  <title>R-pod Owners Forum : Need Help!  179 or 180</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Introduce Yourself : Need Help!  179 or 180</description>
  <pubDate>Fri, 25 Sep 2026 06:51:26 +0000</pubDate>
  <lastBuildDate>Mon, 14 Nov 2016 23:16:21 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=9010</WebWizForums:feedURL>
   <title>Need Help!  179 or 180 : I like the mod. When you finish...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84860#84860</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5215" rel="nofollow">Wnewman1</a><br /><strong>Subject:</strong> 9010<br /><strong>Posted:</strong> 14 Nov 2016 at 11:16pm<br /><br />I like the mod. When you finish it please post your material list. Thanks for sharing.]]>
   <pubDate>Mon, 14 Nov 2016 23:16:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84860#84860</guid>
   <title>Need Help!  179 or 180 : But it (an R-Dome) is not so convenient...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84856#84856</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 9010<br /><strong>Posted:</strong> 14 Nov 2016 at 7:53pm<br /><br />But it (an R-Dome) is not so convenient when one is traveling and stays are overnights and not extended. We did that last year, and plan on doing it again. Our first long trip was in the winter. Our next one will be also. Outside cooking is not necessarily going to take place, so we appreciate the inside kitchen. <br>Ultimately, each one will decide what works best for his or her circumstances. In our case, it is the 179.<br>]]>
   <pubDate>Mon, 14 Nov 2016 19:53:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84856#84856</guid>
   <title>Need Help!  179 or 180 : I&amp;#039;d forget both. My wife...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84849#84849</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6125" rel="nofollow">Douglas J</a><br /><strong>Subject:</strong> 9010<br /><strong>Posted:</strong> 14 Nov 2016 at 5:12pm<br /><br />I'd forget both. My wife and I, both in our 60's, and 1st timers, bought a 183G. It has the larger bathroom and the outside kitchen which we both believe is a huge plus. The only drawback is having to convert the table to the bed. I'd also suggest getting the R-Dome as it effectively doubles the usable space you have when the weather is good.<br /><br />Douglas and Michele]]>
   <pubDate>Mon, 14 Nov 2016 17:12:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84849#84849</guid>
   <title>Need Help!  179 or 180 : I&amp;#039;d like to see to where...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84843#84843</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 9010<br /><strong>Posted:</strong> 14 Nov 2016 at 3:04pm<br /><br />I'd like to see to where you relocated the water pump also. Enlarging the underneath storage would be nice. I mounted a 5x5 post inside my compartment for a ladder. This has proved to be very useful. However, it might not allow me to do any relocating of the pump. You can see this in my mods. The link is in my signature below.]]>
   <pubDate>Mon, 14 Nov 2016 15:04:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84843#84843</guid>
   <title>Need Help!  179 or 180 :  I kind of went nuts with this...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84840#84840</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5749" rel="nofollow">voisj</a><br /><strong>Subject:</strong> 9010<br /><strong>Posted:</strong> 14 Nov 2016 at 1:44pm<br /><br />I kind of went nuts with this mod, I took pictures and plan to post the how to after the drawers are built.(if it all works out) The whole thing is built with screws so it can all be put back to stock,and the top plywood comes off just like the original,so I can pull off the mattress and take off some screws and access it all.<br>I actually moved the pump 12" remounted with noise isolater pad ,and made the storage compartment up front deeper to hold my large easyup awning. And made the space just inside the outside access panel 6" taller inside so I can fit bins stacked up in there. The drawers will be able to pull out 36" (with the slide out out) and you can stand to one side or the other for access. The only issue my wife has is pillows next to the bottom of the window when the shades are down.]]>
   <pubDate>Mon, 14 Nov 2016 13:44:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84840#84840</guid>
   <title>Need Help!  179 or 180 :   Originally posted by voisjWnewman1,I...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84836#84836</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 9010<br /><strong>Posted:</strong> 14 Nov 2016 at 12:32pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by voisj</strong></em><br /><br /><span style="font-size: 11px; : rgb251, 251, 253;">Wnewman1,</span><div><span style=": rgb251, 251, 253;"><span style="font-size: 11px;">I agree on the lack of storage in the 180 so much, that yesterday I ordered 40"" full extension drawer guides and built&nbsp; his and hers drawers, 5 " deep 18" wide and 48" long. This is where most of the day to day clothes will go. I found interior matching shelf material at Home Depot for the face frame and drawer face material.&nbsp; <br></span></span></div></td></tr></table><br>It looks good. However, how will you get to the hot water heater and water pump? Even with the drawers out, it looks like it will be a problem getting to them through the top. The water heater can be accessed through the panel under the bed, but the water pump may be more problematic.<br><br>I see you still have the original mattress. I replaced ours after the third trip with the R-Pod.<br>]]>
   <pubDate>Mon, 14 Nov 2016 12:32:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84836#84836</guid>
   <title>Need Help!  179 or 180 : So cool. The ingenuity Americans...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84834#84834</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6269" rel="nofollow">Weekend Warrior</a><br /><strong>Subject:</strong> 9010<br /><strong>Posted:</strong> 14 Nov 2016 at 11:57am<br /><br />So cool. The ingenuity Americans come up with. No wonder we're the greatest country on planet earth.  ]]>
   <pubDate>Mon, 14 Nov 2016 11:57:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84834#84834</guid>
   <title>Need Help!  179 or 180 : Wnewman1,I agree on the lack of...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84833#84833</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5749" rel="nofollow">voisj</a><br /><strong>Subject:</strong> 9010<br /><strong>Posted:</strong> 14 Nov 2016 at 11:47am<br /><br /><span style="font-size: 11px; : rgb251, 251, 253;">Wnewman1,</span><div><span style=": rgb251, 251, 253;"><span style="font-size: 11px;">I agree on the lack of storage in the 180 so much, that yesterday I ordered 40"" full extension drawer guides and built&nbsp; his and hers drawers, 5 " deep 18" wide and 48" long. This is where most of the day to day clothes will go. I found interior matching shelf material at Home Depot for the face frame and drawer face material.<img src="uploads/5749/IMG_20161112_161948630_HDR_DVD_PAL.jpg" height="405" width="720" border="0" /> &nbsp;</span></span></div><div><span style=": rgb251, 251, 253;"><span style="font-size: 11px;"><br></span></span></div><div><span style=": rgb251, 251, 253;"><span style="font-size: 11px;"><br></span></span></div>]]>
   <pubDate>Mon, 14 Nov 2016 11:47:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84833#84833</guid>
   <title>Need Help!  179 or 180 : We picked the 180 for two reasons....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84827#84827</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5215" rel="nofollow">Wnewman1</a><br /><strong>Subject:</strong> 9010<br /><strong>Posted:</strong> 13 Nov 2016 at 10:46pm<br /><br />We picked the 180 for two reasons. First the full bath is a plus over the small bath in 179 for us. We use the campground showers if they are available. The second reason was sitting at the dinette you feel a bit more room and can look out both sides. The down side is less storage room. We haven't had a problem yet with storage. Whatever you pick you will love it. I know we do.]]>
   <pubDate>Sun, 13 Nov 2016 22:46:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84827#84827</guid>
   <title>Need Help!  179 or 180 : Congrats, happy camping for years...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84825#84825</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6127" rel="nofollow">Vector1952</a><br /><strong>Subject:</strong> 9010<br /><strong>Posted:</strong> 13 Nov 2016 at 10:17pm<br /><br />Congrats, happy camping for years to come]]>
   <pubDate>Sun, 13 Nov 2016 22:17:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84825#84825</guid>
   <title>Need Help!  179 or 180 : Just curious what material you...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84787#84787</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6269" rel="nofollow">Weekend Warrior</a><br /><strong>Subject:</strong> 9010<br /><strong>Posted:</strong> 12 Nov 2016 at 12:54pm<br /><br />Just curious what material you used to replace the foam inside the cushions?]]>
   <pubDate>Sat, 12 Nov 2016 12:54:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84787#84787</guid>
   <title>Need Help!  179 or 180 : Congratulations on your purchase....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84766#84766</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4951" rel="nofollow">CampCat</a><br /><strong>Subject:</strong> 9010<br /><strong>Posted:</strong> 11 Nov 2016 at 8:02pm<br /><br />Congratulations on your purchase.&nbsp;<img src="https://www.rpod-owners.com/smileys/smiley1.gif" border="0" alt="Smile" title="Smile" />]]>
   <pubDate>Fri, 11 Nov 2016 20:02:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84766#84766</guid>
   <title>Need Help!  179 or 180 : Hi John,First, Congratulations...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84764#84764</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5685" rel="nofollow">NickLPod</a><br /><strong>Subject:</strong> 9010<br /><strong>Posted:</strong> 11 Nov 2016 at 7:12pm<br /><br />Hi John,<div>First, Congratulations on your purchase - look forward to years of enjoyment !</div><div>- I checked my iPhone archive, no pictures, sorry</div><div>- As we live in the frozen North (Canada), our Pod is now in winter storage</div><div>- I searched Costco.ca for 'serving tray' &amp; found more expensive examples.</div><div>It is a solid black rectangular tray with 4 equal height sides and a knife &amp; fork pattern (from memory).</div><div>Was on sale for $10 or less at that time.</div><div>BTW I also bought 4 thin flexible cutting mats for different foodstuffs in Costco that fit the tray nicely</div><div>Hope this helps !</div>]]>
   <pubDate>Fri, 11 Nov 2016 19:12:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84764#84764</guid>
   <title>Need Help!  179 or 180 :    Originally posted by NickLPod,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84763#84763</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5749" rel="nofollow">voisj</a><br /><strong>Subject:</strong> 9010<br /><strong>Posted:</strong> 11 Nov 2016 at 6:34pm<br /><br /><br /><div></div><div></div><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by NickLPod</strong></em><br /><br />, I made a Costco tray into a cover for the 2 burners to extend cutting board space (is also the location for the drying rack after washing up).</div></td></tr></table><br /><div></div><div>Nickl</div><div>Do you have a picture of the stove cover/ tray you got at Costco, i went and looked around and coundn't find anything.</div><div>rgds John</div><br />]]>
   <pubDate>Fri, 11 Nov 2016 18:34:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84763#84763</guid>
   <title>Need Help!  179 or 180 : Congrats and have fun. </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84757#84757</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5787" rel="nofollow">densmorema</a><br /><strong>Subject:</strong> 9010<br /><strong>Posted:</strong> 11 Nov 2016 at 2:58pm<br /><br />Congrats and have fun.]]>
   <pubDate>Fri, 11 Nov 2016 14:58:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84757#84757</guid>
   <title>Need Help!  179 or 180 :   Originally posted by Ave8terWE...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84752#84752</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 9010<br /><strong>Posted:</strong> 11 Nov 2016 at 2:30pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Ave8ter</strong></em><br /><br />WE HAVE DECIDED.<br><br>I want to thank everyone for their input on this and after careful reflection and discussion, we have decided to go with the 179.<br><br>Pick it up on the 19th.<br><br>Thanks again.<br><br><br>PS - The table from Amazon looks exactly like one we picked up from Costco.</td></tr></table><br>Congratulations! I hope you enjoy your 179 as much as we are enjoying ours.<br>]]>
   <pubDate>Fri, 11 Nov 2016 14:30:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84752#84752</guid>
   <title>Need Help!  179 or 180 : Regarding tables for the 179,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84751#84751</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5021" rel="nofollow">TheBum</a><br /><strong>Subject:</strong> 9010<br /><strong>Posted:</strong> 11 Nov 2016 at 2:18pm<br /><br />Regarding tables for the 179, we picked up this table from our local Walmart. It's 10" longer than the Amazon one (20" x 40") but still folds up very compactly.<br /><br /><a href="https://www.walmart.com/ip/Mainstays-20-x-40-Table-Black/54571383" target="_blank">https://www.walmart.com/ip/Mainstays-20-x-40-Table-Black/54571383</a>]]>
   <pubDate>Fri, 11 Nov 2016 14:18:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84751#84751</guid>
   <title>Need Help!  179 or 180 : Where do you spend most of your...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84747#84747</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3481" rel="nofollow">scott59</a><br /><strong>Subject:</strong> 9010<br /><strong>Posted:</strong> 11 Nov 2016 at 1:31pm<br /><br />Where do you spend most of your time?<br /><br />The kitchen<br /><br />or the<br /><br />bathroom?]]>
   <pubDate>Fri, 11 Nov 2016 13:31:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84747#84747</guid>
   <title>Need Help!  179 or 180 : WE HAVE DECIDED.  I want to thank...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84743#84743</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6281" rel="nofollow">Ave8ter</a><br /><strong>Subject:</strong> 9010<br /><strong>Posted:</strong> 11 Nov 2016 at 11:47am<br /><br />WE HAVE DECIDED.<br /><br />I want to thank everyone for their input on this and after careful reflection and discussion, we have decided to go with the 179.<br /><br />Pick it up on the 19th.<br /><br />Thanks again.<br /><br /><br />PS - The table from Amazon looks exactly like one we picked up from Costco.]]>
   <pubDate>Fri, 11 Nov 2016 11:47:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84743#84743</guid>
   <title>Need Help!  179 or 180 : We chose the ancher 20 &#195;&#8212;30 inch...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84724#84724</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5787" rel="nofollow">densmorema</a><br /><strong>Subject:</strong> 9010<br /><strong>Posted:</strong> 11 Nov 2016 at 8:18am<br /><br />We chose the ancher 20 ×30 inch table which adjusts from 21-28 inches high,I just went to amazon and they don't show that same brand with that size table right now however they do have it in a lifetime brand same size and the same price I paid which is 33.44. It looks like the same one we bought.It's the closest thing I could find to the original table size which I think was 36×21 and about 29 inches high.by the way the model no.on that lifetime model on Amazon was 28241, hope that helps. We really like it, its so light and you can lay it on the bad or put it between the bed and the cushion on its side.<br />]]>
   <pubDate>Fri, 11 Nov 2016 08:18:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84724#84724</guid>
   <title>Need Help!  179 or 180 : We just picked up our 179 10/24/16...we...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84704#84704</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6127" rel="nofollow">Vector1952</a><br /><strong>Subject:</strong> 9010<br /><strong>Posted:</strong> 10 Nov 2016 at 9:29pm<br /><br />We just picked up our 179 &nbsp;10/24/16...we were like you the 180 bathroom but the dinette we use as a couch, the table goes on the bed....the countertop in the kitchen and the storage made up our minds...hope this helps<div><br></div>]]>
   <pubDate>Thu, 10 Nov 2016 21:29:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84704#84704</guid>
   <title>Need Help!  179 or 180 : Mike and Cherie, Which table did...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84702#84702</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6014" rel="nofollow">mooremg1</a><br /><strong>Subject:</strong> 9010<br /><strong>Posted:</strong> 10 Nov 2016 at 9:05pm<br /><br />Mike and Cherie, Which table did you choose from Amazon? &nbsp;We have a couple of roll-up tables we use outside in the R-Dome but we haven't tried them inside and they're not height adjustable either. &nbsp;&nbsp;]]>
   <pubDate>Thu, 10 Nov 2016 21:05:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84702#84702</guid>
   <title>Need Help!  179 or 180 : We keep our table at home and...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84699#84699</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5787" rel="nofollow">densmorema</a><br /><strong>Subject:</strong> 9010<br /><strong>Posted:</strong> 10 Nov 2016 at 7:24pm<br /><br />We keep our table at home and replaced it with one from amazon,it's almost the same size and adjusts to three different heights folds flat and u can put it almost anyware,sometimes we take it outside to use because it's so light.We also took our seat cushions and had the foam replaced in them,wow what a difference no more sinking down very firm.<br /><br /><br />]]>
   <pubDate>Thu, 10 Nov 2016 19:24:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84699#84699</guid>
   <title>Need Help!  179 or 180 :  Originally posted by voisj ...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84681#84681</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 9010<br /><strong>Posted:</strong> 10 Nov 2016 at 1:49pm<br /><br /> <table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by voisj</strong></em><br /><br /><br /><img src="uploads/5749/IMG_0980_DVD_PAL.JPG" height="480" width="720" border="0" /></td></tr></table> <br /><br />I think I was parked close to there this past summer.&nbsp;&nbsp;&nbsp;<img src="https://www.rpod-owners.com/smileys/smiley4.gif" border="0" align="middle" /> <br /><br /><br />]]>
   <pubDate>Thu, 10 Nov 2016 13:49:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84681#84681</guid>
   <title>Need Help!  179 or 180 : The CPAP machine is why my first...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84678#84678</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 9010<br /><strong>Posted:</strong> 10 Nov 2016 at 12:17pm<br /><br />The CPAP machine is why my first modifications were a 12V outlet and a shelf above the bed to hold the CPAP machine. Thank you for the additional information. I will keep the futon in mind for the future.]]>
   <pubDate>Thu, 10 Nov 2016 12:17:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84678#84678</guid>
   <title>Need Help!  179 or 180 :  Originally posted by StephenHRV...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84677#84677</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5021" rel="nofollow">TheBum</a><br /><strong>Subject:</strong> 9010<br /><strong>Posted:</strong> 10 Nov 2016 at 11:48am<br /><br /> <table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by StephenH</strong></em><br /><br />RV Queen is 75" long X 60" wide.  Rotating it gives 15" of space. 15" / 2 = 7-1/2". So, we will continue to have me climb over my wife until we can't do so any more. Then (probably me) one of us will use the dinette area while the other uses the bed.<br /><br /></td></tr></table><br /><br />My wife and I already use separate beds in our 179. She suffers from frequent insomnia and I have to use a CPAP, so the near side of the bed would be the best place for both if we both slept there. So, she sleeps on the dinette (she's shorter than I am).<br /><br />Before we put in the futon, she was using an air mattress that we had to inflate every night and deflate every morning. With the futon, converting from bed to sofa and vice versa is very fast.]]>
   <pubDate>Thu, 10 Nov 2016 11:48:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84677#84677</guid>
   <title>Need Help!  179 or 180 : The only thing that keeps our...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84671#84671</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 9010<br /><strong>Posted:</strong> 09 Nov 2016 at 9:58pm<br /><br />The only thing that keeps our 179 from being perfect is the same thing that would apply to the 180. That is, the lack of a walk-around bed. Given the space constraints, it probably could not be done in a trailer the width of the R-Pod. I would take a smaller dinette&nbsp; and move the wardrobe to small ones on either side of the bed if there were enough room to do so in the 179. Given that there would only be 7-1/2" of space on either side if the mattress were rotated 90 degrees, it would not give sufficient space to maneuver along the sides.<br><br>RV Queen is 75" long X 60" wide.&nbsp; Rotating it gives 15" of space. 15" / 2 = 7-1/2". So, we will continue to have me climb over my wife until we can't do so any more. Then (probably me) one of us will use the dinette area while the other uses the bed.<br>]]>
   <pubDate>Wed, 09 Nov 2016 21:58:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84671#84671</guid>
   <title>Need Help!  179 or 180 : We have a 177 that we purchased...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84668#84668</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 9010<br /><strong>Posted:</strong> 09 Nov 2016 at 9:24pm<br /><br />We have a 177 that we purchased in January 2011.&nbsp; Much good wisdom and advice above.&nbsp; Let me add this to the mix.&nbsp; Go to the dealer you plan on purchasing your 179 or 180 from.&nbsp; Spend at least an hour or two or more in each, make notes on your likes/dislikes&nbsp; and discuss your results with each other.&nbsp; Am sure you will reach a consensus and be happy with it.&nbsp; We are still really happy with our 177, been a great, dependable TT for us.]]>
   <pubDate>Wed, 09 Nov 2016 21:24:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84668#84668</guid>
   <title>Need Help!  179 or 180 :   Originally posted by NickLPodWe...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84667#84667</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 9010<br /><strong>Posted:</strong> 09 Nov 2016 at 9:18pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by NickLPod</strong></em><br /><br />We (the boss &amp; I) had the same discussion &amp; bought the 180 over the 179 this summer.<div>The 180 dry bathroom just beat the nice wide kitchen counter space in the 180.</div><div>We do use the bathroom features: toilet at night, the shower to wash feet &amp; ankles, and as a change room.</div><div>(This latter is important for my wife, who believes I should not change in full view of others).</div><div>Storage for short trips is fine and we eat at the dinette or outside in the dome when possible.</div><div>As suggested &amp; implemented by many others in this forum (cool!), I made a Costco tray into a cover for the 2 burners to extend cutting board space (is also the location for the drying rack after washing up).</div></td></tr></table><br>We added a spring-tension shower rod and a set of curtains by the bed. If need be, we can move those. If the bathroom door is open, it also acts as a visual block for the other end of the R-Pod so if the dinette window cover is closed, one has a significant amount of space in which to change that is not visible to someone at the kitchen end.<br><br>We use our bathroom in our 179 at night also and have showered in there, not just washed our feet and ankles.<br><br>In the end, each of us will choose the one he/she feels is the right one for him/her. In this case, the rule, "If mama ain't happy, ain't nobody happy!" applies.<br>]]>
   <pubDate>Wed, 09 Nov 2016 21:18:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84667#84667</guid>
   <title>Need Help!  179 or 180 : Hi there!  Ditto on all of the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84665#84665</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5352" rel="nofollow">birderdiane526</a><br /><strong>Subject:</strong> 9010<br /><strong>Posted:</strong> 09 Nov 2016 at 8:08pm<br /><br />Hi there!  Ditto on all of the things said about the 179. We are really happy with ours. We had been full-timing in a Teardrop and stumbled upon Rpods which met our needs for more space without going to large. So we upgraded in June to a 179 and love it. Even the tiny wet bath! You're bound to love either! Happy trails!]]>
   <pubDate>Wed, 09 Nov 2016 20:08:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9010&amp;PID=84665#84665</guid>
