  <title>R-pod Owners Forum : Whats needed</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Introduce Yourself : Whats needed</description>
  <pubDate>Fri, 25 Sep 2026 06:03:41 +0000</pubDate>
  <lastBuildDate>Tue, 08 Nov 2016 21:27:51 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=9000</WebWizForums:feedURL>
   <title>Whats needed : ok, a few things i had, a few...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9000&amp;PID=84637#84637</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6126" rel="nofollow">mjlrpod</a><br /><strong>Subject:</strong> 9000<br /><strong>Posted:</strong> 08 Nov 2016 at 9:27pm<br /><br />ok, a few things i had, a few things i just ordered, and between now and spring i'll chip away at getting a few more things. thanks everyone.]]>
   <pubDate>Tue, 08 Nov 2016 21:27:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9000&amp;PID=84637#84637</guid>
   <title>Whats needed :              This is a...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9000&amp;PID=84630#84630</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5232" rel="nofollow">Richand Cindy</a><br /><strong>Subject:</strong> 9000<br /><strong>Posted:</strong> 08 Nov 2016 at 5:28pm<br /><br /><!--if gte mso 9> <o:OfficeSettings>  <o:Rely&#079;nVML/>  <o:AllowPNG/> </o:OfficeSettings><!--><p ="Ms&#111;normal">This is a long post but since it took me two years to research and buy my RPOD 180 I accumulated significant information on accessories to buy.&nbsp; So I am sharing my list.&nbsp; Feel free to add to it..<br></p><p ="Ms&#111;normal">RV Assessory Checklist (items you need to buy, should buy,or just some that are nice to have)</p><p ="Ms&#111;normal">E<b style="mso-bidi-font-weight:normal">xtended warranty</b>.<span style="mso-spacerun:yes">&nbsp; </span>Do not buy third party.<span style="mso-spacerun:yes">&nbsp; </span>Forest River sells a one year extendedwarranty for $150.00 The dealer makes no money off of it and may not tell youabout it and try to sell you their version (which legally cannot be called awarranty – it is an extended service plan).<span style="mso-spacerun:yes">&nbsp;</span>You must act quickly, as offer expires (one posting said you had to buyit within 30 days after getting RPOD).<span style="mso-spacerun:yes">&nbsp;</span>Call Forest River directly if dealer acts ignorant.<span style="mso-spacerun:yes">&nbsp; </span>Dealer service plans are generally expensiveand most reviews are negative.<span style="mso-spacerun:yes">&nbsp; </span>Somedealers include a free unlimited warranty.<span style="mso-spacerun:yes">&nbsp;</span>This is not a scam but may not be a good deal.<span style="mso-spacerun:yes">&nbsp; </span>You have to bring you RV back to dealer oncea year for $150 inspection to keep warranty active.<span style="mso-spacerun:yes">&nbsp; </span>And then it does not really warranty the RV(leaks, axle breaks) but rather the components (refrig, heater).<span style="mso-spacerun:yes">&nbsp; </span>Only worth buying at a dealer that includesit if they do not charge more for the RV.<span style="mso-spacerun:yes">&nbsp;</span>One dealer who was $3000 more than another said, “but the warranty isfree and that’s worth the $3000 difference!”</p><p ="Ms&#111;normal"><b style="mso-bidi-font-weight:normal">Brake controller</b>– Even if TV has towing package it probably lacks a break controller.<span style="mso-spacerun:yes">&nbsp; </span>Tekumsa P2 is highly rated but moreexpensive.<span style="mso-spacerun:yes">&nbsp; </span>The less expensive the unitthe more it has to be in a fixed position (i.e. parallel to ground).<span style="mso-spacerun:yes">&nbsp; </span>It comes with wires to splice into TV howevermost tow packages already have the female harness so only need to buy maleharness for your vehicle (around $18) then no searching for the correct wiresto splice into, and you can remove unit at will.<span style="mso-spacerun:yes">&nbsp; </span>An internet search for your TV will let youknow where to find the hitch.<span style="mso-spacerun:yes">&nbsp; </span>On ourJeep Cherokee it was hidden away and we could not find it until we found aUTube video demonstration.</p><p ="Ms&#111;normal"><b style="mso-bidi-font-weight:normal">Weight distribution(WDH) and anti sway</b></p><p ="Ms&#111;normal" style="text-indent:.5in">-Equal-i-zer weight distributionhitch 10,000 lbs $408<span style="mso-spacerun:yes">&nbsp; </span>includes 4 ptfriction sway control. </p><p ="Ms&#111;normal" style="margin-left:.5in">-Blue OX is also highly rated.<span style="mso-spacerun:yes">&nbsp; </span>It prevents sway instead of correctingit.<span style="mso-spacerun:yes">&nbsp; </span>It is $600 and easier toconnect.<span style="mso-spacerun:yes">&nbsp; </span>Get 350 lb tongue weight version</p><p ="Ms&#111;normal" style="margin-left:.5in">-There are numerous cheaperoptions.<span style="mso-spacerun:yes">&nbsp; </span>But you may not be able to backup and/or do not have anti sway, only weight distribution.<span style="mso-spacerun:yes">&nbsp; </span>Most people say anti-sway is required but WDHis not necessary as larger tow vehicles can handle it well.</p><p ="Ms&#111;normal"><b style="mso-bidi-font-weight:normal">Other items</b></p><p ="Ms&#111;normal">□<span style="mso-tab-count:1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>Whitewater hose (for drinking water only) 25’ Camco $9.97</p><p ="Ms&#111;normal">□<span style="mso-tab-count:1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>Garden waterhose (for black water flush and all other washing)</p><p ="Ms&#111;normal">□<span style="mso-tab-count:1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>Waterfilter with right angle</p><p ="Ms&#111;normal">□<span style="mso-tab-count:1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>Waterpressure regulator</p><p ="Ms&#111;normal"><span style="mso-tab-count:1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>Yconnector to attach two hoses to single water line</p><p ="Ms&#111;normal" style="margin-left:.5in;text-indent:-.5in">□<span style="mso-tab-count:1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>Oxy-Kem holding tank treatment.<span style="mso-spacerun:yes">&nbsp; </span>Turn off vent fan when going to the bathroom.<span style="mso-spacerun:yes">&nbsp; </span>Always wait until black tank is 2/3 fullbefore emptying</p><p ="Ms&#111;normal" style="margin-left:.5in;text-indent:-.5in">□<span style="mso-tab-count:1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>Sewer hose 2 x 10’ is better thansingle 15 foot (Valterra D04-0275 newer version comes with clear elbow $50.50).<span style="mso-spacerun:yes">&nbsp; </span>Reported to have less leaks than Camco model</p><p ="Ms&#111;normal">□<span style="mso-tab-count:1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>Sewerelbow to connect to ground hole (comes with Valterra above)</p><p ="Ms&#111;normal" style="margin-left:.5in;text-indent:-.5in">□<span style="mso-tab-count:1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>Sewer elbow clear to connect to RVto see when water is clean Valterra T1026<span style="mso-spacerun:yes">&nbsp;</span>$11.50 (also comes with Valterra above)</p><p ="Ms&#111;normal">□<span style="mso-tab-count:1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>Sewerhose holder to keep hose slanted to ground Camco 43051 20’ $22.94</p><p ="Ms&#111;normal" style="margin-left:.5in;text-indent:-.5in">□<span style="mso-tab-count:1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>Disposable gloves for cleaning outholding tanks (or strong rubber gloves to re-use and save the environment)</p><p ="Ms&#111;normal" style="margin-left:.5in;text-indent:-.5in">□<span style="mso-tab-count:1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>NCVT Fluke volt alert (looks like apenlight)– standing on the ground touch the door frame or steps if there isvoltage leak it will light up preventing a shock.<span style="mso-spacerun:yes">&nbsp; </span>Do it when first setting up camp andconnecting electric</p><p ="Ms&#111;normal">□<span style="mso-tab-count:1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>Tireleveling plastic with chock for under tires</p><p ="Ms&#111;normal">□<span style="mso-tab-count:1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>Plasticpads for stabilizers (Do not use wood)</p><p ="Ms&#111;normal">□<span style="mso-tab-count:1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>Lock fortrailer hitch to prevent someone from stealing your RV when left alone unhooked</p><p ="Ms&#111;normal" style="margin-left:.5in;text-indent:-.5in">□<span style="mso-tab-count:1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>Leveling guides. One type goes onhitch and turns to tell you how many inches to raise RV. Other types stick toside walls.</p><p ="Ms&#111;normal">□<span style="mso-tab-count:1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>Propanetank gauge.<span style="mso-spacerun:yes">&nbsp; </span>May need to get second tankbut try it first with one tank.</p><p ="Ms&#111;normal" style="margin-left:.5in;text-indent:-.5in">□<span style="mso-tab-count:1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>Bug and rodent screens – Spiders infurnace, refrigerator and hot water heater can do damage.<span style="mso-spacerun:yes">&nbsp; </span>Need to get screens for all vents.<span style="mso-spacerun:yes">&nbsp; </span>Camco 42154 for Dometic refrigerator Pack of6 vents $15.88.<span style="mso-spacerun:yes">&nbsp; </span>Camco 42141 furnace ventscreen 2 Pack $10.86. Camco 42145 Large screen for water heater $16.00</p><p ="Ms&#111;normal">□<span style="mso-tab-count:1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>Lawn mat(Do not use plastic grass – stays wet) use porous material made for RVing</p><p ="Ms&#111;normal">□<span style="mso-tab-count:1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>Dustbroom with pan</p><p ="Ms&#111;normal">□<span style="mso-tab-count:1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>Lanternsand flashlight</p><p ="Ms&#111;normal">□<span style="mso-tab-count:1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>Sparefuses</p><p ="Ms&#111;normal">□<span style="mso-tab-count:1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>BBQ Grill– <span style="mso-spacerun:yes">&nbsp;</span>can get propane now that 2017.5 RV hasquick connector</p><p ="Ms&#111;normal">□<span style="mso-tab-count:1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>Propanehose extension 10 foot Camco $21.26 (not the standard size 3/8”)</p><p ="Ms&#111;normal">□<span style="mso-tab-count:1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>Stickymats to keep things on the counter</p><p ="Ms&#111;normal">□<span style="mso-tab-count:1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>Wooddowels to keep windows closed and locked – so they do not open during drives</p><p ="Ms&#111;normal">□<span style="mso-tab-count:1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>Expandabledrapery rods to put in refrigerator to hold food in place</p><p ="Ms&#111;normal" style="margin-left:.5in;text-indent:-.5in">□<span style="mso-tab-count:1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>Oxygenics<span style="mso-spacerun:yes">&nbsp; </span>BodySpa RV shower kit – white (ModelETL26781) Amazon $31.13.<span style="mso-spacerun:yes">&nbsp; </span>Sends water athigher pressure thus using less water for a shower.<span style="mso-spacerun:yes">&nbsp; </span>Great product reviews, really works. Made forRV</p><p ="Ms&#111;normal" style="margin-left:.5in;text-indent:-.5in">□<span style="mso-tab-count:1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>GPS<span style="mso-spacerun:yes">&nbsp;</span>While a car GPS is handy it is not designed for RV use.<span style="mso-spacerun:yes">&nbsp; </span>For one, you will drive slower and theestimated time will be off by as much as a third.<span style="mso-spacerun:yes">&nbsp; </span>Second, you may want to avoid steep grades,low bridges and normal GPS does not have a setting for that.<span style="mso-spacerun:yes">&nbsp; </span>There are a few freestanding GPS units thatare made for RV’s. Unfortunately if you already own a GPS they do not sell mapsto convert to RV use.<span style="mso-spacerun:yes">&nbsp; </span>However there isan APP designed for smartphones that is specific to RV’s .<span style="mso-spacerun:yes">&nbsp; </span>It is called CoPilot.<span style="mso-spacerun:yes">&nbsp; </span>Expensive at $59.99 and has many negativereviews, so buyer beware.</p><p ="Ms&#111;normal">&nbsp;</p><p ="Ms&#111;normal">&nbsp;</p><p ="Ms&#111;normal">Replace mattress </p><p ="Ms&#111;normal" style="margin-left:.5in">-11” NuForm Quilted pillow top memoryfoam short queen 60 x 74 (RPOD <span style="mso-spacerun:yes">&nbsp;</span>is 74”)RV size $258 price raised to $279 at Overstock.<span style="mso-spacerun:yes">&nbsp;</span>Regular queen is 60 x 80</p><p ="Ms&#111;normal">&nbsp;</p><p ="Ms&#111;normal">Replace 6 gal water heater with tankless unlimited hot water</p><p ="Ms&#111;normal" style="margin-left:.5in">-Truma Aqua Go <span style="mso-spacerun:yes">&nbsp;</span>basic model is $1099.<span style="mso-spacerun:yes">&nbsp; </span>Could always add it later, if running out ofhot water is an issue.<span style="mso-spacerun:yes">&nbsp; </span>It is said thatrunning water heater on both propane and electric at the same heats up water fast.So probably will be fine with existing 6 gal heater, especially if you can takeshort showers.<span style="mso-spacerun:yes">&nbsp; </span>Some dealers however willgive you trade in value (up to $300) for turning in a new unused waterheater.<span style="mso-spacerun:yes">&nbsp; </span>So check with you dealer as itmay be cheaper to do it at time of delivery before using the standard waterheater.<span style="mso-spacerun:yes">&nbsp; </span>Do not buy any other brand, theyare half the price but are all terrible!!!</p><p ="Ms&#111;normal">Add surge protection to RV</p><p ="Ms&#111;normal" style="margin-left:.5in">-Progressive industries EMS-PT30CPortable RV surge protector 30 AMP.<span style="mso-spacerun:yes">&nbsp;</span>Comes with metal hook to be able to lock it onto the electric box sothat it is not stolen.<span style="mso-spacerun:yes">&nbsp; </span>$235.00.<span style="mso-spacerun:yes">&nbsp; </span>This is better than just surge protectionsince it will also shut off current if it goes too low or is wired wrong.<span style="mso-spacerun:yes">&nbsp; </span>Even better, get the hard wired version(HW30C same price) so no worries about getting stolen.<span style="mso-spacerun:yes">&nbsp; </span>May need to have dealer install as itinvolves cutting into electric lines.<span style="mso-spacerun:yes">&nbsp;</span>Also has a low hum but to eliminate it people report using rubberspacers when attaching it to RV floor.</p><p ="Ms&#111;normal" style="margin-left:.5in">&nbsp;</p><p ="Ms&#111;normal">Improve WiFi</p><p ="Ms&#111;normal"><span style="mso-tab-count:1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </span>Althoughmany RV parks have free WiFi, the signal is usually spotty at best.<span style="mso-spacerun:yes">&nbsp; </span>Therefore you can add a WiFi extender to geta stronger signal.<span style="mso-spacerun:yes">&nbsp; </span>The WiFi Ranger isrecommended by some top RV YouTubers but does not have good overall reviews.<span style="mso-spacerun:yes">&nbsp; </span>There are cheaper options (as low as $60)that work well and do not require installation on roof of RPOD</p><p ="Ms&#111;normal">Add wind deflector on roof of tow vehicle.<span style="mso-spacerun:yes">&nbsp; </span>Very controversial, at best it saves 10% oraround 1 mpg</p><p ="Ms&#111;normal" style="text-indent:.5in">-Aeroplus by Purpleline $282 attachesto cross bar of roof rack (need to buy for $99 more)</p><p ="Ms&#111;normal" style="text-indent:.5in">-Aeroshield straps to door frame$366.<span style="mso-spacerun:yes">&nbsp; </span>No roof rack required. <span style="mso-spacerun:yes">&nbsp;&nbsp;</span>Does make ride more stable if wind is aproblem bouncing car around</p><p ="Ms&#111;normal">&nbsp;</p><p ="Ms&#111;normal">Washing Machine – yes they make washing machines that canfit into RPOD!<span style="mso-spacerun:yes">&nbsp; </span>If you really hatecampground laundromats consider doing your own laundry.<span style="mso-spacerun:yes">&nbsp; </span>These have separate tub for spinning dry andalmost completely dry clothes.<span style="mso-spacerun:yes">&nbsp; </span>Just hangoutside for final dry.<span style="mso-spacerun:yes">&nbsp; </span>Most campgroundswill not allow clotheslines to be strung across to trees but will allow clothesdryer racks that attach to RV or stand alone.</p><p ="Ms&#111;normal">Panda washing machine 28 lbs.<span style="mso-spacerun:yes">&nbsp; </span>Connects to sink or shower has almost 8 lbcapacity (5 shirts) $150.00 23x14x26.<span style="mso-spacerun:yes">&nbsp;</span>There are two other brands which are $80-85 which look similar and alsogot good reviews.<span style="mso-spacerun:yes">&nbsp; </span>So do not know why payingtwice the price for Panda is better</p><p ="Ms&#111;normal">&nbsp;</p><p ="Ms&#111;normal">If you get a smell in RV when towing with windows open youmay consider replacing the roof vent caps with Siphon 360 roof vents.<span style="mso-spacerun:yes">&nbsp; </span>Will need to unscrew old one, cut the ventpipe to 5/8, screw on the new <span style="mso-spacerun:yes">&nbsp;</span>one and sealwith DiCor lap sealant.<span style="mso-spacerun:yes">&nbsp; </span>There is a newmodel (389381) that goes over the old pipe and uses only caulk as it is notreplacing the old vent cap.<span style="mso-spacerun:yes">&nbsp; </span>Also cheaper$25 vs $35</p><p ="Ms&#111;normal">The old fan was Fantastic <span style="mso-spacerun:yes">&nbsp;</span>and needed a vent cover ($65).<span style="mso-spacerun:yes">&nbsp; </span>It was just replaced it with a differentcompany.<span style="mso-spacerun:yes">&nbsp; </span>See if there is a vent cover.<span style="mso-spacerun:yes">&nbsp; </span>This will allow you to travel with the fancover open even if it is raining.<span style="mso-spacerun:yes">&nbsp; </span></p><p ="Ms&#111;normal">Winter cover – Cover for 179 fits the 180 as the doors arein the same place.<span style="mso-spacerun:yes">&nbsp; </span>Classic AssessoriesPolyPro 3 Model 4 cover (part 80-197-17100-00) Amazon $151.<span style="mso-spacerun:yes">&nbsp; </span>They also make a PermaPro model for$191.<span style="mso-spacerun:yes">&nbsp; </span>Do not know what the difference is.</p><!--if gte mso 9> <w:Word>  <w:View>Normal</w:View>  <w:Zoom>0</w:Zoom>  <w:TrackMoves/>  <w:Trackatting/>  <w:Punctuati&#111;nKerning/>  <w:ValidateAgainstSchemas/>  <w:SaveIfInvalid>false</w:SaveIfInvalid>  <w:IgnoreMixed>false</w:IgnoreMixed>  <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText>  <w:D&#111;notPromoteQF/>  <w:LidThemeOther>EN-US</w:LidThemeOther>  <w:LidThemeAsian>X-NONE</w:LidThemeAsian>  <w:LidThemeComplex>X-NONE</w:LidThemeComplex>  <w:Compatibility>   <w:BreakWrappedTables/>   <w:SnapToGridInCell/>   <w:WrapTextWithPunct/>   <w:UseAsianBreakRules/>   <w:D&#111;ntGrowAutofit/>   <w:SplitPgBreakAndark/>   <w:EnableKerning/>   <w:D&#111;ntFlipMirrorIndents/>   <w:OverrideTableStyleHps/>  </w:Compatibility>  <m:mathPr>   <m:mathFont m:val="Cambria Math"/>   <m:brkBin m:val="before"/>   <m:brkBinSub m:val="&amp;#45;-"/>   <m:smallFrac m:val="off"/>   <m:dispDef/>   <m:lMargin m:val="0"/>   <m:rMargin m:val="0"/>   <m:defJc m:val="centerGroup"/>   <m:wrapIndent m:val="1440"/>   <m:intLim m:val="subSup"/>   <m:naryLim m:val="undOvr"/>  </m:mathPr></w:Word><!--><!--if gte mso 9> <w:LatentStyles DefLockedState="false" DefUnhideWhenUsed="false"    DefSemi="false" DefQat="false" DefPriority="99"    LatentStyleCount="371">  <w:LsdExcepti&#111;n Locked="false" Priority="0" Qat="true" Name="Normal"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Qat="true" Name="ing 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Semi="true"     UnhideWhenUsed="true" Qat="true" Name="ing 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Semi="true"     UnhideWhenUsed="true" Qat="true" Name="ing 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Semi="true"     UnhideWhenUsed="true" Qat="true" Name="ing 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Semi="true"     UnhideWhenUsed="true" Qat="true" Name="ing 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Semi="true"     UnhideWhenUsed="true" Qat="true" Name="ing 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Semi="true"     UnhideWhenUsed="true" Qat="true" Name="ing 7"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Semi="true"     UnhideWhenUsed="true" Qat="true" Name="ing 8"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Semi="true"     UnhideWhenUsed="true" Qat="true" Name="ing 9"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="index 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="index 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="index 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="index 4"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="index 5"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="index 6"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="index 7"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="index 8"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="index 9"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Semi="true"     UnhideWhenUsed="true" Name="toc 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Semi="true"     UnhideWhenUsed="true" Name="toc 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Semi="true"     UnhideWhenUsed="true" Name="toc 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Semi="true"     UnhideWhenUsed="true" Name="toc 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Semi="true"     UnhideWhenUsed="true" Name="toc 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Semi="true"     UnhideWhenUsed="true" Name="toc 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Semi="true"     UnhideWhenUsed="true" Name="toc 7"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Semi="true"     UnhideWhenUsed="true" Name="toc 8"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Semi="true"     UnhideWhenUsed="true" Name="toc 9"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Normal Indent"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="footnote text"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="annotati&#111;n text"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="er"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="footer"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="index ing"/>  <w:LsdExcepti&#111;n Locked="false" Priority="35" Semi="true"     UnhideWhenUsed="true" Qat="true" Name="capti&#111;n"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="table of figures"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="envelope address"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="envelope return"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="footnote reference"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="annotati&#111;n reference"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="line number"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="page number"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="endnote reference"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="endnote text"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="table of authorities"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="macro"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="toa ing"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List Bullet"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List Number"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List 4"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List 5"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List Bullet 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List Bullet 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List Bullet 4"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List Bullet 5"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List Number 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List Number 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List Number 4"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List Number 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="10" Qat="true" Name="Title"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Closing"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Signature"/>  <w:LsdExcepti&#111;n Locked="false" Priority="1" Semi="true"     UnhideWhenUsed="true" Name="Default Paragraph Font"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Text"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Text Indent"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List C&#111;ntinue"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List C&#111;ntinue 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List C&#111;ntinue 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List C&#111;ntinue 4"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List C&#111;ntinue 5"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Message er"/>  <w:LsdExcepti&#111;n Locked="false" Priority="11" Qat="true" Name="Subtitle"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Salutati&#111;n"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Date"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Text First Indent"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Text First Indent 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Note ing"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Text 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Text 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Text Indent 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Text Indent 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Block Text"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Hyper"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="FollowedHyper"/>  <w:LsdExcepti&#111;n Locked="false" Priority="22" Qat="true" Name="Str&#111;ng"/>  <w:LsdExcepti&#111;n Locked="false" Priority="20" Qat="true" Name="Emphasis"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" "/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Plain Text"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="E-mail Signature"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Top of "/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Bottom of "/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Normal Web"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Acr&#111;nym"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Address"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Cite"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Code"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Definiti&#111;n"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Keyboard"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Preatted"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" le"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" r"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Variable"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Normal Table"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="annotati&#111;n subject"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="No List"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Outline List 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Outline List 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Outline List 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Simple 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Simple 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Simple 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table ic 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table ic 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table ic 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table ic 4"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Colorful 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Colorful 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Colorful 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Columns 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Columns 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Columns 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Columns 4"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Columns 5"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Grid 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Grid 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Grid 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Grid 4"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Grid 5"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Grid 6"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Grid 7"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Grid 8"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table List 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table List 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table List 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table List 4"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table List 5"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table List 6"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table List 7"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table List 8"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table 3D effects 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table 3D effects 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table 3D effects 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table C&#111;ntemporary"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Elegant"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Professi&#111;nal"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Subtle 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Subtle 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Web 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Web 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Web 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Ballo&#111;n Text"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Name="Table Grid"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Theme"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" Name="Placeholder Text"/>  <w:LsdExcepti&#111;n Locked="false" Priority="1" Qat="true" Name="No Spacing"/>  <w:LsdExcepti&#111;n Locked="false" Priority="60" Name="Light Shading"/>  <w:LsdExcepti&#111;n Locked="false" Priority="61" Name="Light List"/>  <w:LsdExcepti&#111;n Locked="false" Priority="62" Name="Light Grid"/>  <w:LsdExcepti&#111;n Locked="false" Priority="63" Name="Medium Shading 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="64" Name="Medium Shading 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="65" Name="Medium List 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="66" Name="Medium List 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="67" Name="Medium Grid 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="68" Name="Medium Grid 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="69" Name="Medium Grid 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="70" Name="Dark List"/>  <w:LsdExcepti&#111;n Locked="false" Priority="71" Name="Colorful Shading"/>  <w:LsdExcepti&#111;n Locked="false" Priority="72" Name="Colorful List"/>  <w:LsdExcepti&#111;n Locked="false" Priority="73" Name="Colorful Grid"/>  <w:LsdExcepti&#111;n Locked="false" Priority="60" Name="Light Shading Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="61" Name="Light List Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="62" Name="Light Grid Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="63" Name="Medium Shading 1 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="64" Name="Medium Shading 2 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="65" Name="Medium List 1 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" Name="Revisi&#111;n"/>  <w:LsdExcepti&#111;n Locked="false" Priority="34" Qat="true"     Name="List Paragraph"/>  <w:LsdExcepti&#111;n Locked="false" Priority="29" Qat="true" Name="Quote"/>  <w:LsdExcepti&#111;n Locked="false" Priority="30" Qat="true"     Name="Intense Quote"/>  <w:LsdExcepti&#111;n Locked="false" Priority="66" Name="Medium List 2 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="67" Name="Medium Grid 1 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="68" Name="Medium Grid 2 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="69" Name="Medium Grid 3 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="70" Name="Dark List Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="71" Name="Colorful Shading Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="72" Name="Colorful List Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="73" Name="Colorful Grid Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="60" Name="Light Shading Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="61" Name="Light List Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="62" Name="Light Grid Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="63" Name="Medium Shading 1 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="64" Name="Medium Shading 2 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="65" Name="Medium List 1 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="66" Name="Medium List 2 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="67" Name="Medium Grid 1 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="68" Name="Medium Grid 2 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="69" Name="Medium Grid 3 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="70" Name="Dark List Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="71" Name="Colorful Shading Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="72" Name="Colorful List Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="73" Name="Colorful Grid Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="60" Name="Light Shading Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="61" Name="Light List Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="62" Name="Light Grid Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="63" Name="Medium Shading 1 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="64" Name="Medium Shading 2 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="65" Name="Medium List 1 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="66" Name="Medium List 2 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="67" Name="Medium Grid 1 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="68" Name="Medium Grid 2 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="69" Name="Medium Grid 3 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="70" Name="Dark List Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="71" Name="Colorful Shading Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="72" Name="Colorful List Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="73" Name="Colorful Grid Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="60" Name="Light Shading Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="61" Name="Light List Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="62" Name="Light Grid Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="63" Name="Medium Shading 1 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="64" Name="Medium Shading 2 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="65" Name="Medium List 1 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="66" Name="Medium List 2 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="67" Name="Medium Grid 1 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="68" Name="Medium Grid 2 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="69" Name="Medium Grid 3 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="70" Name="Dark List Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="71" Name="Colorful Shading Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="72" Name="Colorful List Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="73" Name="Colorful Grid Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="60" Name="Light Shading Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="61" Name="Light List Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="62" Name="Light Grid Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="63" Name="Medium Shading 1 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="64" Name="Medium Shading 2 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="65" Name="Medium List 1 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="66" Name="Medium List 2 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="67" Name="Medium Grid 1 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="68" Name="Medium Grid 2 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="69" Name="Medium Grid 3 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="70" Name="Dark List Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="71" Name="Colorful Shading Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="72" Name="Colorful List Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="73" Name="Colorful Grid Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="60" Name="Light Shading Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="61" Name="Light List Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="62" Name="Light Grid Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="63" Name="Medium Shading 1 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="64" Name="Medium Shading 2 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="65" Name="Medium List 1 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="66" Name="Medium List 2 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="67" Name="Medium Grid 1 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="68" Name="Medium Grid 2 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="69" Name="Medium Grid 3 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="70" Name="Dark List Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="71" Name="Colorful Shading Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="72" Name="Colorful List Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="73" Name="Colorful Grid Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="19" Qat="true"     Name="Subtle Emphasis"/>  <w:LsdExcepti&#111;n Locked="false" Priority="21" Qat="true"     Name="Intense Emphasis"/>  <w:LsdExcepti&#111;n Locked="false" Priority="31" Qat="true"     Name="Subtle Reference"/>  <w:LsdExcepti&#111;n Locked="false" Priority="32" Qat="true"     Name="Intense Reference"/>  <w:LsdExcepti&#111;n Locked="false" Priority="33" Qat="true" Name="Book Title"/>  <w:LsdExcepti&#111;n Locked="false" Priority="37" Semi="true"     UnhideWhenUsed="true" Name="Bibliography"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Semi="true"     UnhideWhenUsed="true" Qat="true" Name="TOC ing"/>  <w:LsdExcepti&#111;n Locked="false" Priority="41" Name="Plain Table 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="42" Name="Plain Table 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="43" Name="Plain Table 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="44" Name="Plain Table 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="45" Name="Plain Table 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="40" Name="Grid Table Light"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46" Name="Grid Table 1 Light"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="Grid Table 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="Grid Table 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="Grid Table 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="Grid Table 5 Dark"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51" Name="Grid Table 6 Colorful"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52" Name="Grid Table 7 Colorful"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="Grid Table 1 Light Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="Grid Table 2 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="Grid Table 3 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="Grid Table 4 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="Grid Table 6 Colorful Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="Grid Table 7 Colorful Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="Grid Table 1 Light Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="Grid Table 2 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="Grid Table 3 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="Grid Table 4 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="Grid Table 6 Colorful Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="Grid Table 7 Colorful Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="Grid Table 1 Light Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="Grid Table 2 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="Grid Table 3 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="Grid Table 4 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="Grid Table 6 Colorful Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="Grid Table 7 Colorful Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="Grid Table 1 Light Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="Grid Table 2 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="Grid Table 3 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="Grid Table 4 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="Grid Table 6 Colorful Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="Grid Table 7 Colorful Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="Grid Table 1 Light Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="Grid Table 2 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="Grid Table 3 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="Grid Table 4 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="Grid Table 6 Colorful Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="Grid Table 7 Colorful Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="Grid Table 1 Light Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="Grid Table 2 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="Grid Table 3 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="Grid Table 4 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="Grid Table 6 Colorful Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="Grid Table 7 Colorful Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46" Name="List Table 1 Light"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="List Table 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="List Table 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="List Table 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="List Table 5 Dark"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51" Name="List Table 6 Colorful"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52" Name="List Table 7 Colorful"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="List Table 1 Light Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="List Table 2 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="List Table 3 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="List Table 4 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="List Table 5 Dark Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="List Table 6 Colorful Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="List Table 7 Colorful Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="List Table 1 Light Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="List Table 2 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="List Table 3 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="List Table 4 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="List Table 5 Dark Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="List Table 6 Colorful Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="List Table 7 Colorful Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="List Table 1 Light Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="List Table 2 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="List Table 3 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="List Table 4 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="List Table 5 Dark Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="List Table 6 Colorful Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="List Table 7 Colorful Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="List Table 1 Light Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="List Table 2 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="List Table 3 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="List Table 4 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="List Table 5 Dark Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="List Table 6 Colorful Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="List Table 7 Colorful Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="List Table 1 Light Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="List Table 2 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="List Table 3 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="List Table 4 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="List Table 5 Dark Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="List Table 6 Colorful Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="List Table 7 Colorful Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="List Table 1 Light Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="List Table 2 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="List Table 3 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="List Table 4 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="List Table 5 Dark Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="List Table 6 Colorful Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="List Table 7 Colorful Accent 6"/> </w:LatentStyles><!--><!--if gte mso 10> /* Style Definitions */ table.MsoNormalTable	{mso-style-name:"Table Normal";	mso-tstyle-rowband-size:0;	mso-tstyle-colband-size:0;	mso-style-noshow:yes;	mso-style-priority:99;	mso-style-parent:"";	mso-padding-alt:0in 5.4pt 0in 5.4pt;	mso-para-margin-top:0in;	mso-para-margin-right:0in;	mso-para-margin-bottom:10.0pt;	mso-para-margin-left:0in;	line-height:115%;	mso-pagination:widow-orphan;	font-size:11.0pt;	font-family:"Calibri",sans-serif;	mso-ascii-font-family:Calibri;	mso-ascii-theme-font:minor-latin;	mso-hansi-font-family:Calibri;	mso-hansi-theme-font:minor-latin;	mso-bidi-font-family:"Times New Roman";	mso-bidi-theme-font:minor-bidi;}<!-->]]>
   <pubDate>Tue, 08 Nov 2016 17:28:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9000&amp;PID=84630#84630</guid>
   <title>Whats needed : Pocket hose:http://www.target....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9000&amp;PID=84537#84537</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4397" rel="nofollow">Pete Brayton</a><br /><strong>Subject:</strong> 9000<br /><strong>Posted:</strong> 06 Nov 2016 at 9:13pm<br /><br />Pocket hose:&nbsp;<div>http://www.target.com/p/as-seen-on-tv-pocket-hose-50ft/-/A-14770356?ref=tgt_adv_XS000000&amp;AFID=google_pla_df&amp;CPNG=&amp;adgroup=&amp;LID=700000001170770pgs&amp;network=g&amp;device=c&amp;location=9028767&amp;gclid=Cj0KEQjwqfvABRC6gJ3T_4mwspoBEiQAyoQPkcsr7qFVTk6o7K4U8mkNolfS4kFpYt9X-uvFRLzHtiMaArln8P8HAQ&amp;gclsrc=aw.ds</div>]]>
   <pubDate>Sun, 06 Nov 2016 21:13:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9000&amp;PID=84537#84537</guid>
   <title>Whats needed : What&amp;#039;s a pocket hose? </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9000&amp;PID=84527#84527</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5352" rel="nofollow">birderdiane526</a><br /><strong>Subject:</strong> 9000<br /><strong>Posted:</strong> 06 Nov 2016 at 7:15pm<br /><br />What's a pocket hose?]]>
   <pubDate>Sun, 06 Nov 2016 19:15:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9000&amp;PID=84527#84527</guid>
   <title>Whats needed : What&amp;#039;s pocket hose? </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9000&amp;PID=84526#84526</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5352" rel="nofollow">birderdiane526</a><br /><strong>Subject:</strong> 9000<br /><strong>Posted:</strong> 06 Nov 2016 at 7:14pm<br /><br />What's pocket hose?]]>
   <pubDate>Sun, 06 Nov 2016 19:14:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9000&amp;PID=84526#84526</guid>
   <title>Whats needed : Either 2 or 4 wheel chocks. A...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9000&amp;PID=84525#84525</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 9000<br /><strong>Posted:</strong> 06 Nov 2016 at 7:06pm<br /><br />Either 2 or 4 wheel chocks.&nbsp; A set (usually come in 10 pack) of plastic self-leveling pads.&nbsp; Do you plan on boondocking a lot or usually camp where you have electricity?&nbsp; Solar panel for your z-amp is a possibility or an extra battery.&nbsp; If you plan on doing a lot off the grid and don't already have a battery look into 2 6 volt golf cart batteries.&nbsp; This is what I plan on once my 2 12v group 24's bite the dust.&nbsp; They have just completed year number 6 of faithful service, guess I will try one more year and see what happens.&nbsp; Look at other posts on this forum, a lot of great advice and wisdom can be found.&nbsp; Do a search on similar topics you should be able to pull up a lot of info you are looking for.]]>
   <pubDate>Sun, 06 Nov 2016 19:06:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9000&amp;PID=84525#84525</guid>
   <title>Whats needed : Get a 45 degree (or 90) clear...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9000&amp;PID=84524#84524</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6157" rel="nofollow">Bama Pod</a><br /><strong>Subject:</strong> 9000<br /><strong>Posted:</strong> 06 Nov 2016 at 6:55pm<br /><br />Get a 45 degree (or 90) clear elbow as well so can see when water runs clear.&nbsp; All fit in storage tube.&nbsp; Maybe consider a Sidewinder as well.&nbsp; Don't forget a dedicated black tank flush hose (we'll use one of the "pocket" hoses) just in case flush station does not have a hose.]]>
   <pubDate>Sun, 06 Nov 2016 18:55:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9000&amp;PID=84524#84524</guid>
   <title>Whats needed : Fifteen foot RhinoFlex. The whole...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9000&amp;PID=84522#84522</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1573" rel="nofollow">CharlieM</a><br /><strong>Subject:</strong> 9000<br /><strong>Posted:</strong> 06 Nov 2016 at 6:41pm<br /><br /><font size="3">Fifteen foot RhinoFlex. The whole thing fits in 60".<br><br><a href="http://www.amaz&#111;n.com/Camco-39761-RhinoFLEX-Swivel-Fittings/dp/B002OUMVWY/ref=sr_1_1?ie=UTF8&amp;qid=1478475560&amp;sr=8-1&amp;keywords=rhinoflex+sewer+hose" target="_blank">http://www.amazon.com/Camco-39761-RhinoFLEX-Swivel-Fittings/dp/B002OUMVWY/ref=sr_1_1?ie=UTF8&amp;qid=1478475560&amp;sr=8-1&amp;keywords=rhinoflex+sewer+hose</a><br></font>]]>
   <pubDate>Sun, 06 Nov 2016 18:41:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9000&amp;PID=84522#84522</guid>
   <title>Whats needed : Hello everyoneI just bought a...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=9000&amp;PID=84519#84519</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6126" rel="nofollow">mjlrpod</a><br /><strong>Subject:</strong> 9000<br /><strong>Posted:</strong> 06 Nov 2016 at 5:58pm<br /><br />Hello everyone<div>I just bought a new 2017 rp172 on the nov 5th. This is my first non pop up trailer. I wont be going out till spring, and i'd like to get some opinions on what things might be a good idea to buy during the winter so i'll be ready for spring. First thing i know i need, sewer hose system for black water hookup. Whats a good type? i have the new 2017 style, with the 62 inch storage tube. What lenth will fit the tube? any suggestions would be appreciated. I have the pod dome with mine, the 172 didnt have the awning, but honestly, i didnt like the way it looks anyway. thanks all</div>]]>
   <pubDate>Sun, 06 Nov 2016 17:58:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=9000&amp;PID=84519#84519</guid>
