  <title>R-pod Owners Forum : Looking at an R-pod purchase in the spring</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Introduce Yourself : Looking at an R-pod purchase in the spring</description>
  <pubDate>Fri, 25 Sep 2026 06:52:48 +0000</pubDate>
  <lastBuildDate>Tue, 18 Oct 2016 20:39:45 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=8917</WebWizForums:feedURL>
   <title>Looking at an R-pod purchase in the spring : I&amp;#039;m glad I was able to help.I...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8917&amp;PID=83721#83721</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 8917<br /><strong>Posted:</strong> 18 Oct 2016 at 8:39pm<br /><br />I'm glad I was able to help.<br><br>I just finished a couple of more mods which I will be posting to my mods soon. The wonderful thing about the R-Pods is that they almost cry out for the owner to customize things. While I was initially disappointed that my 2016 lacked some of the features that I read were supposed to be part of the 2016 lineup (making mine more of a 2015.5), my improvements have made it so much more. I wish you success on your R-Pod hunt.<br>]]>
   <pubDate>Tue, 18 Oct 2016 20:39:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8917&amp;PID=83721#83721</guid>
   <title>Looking at an R-pod purchase in the spring : Thanks again Stephen. I suspected...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8917&amp;PID=83720#83720</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6198" rel="nofollow">DrSafety</a><br /><strong>Subject:</strong> 8917<br /><strong>Posted:</strong> 18 Oct 2016 at 8:01pm<br /><br />Thanks again Stephen. I suspected as much.<div><br><div>Looking forward to the rpod hunt. I really like the added features and t he color of the 2017.5 models.<br><div><br></div></div></div>]]>
   <pubDate>Tue, 18 Oct 2016 20:01:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8917&amp;PID=83720#83720</guid>
   <title>Looking at an R-pod purchase in the spring : The Equal-i-zer 4-way stabilization,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8917&amp;PID=83708#83708</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 8917<br /><strong>Posted:</strong> 18 Oct 2016 at 1:06pm<br /><br />The Equal-i-zer 4-way stabilization, the Fastway E2 and the Andersen No-Sway hitches do not require a separate friction sway bar. Stabilization is built into the hitches. In the Equal-i-zer and the E2, the angle of the head and bars combined with the friction of the pivot points and the friction of the bars and the brackets on the trailer tongue provide the stabilization. On the Andersen, the friction of the ball's post in the socket provides the stabilization. As has been noted in another post, the closer the hitch is to the rear axle, the better as the short distance helps minimize the sway. In the case of the Escape, the distance is about 3 feet. Other vehicles like pickups would have the hitch much farther from the axle. We do feel a little "nudge" when passed by a tractor trailer or big panel truck. It isn't bad and I don't have to correct it.]]>
   <pubDate>Tue, 18 Oct 2016 13:06:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8917&amp;PID=83708#83708</guid>
   <title>Looking at an R-pod purchase in the spring :   Originally posted by ron_whittDr....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8917&amp;PID=83707#83707</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6198" rel="nofollow">DrSafety</a><br /><strong>Subject:</strong> 8917<br /><strong>Posted:</strong> 18 Oct 2016 at 12:56pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by ron_whitt</strong></em><br /><br />Dr. Take the dry weight of your pod, add the lb's for propane tank, micro wave etc then add about 800 - 900 lb (min) for clothes, food, tools etc.  Wither you have these in the tt or your tv it doesn't matter you are still pulling/towing that weight.  Don't forget to add people weight also.. See what you come up with and then decide if the Ford escape gives you the towing capacity and safety margins you would be happy with.  Good luck with your podding adventures. <br></td></tr></table><br><br>Ron,<br><br>Thanks for the note of caution.&nbsp; Your post forced me to do a little research.&nbsp; The GCVR for my escape is 7,638lbs.&nbsp; It curb weight is 3645. So there is approximately 4,000 lbs for trailer,cargo, and occupants.&nbsp; I am glad I didn't need to need to worry about subtracting the occupant weights off of the 3500 lb towing limit as it would leave little room for gear.&nbsp; It is also more incentive to lose a bit of weight so we can travel with more gear <img src="https://www.rpod-owners.com/smileys/smiley4.gif" border="0" alt="Big smile" title="Big smile" />.<br>]]>
   <pubDate>Tue, 18 Oct 2016 12:56:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8917&amp;PID=83707#83707</guid>
   <title>Looking at an R-pod purchase in the spring :   Originally posted by birderdiane526Welcome!...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8917&amp;PID=83706#83706</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6198" rel="nofollow">DrSafety</a><br /><strong>Subject:</strong> 8917<br /><strong>Posted:</strong> 18 Oct 2016 at 12:33pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by birderdiane526</strong></em><br /><br />Welcome!  We full-time in a 2016 179 and find the storage adequate.  This lifestyle requires paring down, so we have learned to live with less.  The 179 Floorplan is really comfortable for us.<br><br>Happy trails!</td></tr></table><br><br>Thanks Birder,&nbsp; I am a fellow birder as well.&nbsp; <br><br>Yes we will have to look at how we used to camp and only take the essentials.&nbsp; This is part of our wanting to simply our lifestyle.&nbsp; We was headed down the motorhome route with stars in our eyes.&nbsp; we thought we had finally made a choice when it hit us.&nbsp; Hey is this still camping??&nbsp; Since that time we have refocused on how we can get more out of life by getting by with less.<br><br>I am happy to find this forum as it will be helpful as we get closer to finalizing a purchase and hitting the road.<br>]]>
   <pubDate>Tue, 18 Oct 2016 12:33:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8917&amp;PID=83706#83706</guid>
   <title>Looking at an R-pod purchase in the spring :   Originally posted by StephenHp.s....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8917&amp;PID=83705#83705</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6198" rel="nofollow">DrSafety</a><br /><strong>Subject:</strong> 8917<br /><strong>Posted:</strong> 18 Oct 2016 at 12:27pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by StephenH</strong></em><br /><br /><br>p.s. Don't forget to get a set of towing mirrors. Don't get the cheap ones that just use a rubber strap to attach to the mirror. Get the ones that have the padded tightening ratchet. The cheap ones will rub the paint on the mirrors. I also use plastic wrap like you would use for wrapping things for moving to go around the mirror and then cinch it in the middle with excess material so most of the mirror is visible. The tow mirrors will give you most of your visibility of what is behind you. The Escape's mirrors are not wide enough to see around the R-Pod. In some states, they are required.<br><br>You will be close to the limit. However, the Escape you have should be up to the task. Just remember that you should carefully consider whether what you want to take is really needed or if it will just be excess weight when you pack.<br></td></tr></table><br><br>Stephen - Thanks again for the info.&nbsp; I saw a video on etrailer on the installation of the brake controller as well and it doesn't look too bad as long as you have access.<br><br>I did save a few things from the previous trailer and tow vehicle.&nbsp; One of those was the towing mirrors.&nbsp; They are a good quality with rubber padded points of contact that caused no problems in 4 years of towing in the mirrors of my previous tow vehicle.<br><br>I understand about only taking what is necessary.&nbsp; This vehicle is about paring back and that should follow suit with what we pack for our trip.<br><br>One last question (at least for now)<img src="https://www.rpod-owners.com/smileys/smiley4.gif" border="0" alt="Big smile" title="Big smile" />. Does the 4 way equalizer hitch require a sway bar as well.&nbsp; My previous weight distribution hitch (not sure of the brand - bars with chains) had a friction sway bar as well.&nbsp; The description on etrailer makes it sound like a separate sway bar isn't necessary.<br><br>Great to know this forum is here with plenty of folks like yourself that are willing to help.<br><br>]]>
   <pubDate>Tue, 18 Oct 2016 12:27:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8917&amp;PID=83705#83705</guid>
   <title>Looking at an R-pod purchase in the spring :   I installed it myself. I got...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8917&amp;PID=83688#83688</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 8917<br /><strong>Posted:</strong> 17 Oct 2016 at 10:58pm<br /><br />I installed it myself. I got a couple of ramps at Walmart to raise the back end of the car so I could maneuver under it easier. If you have access to a lift, it would be even easier. It was somewhat time-consuming as I wanted to take my time and do it right and also make sure that the wires were routed in such a way that there would not be problems.<br><br>I did some threading of the main wire that runs front to back under heat shielding and in part through the frame. It was tricky figuring how to bring the wire up along the front-driver's side wheel well and into the engine compartment. You may figure out a better way to do this. The hardest parts were to run the wire through the firewall to connect to the controller and to run the wire to connect to the brake. There is already a cut-out in the carpet and a plug in the firewall. Take advantage of this to run the wires. It will take some fishing around to find the wires as you try to poke them through. I used a straightened coat-hanger to help fish it through.<br><br>There is not much room to work between the seat and dash. Getting the wire tap on and crimped/locked was something that had to pretty much be done by touch. For a 62-year-old, it was not easy. The connections at the back end of the car were simple. Figuring out where and how to attach the bracket for the round connector took a few minutes, but once done, it has worked out well.<br>Edit:<br>p.s. Don't forget to get a set of towing mirrors. Don't get the cheap ones that just use a rubber strap to attach to the mirror. Get the ones that have the padded tightening ratchet. The cheap ones will rub the paint on the mirrors. I also use plastic wrap like you would use for wrapping things for moving to go around the mirror and then cinch it in the middle with excess material so most of the mirror is visible. The tow mirrors will give you most of your visibility of what is behind you. The Escape's mirrors are not wide enough to see around the R-Pod. In some states, they are required.<br><br>You will be close to the limit. However, the Escape you have should be up to the task. Just remember that you should carefully consider whether what you want to take is really needed or if it will just be excess weight when you pack.<br>]]>
   <pubDate>Mon, 17 Oct 2016 22:58:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8917&amp;PID=83688#83688</guid>
   <title>Looking at an R-pod purchase in the spring :   Originally posted by StephenHI...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8917&amp;PID=83686#83686</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6198" rel="nofollow">DrSafety</a><br /><strong>Subject:</strong> 8917<br /><strong>Posted:</strong> 17 Oct 2016 at 10:45pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by StephenH</strong></em><br /><br />I can go beyond theory to experience. I have been towing our 2016 RP-179 with a 2016 Ford Escape SE with 2L Ecoboost engine and factory tow package.<br><br>You will definitely need a Weight Distribution Hitch and Sway Control. I have the Equal-i-zer 4-way stabilization hitch which is what the dealer recommended. It does work well, especially after I added an additional washer for more weight transfer. The dealer had set it up for everything empty. I found that it was inadequate. With the additional washer, the setup seems to be spot-on.<br><br>You will need to add a brake controller. Since the Escape does not come equipped for the 7-terminal round connector, it will need to be added also since a 4-pin connector will not work for the electric brakes. Etrailer is where I purchased mine. Some people use the Tekonsha Prodigy P3 controller, but I chose the Hopkins InSIGHT Flex-Mount controller instead as it allowed me more flexibility in placement of the components. I have the display on top of the dash, the manual control on the part of the lower dash near the radio, and the main control unit on the panel above the hood release. With the controller, an installation kit is needed which includes the wiring needed to get the power and connections from the back of the Escape to the engine compartment and battery. There is a picture of our Escape's installation on the Etrailer site. Look for my name in the photo credits.<br></td></tr></table><div><br></div><div>Stephan Thank you for all the great information. &nbsp;</div><div><br></div><div>I did check out the Insight flex mount brake controller and that definitely seems to be the way to go. &nbsp;I like the compactness and placing it out of they way. My last controller was a Prodigy and it was a knee knocker at times. I was struggling with a place to mount a controller and it looks like the insight will solve that issue.</div><div><br></div><div>Did you install the brake controller yourself. I am pretty handy and not afraid of a project. If you did was it difficult? &nbsp;</div><div><br></div><div>Thanks as well for the tip on the premium gas. &nbsp;Don't know if I would have come up with that either.</div><div><br></div><div>Sounds like you hav had good success towing with the escape. I was just worried we would be pushing the limits. &nbsp;It is the vehicle we have as well and if we go the Rpod route what to make sure we can tow with no issues. Your detailed response definitely gave me confidence in the escape being able to handle the towing. &nbsp;</div><div><br></div><div>Thanks Again&nbsp;</div><div><br></div><div><br></div><div><br></div><div><br></div><div><br></div><div><br></div><div><br></div><div><br></div>]]>
   <pubDate>Mon, 17 Oct 2016 22:45:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8917&amp;PID=83686#83686</guid>
   <title>Looking at an R-pod purchase in the spring : Welcome!  We full-time in a 2016...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8917&amp;PID=83681#83681</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5352" rel="nofollow">birderdiane526</a><br /><strong>Subject:</strong> 8917<br /><strong>Posted:</strong> 17 Oct 2016 at 9:35pm<br /><br />Welcome!  We full-time in a 2016 179 and find the storage adequate.  This lifestyle requires paring down, so we have learned to live with less.  The 179 Floorplan is really comfortable for us.<br /><br />Happy trails! ]]>
   <pubDate>Mon, 17 Oct 2016 21:35:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8917&amp;PID=83681#83681</guid>
   <title>Looking at an R-pod purchase in the spring : I can go beyond theory to experience....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8917&amp;PID=83678#83678</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 8917<br /><strong>Posted:</strong> 17 Oct 2016 at 7:53pm<br /><br />I can go beyond theory to experience. I have been towing our 2016 RP-179 with a 2016 Ford Escape SE with 2L Ecoboost engine and factory tow package.<br><br>You will definitely need a Weight Distribution Hitch and Sway Control. I have the Equal-i-zer 4-way stabilization hitch which is what the dealer recommended. It does work well, especially after I added an additional washer for more weight transfer. The dealer had set it up for everything empty. I found that it was inadequate. With the additional washer, the setup seems to be spot-on.<br><br>You will need to add a brake controller. Since the Escape does not come equipped for the 7-terminal round connector, it will need to be added also since a 4-pin connector will not work for the electric brakes. Etrailer is where I purchased mine. Some people use the Tekonsha Prodigy P3 controller, but I chose the Hopkins InSIGHT Flex-Mount controller instead as it allowed me more flexibility in placement of the components. I have the display on top of the dash, the manual control on the part of the lower dash near the radio, and the main control unit on the panel above the hood release. With the controller, an installation kit is needed which includes the wiring needed to get the power and connections from the back of the Escape to the engine compartment and battery. There is a picture of our Escape's installation on the Etrailer site. Look for my name in the photo credits.<br><br>One other thing you should consider which we have found to be helpful is a wind deflector. I purchased and installed an AeroPlus wind deflector by PurpleLine. Another option is an AeroShield by Icon. It was a little tricky installing the AeroPlus. I fastened it to the rear cross-bar for the roof rack. Ihad to add shims to get it to sit properly as the Escape's roof rack is low-profile. This, together with limiting our top speed to 60 mph has given us adequate mileage. It is much better than on our first trip during which we tried to tow at 65-70 mph. With headwinds, we were getting about 11 mpg. With the AeroPlus and 60 mph top speed, our mileage is about 15 mg.<br><br>The Escape's performance is based on running premium gasoline while towing. This is what Ford recommends. I suspect that regular would work, but there would be more risk of detonation (knocking). Also, the engine can develop more power with premium gasoline. For the generally flat towing in Michigan, you should have no problems at all. For mountain terrain, the boost means that the engine gets the air it needs to perform. We have towed up some significant grades. The most difficult was the climb in Virginia up the the Blue Ridge Parkway on VA 56 through Steel's Tavern up to Montebello. That was steep and twisting, keeping us from building enough speed for the transmission cooler to work effectively. The engine was also getting hot until I remembered the old trick of turning off the AC. That brought the temperatures down sufficiently to complete the climb. Once we got up to the BRP and could build up some speed, we were fine.<br><br>We already had the Escape when we purchased our R-Pod. We had intended to purchase a used Casita, but it turned out to be a scam, so we needed to find something which would work for us. The R-Pod has been a good choice. If I had not already purchased the Escape, I would probably have chosen something with a little more capacity such as a Ford Explorer. Even better would be something like the Jeep Grand Cherokee with the Diesel engine. I like having something that will be economical for the times we are not towing the R-Pod. As it is, we will be towing with our Escape for a while as we can't afford to trade it right now. We have about 10,000 miles of towing with it so far, so I can say that it will work. Whether it will be the correct vehicle for you is something you will have to decide.<br>]]>
   <pubDate>Mon, 17 Oct 2016 19:53:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8917&amp;PID=83678#83678</guid>
   <title>Looking at an R-pod purchase in the spring : Dr. Take the dry weight of your...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8917&amp;PID=83677#83677</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=993" rel="nofollow">ron_whitt</a><br /><strong>Subject:</strong> 8917<br /><strong>Posted:</strong> 17 Oct 2016 at 7:18pm<br /><br />Dr. Take the dry weight of your pod, add the lb's for propane tank, micro wave etc then add about 800 - 900 lb (min) for clothes, food, tools etc.  Wither you have these in the tt or your tv it doesn't matter you are still pulling/towing that weight.  Don't forget to add people weight also.. See what you come up with and then decide if the Ford escape gives you the towing capacity and safety margins you would be happy with.  Good luck with your podding adventures. <br /> ]]>
   <pubDate>Mon, 17 Oct 2016 19:18:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8917&amp;PID=83677#83677</guid>
   <title>Looking at an R-pod purchase in the spring : Welcome to the group!!you should...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8917&amp;PID=83673#83673</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1100" rel="nofollow">Leo B</a><br /><strong>Subject:</strong> 8917<br /><strong>Posted:</strong> 17 Oct 2016 at 12:55pm<br /><br />Welcome to the group!!you should be fine towing with your vehicle.]]>
   <pubDate>Mon, 17 Oct 2016 12:55:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8917&amp;PID=83673#83673</guid>
   <title>Looking at an R-pod purchase in the spring :  We sold our small TT 23&amp;#039;...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8917&amp;PID=83672#83672</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6198" rel="nofollow">DrSafety</a><br /><strong>Subject:</strong> 8917<br /><strong>Posted:</strong> 17 Oct 2016 at 12:33pm<br /><br />We sold our small TT 23' and previous tow vehicle last year but miss camping.&nbsp; We are intrigued by the R-pod and looking at a purchase of a 180 in the spring.&nbsp; How do you like the R-pod to you feel there is enough space storage and living?<br><br>I am most interested in your opinion of a 2016 ford escape (2.0l ecoboost) with towing package 3500 lb limit, as a tow vehicle.&nbsp; We will be mostly taking local short less than 5 hour trips within Michigan.&nbsp; However, we have also looked at taking a longer trip out West and more mountainous terrain.&nbsp; Will the Escape make it as TV for that trip? I know I need a Weight distribution hitch, brake controller added.&nbsp; Is there anything else?<br><br>Thanks in advance for your assistance<br>]]>
   <pubDate>Mon, 17 Oct 2016 12:33:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8917&amp;PID=83672#83672</guid>
