronahue</strong></em><br /><br />I use the same theory I use behind my ears, if you can't see it why wash it<img src="https://www.rpod-owners.com/smileys/smiley1.gif" border="0" alt="Smile" title="Smile" /></td></tr></table><br>Unfortunately, the roof of the R-Pod is not like behind our ears. The sun's UV rays will with time degrade the gelcoat and the top will eventually grow brittle and crack. Cleaning and applying a protective coating to the top of the R-Pod is not the easiest thing to do. However, it can extend the life of the roof. Besides, when the roof is being cleaned is a good time to inspect the lap sealant for cracks and to clean and apply more lap sealant as needed. If you never look up there, you won't know when a potential leak is developing.<br>]]>
   <pubDate>Sat, 18 Feb 2017 20:04:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=88157#88157</guid>
   <title>CLEAN!!! : I use the same theory I use behind...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=88153#88153</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4087" rel="nofollow">ronahue</a><br /><strong>Subject:</strong> 9314<br /><strong>Posted:</strong> 18 Feb 2017 at 5:35pm<br /><br />I use the same theory I use behind my ears, if you can't see it why wash it<img src="https://www.rpod-owners.com/smileys/smiley1.gif" border="0" alt="Smile" title="Smile" /><div><br></div>]]>
   <pubDate>Sat, 18 Feb 2017 17:35:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=88153#88153</guid>
   <title>CLEAN!!! : Same, same, I don&amp;#039;t feel...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=88146#88146</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 9314<br /><strong>Posted:</strong> 18 Feb 2017 at 2:57pm<br /><br />Same, same, I don't feel confident walking on roof, either way you need a ladder.  ]]>
   <pubDate>Sat, 18 Feb 2017 14:57:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=88146#88146</guid>
   <title>CLEAN!!! : oh ya, a ladder is a must for...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=88129#88129</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1821" rel="nofollow">hogone</a><br /><strong>Subject:</strong> 9314<br /><strong>Posted:</strong> 18 Feb 2017 at 7:00am<br /><br />oh ya, a ladder is a must for me.&nbsp; i use a car brush on a long handle for the top and hand wash the rest.&nbsp; i use turtle wax soap and wipe it down with turtle wax wash and wax. &nbsp; sparkly when done!!&nbsp; hogone&nbsp;]]>
   <pubDate>Sat, 18 Feb 2017 07:00:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=88129#88129</guid>
   <title>CLEAN!!! : New podder here. Just curious...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=88127#88127</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6462" rel="nofollow">Subzilla</a><br /><strong>Subject:</strong> 9314<br /><strong>Posted:</strong> 18 Feb 2017 at 5:17am<br /><br />New podder here. Just curious about cleaning methods??&nbsp;&nbsp;&nbsp;Ladder and scrub brush/cloth?&nbsp;&nbsp;&nbsp;Any easier way?  Thanks]]>
   <pubDate>Sat, 18 Feb 2017 05:17:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=88127#88127</guid>
   <title>CLEAN!!! : I scrubbed ours down after our...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=87870#87870</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 9314<br /><strong>Posted:</strong> 12 Feb 2017 at 2:50pm<br /><br />I scrubbed ours down after our winter trip. However, I still see the effects of road salt. I will be going under and cleaning and painting rust spots. I already have done some of them. I bought some Rust-oleum Rust Reformer to catch any spots my wire brushing may miss.<br>]]>
   <pubDate>Sun, 12 Feb 2017 14:50:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=87870#87870</guid>
   <title>CLEAN!!! : i don&amp;#039;t think we have received...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=87858#87858</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1821" rel="nofollow">hogone</a><br /><strong>Subject:</strong> 9314<br /><strong>Posted:</strong> 12 Feb 2017 at 10:31am<br /><br />i don't think we have received 2 inches total this year.&nbsp; not that st louis ever gets much, but this has been a super mellow winter.&nbsp; hogone]]>
   <pubDate>Sun, 12 Feb 2017 10:31:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=87858#87858</guid>
   <title>CLEAN!!! : I wish we could, ours is surrounded...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=87857#87857</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1100" rel="nofollow">Leo B</a><br /><strong>Subject:</strong> 9314<br /><strong>Posted:</strong> 12 Feb 2017 at 10:11am<br /><br />I wish we could, ours is surrounded by 3 foot of snow with 8-14 expected tonight.]]>
   <pubDate>Sun, 12 Feb 2017 10:11:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=87857#87857</guid>
   <title>CLEAN!!! : scrubbed the pod down yesterday....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=87852#87852</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1821" rel="nofollow">hogone</a><br /><strong>Subject:</strong> 9314<br /><strong>Posted:</strong> 12 Feb 2017 at 6:56am<br /><br />scrubbed the pod down yesterday<img src="https://www.rpod-owners.com/smileys/smiley20.gif" border="0" alt="Thumbs Up" title="Thumbs Up" />.&nbsp; looks really good.&nbsp; hogone]]>
   <pubDate>Sun, 12 Feb 2017 06:56:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9314&amp;PID=87852#87852</guid>
