  <title>R-pod Owners Forum : Solar Panel</title>
  <link>http://www.rpod-owners.com/</link>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Solar Panel</description>
  <pubDate>Wed, 29 Apr 2026 21:15:43 +0000</pubDate>
  <lastBuildDate>Thu, 13 Oct 2016 07:37:12 +0000</lastBuildDate>
  <WebWizForums:feedURL>www.rpod-owners.com/RSS_post_feed.asp?TID=8880</WebWizForums:feedURL>
   <url>http://www.rpod-owners.com/forum_images/web_wiz_forums.png</url>
   <title>Solar Panel : Thank you so much. This is a very...</title>
   <link>http://www.rpod-owners.com/forum_posts.asp?TID=8880&amp;PID=83503#83503</link>
    <![CDATA[<strong>Author:</strong> <a href="http://www.rpod-owners.com/member_profile.asp?PF=6158" rel="nofollow">Chuckfsc</a><br /><strong>Subject:</strong> 8880<br /><strong>Posted:</strong> 13 Oct 2016 at 7:37am<br /><br />Thank you so much. This is a very nice installation. Great job]]>
   <pubDate>Thu, 13 Oct 2016 07:37:12 +0000</pubDate>
   <guid isPermaLink="true">http://www.rpod-owners.com/forum_posts.asp?TID=8880&amp;PID=83503#83503</guid>
   <title>Solar Panel : We used the one that combine a...</title>
   <link>http://www.rpod-owners.com/forum_posts.asp?TID=8880&amp;PID=83470#83470</link>
    <![CDATA[<strong>Author:</strong> <a href="http://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 8880<br /><strong>Posted:</strong> 12 Oct 2016 at 1:25pm<br /><br />We used the one that combine a outlet, with two USB charge ports. Have one on the end of the dinette, and one next to the bed.<br><br><img src="http://i174.photobucket.com/albums/w88/maypo59/R-Pod/20151222_144458_zpsfqdmbiq5.jpg" border="0" /><br><br><img src="http://i174.photobucket.com/albums/w88/maypo59/R-Pod/20151222_144452_zps1h3nsbwl.jpg" border="0" /><br><br>]]>
   <pubDate>Wed, 12 Oct 2016 13:25:42 +0000</pubDate>
   <guid isPermaLink="true">http://www.rpod-owners.com/forum_posts.asp?TID=8880&amp;PID=83470#83470</guid>
   <title>Solar Panel : I installed the plugs. One plug...</title>
   <link>http://www.rpod-owners.com/forum_posts.asp?TID=8880&amp;PID=83467#83467</link>
    <![CDATA[<strong>Author:</strong> <a href="http://www.rpod-owners.com/member_profile.asp?PF=4133" rel="nofollow">sailor323</a><br /><strong>Subject:</strong> 8880<br /><strong>Posted:</strong> 12 Oct 2016 at 12:07pm<br /><br /><img src="uploads/4133/2016-10-12_10.31.59_640x360.jpg" height="360" width="640" border="0" /><img src="uploads/4133/2016-10-12_10.32.35_640x360.jpg" height="360" width="640" border="0" />I installed the plugs.&nbsp; One plug is on the front of the galley cabinet below the sink, another is on the right side of the galley cabinet.&nbsp; A third plug, along with USB plug is next to the 120V outlet below the bed.&nbsp; The last one is below the 120V plug on the outside.&nbsp; I ran a new circuit for the plugs from the distribution panel.<br><img src="uploads/4133/2016-10-12_10.30.18_640x360.jpg" height="360" width="640" border="0" /><br>]]>
   <pubDate>Wed, 12 Oct 2016 12:07:30 +0000</pubDate>
   <guid isPermaLink="true">http://www.rpod-owners.com/forum_posts.asp?TID=8880&amp;PID=83467#83467</guid>
   <title>Solar Panel : Thank you . You mentioned the...</title>
   <link>http://www.rpod-owners.com/forum_posts.asp?TID=8880&amp;PID=83457#83457</link>
    <![CDATA[<strong>Author:</strong> <a href="http://www.rpod-owners.com/member_profile.asp?PF=6158" rel="nofollow">Chuckfsc</a><br /><strong>Subject:</strong> 8880<br /><strong>Posted:</strong> 11 Oct 2016 at 10:23pm<br /><br />Thank you . You mentioned the 12 V outlets. Did you install them or the dealer? Can you also send me pictures of their locations within the RPod ?<div>Thanks</div><div>Chuck</div>]]>
   <pubDate>Tue, 11 Oct 2016 22:23:31 +0000</pubDate>
   <guid isPermaLink="true">http://www.rpod-owners.com/forum_posts.asp?TID=8880&amp;PID=83457#83457</guid>
   <title>Solar Panel : Good guidance/advice from sailor...</title>
   <link>http://www.rpod-owners.com/forum_posts.asp?TID=8880&amp;PID=83339#83339</link>
    <![CDATA[<strong>Author:</strong> <a href="http://www.rpod-owners.com/member_profile.asp?PF=4247" rel="nofollow">Don Halas</a><br /><strong>Subject:</strong> 8880<br /><strong>Posted:</strong> 09 Oct 2016 at 11:47am<br /><br />Good guidance/advice from sailor 323.<div><br></div>]]>
   <pubDate>Sun, 09 Oct 2016 11:47:48 +0000</pubDate>
   <guid isPermaLink="true">http://www.rpod-owners.com/forum_posts.asp?TID=8880&amp;PID=83339#83339</guid>
   <title>Solar Panel : I did not mount the inverter....</title>
   <link>http://www.rpod-owners.com/forum_posts.asp?TID=8880&amp;PID=83333#83333</link>
    <![CDATA[<strong>Author:</strong> <a href="http://www.rpod-owners.com/member_profile.asp?PF=4133" rel="nofollow">sailor323</a><br /><strong>Subject:</strong> 8880<br /><strong>Posted:</strong> 09 Oct 2016 at 7:51am<br /><br />I did not mount the inverter.&nbsp; We have several 12V outlets around the pod.&nbsp; We plug the inverter in whenever we need it--mostly for the coffee grinder or small food processor when we are boondocking.&nbsp; <br>]]>
   <pubDate>Sun, 09 Oct 2016 07:51:43 +0000</pubDate>
   <guid isPermaLink="true">http://www.rpod-owners.com/forum_posts.asp?TID=8880&amp;PID=83333#83333</guid>
   <title>Solar Panel : Thanks for the info. How did you...</title>
   <link>http://www.rpod-owners.com/forum_posts.asp?TID=8880&amp;PID=83326#83326</link>
    <![CDATA[<strong>Author:</strong> <a href="http://www.rpod-owners.com/member_profile.asp?PF=6158" rel="nofollow">Chuckfsc</a><br /><strong>Subject:</strong> 8880<br /><strong>Posted:</strong> 08 Oct 2016 at 8:14pm<br /><br />Thanks for the info. How did you mount your inverter in the RPod and run the wires?]]>
   <pubDate>Sat, 08 Oct 2016 20:14:50 +0000</pubDate>
   <guid isPermaLink="true">http://www.rpod-owners.com/forum_posts.asp?TID=8880&amp;PID=83326#83326</guid>
   <title>Solar Panel : Yes, I do have a small 300 watt...</title>
   <link>http://www.rpod-owners.com/forum_posts.asp?TID=8880&amp;PID=83271#83271</link>
    <![CDATA[<strong>Author:</strong> <a href="http://www.rpod-owners.com/member_profile.asp?PF=4133" rel="nofollow">sailor323</a><br /><strong>Subject:</strong> 8880<br /><strong>Posted:</strong> 07 Oct 2016 at 9:45pm<br /><br />Yes, I do have a small 300 watt inverter for running small appliances like a coffee grinder.&nbsp; I do not use it to charge cell phones,laptops or tablets.&nbsp; I have a 12V brick for the laptop and cigarette lighter plugs for tablets and cell phones.&nbsp; we don't watch TV or DVD, but could do so without an inverter. Inverters are a kind of waste of energy when you can simply go DC to DC<br>]]>
   <pubDate>Fri, 07 Oct 2016 21:45:28 +0000</pubDate>
   <guid isPermaLink="true">http://www.rpod-owners.com/forum_posts.asp?TID=8880&amp;PID=83271#83271</guid>
   <title>Solar Panel : Thanks for the clarification....</title>
   <link>http://www.rpod-owners.com/forum_posts.asp?TID=8880&amp;PID=83266#83266</link>
    <![CDATA[<strong>Author:</strong> <a href="http://www.rpod-owners.com/member_profile.asp?PF=6158" rel="nofollow">Chuckfsc</a><br /><strong>Subject:</strong> 8880<br /><strong>Posted:</strong> 07 Oct 2016 at 8:04pm<br /><br />Thanks for the clarification. Do you have a inverter installed on yours for the ability to watch TV or a DVD, or to charge your cell phone or IPad on your batteries with the solar panel charging them?<div><br></div>]]>
   <pubDate>Fri, 07 Oct 2016 20:04:38 +0000</pubDate>
   <guid isPermaLink="true">http://www.rpod-owners.com/forum_posts.asp?TID=8880&amp;PID=83266#83266</guid>
   <title>Solar Panel : No, the pod does not come with...</title>
   <link>http://www.rpod-owners.com/forum_posts.asp?TID=8880&amp;PID=83259#83259</link>
    <![CDATA[<strong>Author:</strong> <a href="http://www.rpod-owners.com/member_profile.asp?PF=4133" rel="nofollow">sailor323</a><br /><strong>Subject:</strong> 8880<br /><strong>Posted:</strong> 07 Oct 2016 at 4:44pm<br /><br />No, the pod does not come with an inverter.&nbsp; Many people incorrectly refer to the converter as an inverter.&nbsp; The converter changes 120V AC to 12V DC in order to charge the battery.&nbsp; An inverter does the opposite, it changes battery power to 120V AC.&nbsp; As for a solar panel, you should go with at least 100 watts.&nbsp; You will also need a charge controller.&nbsp; Some solar kits come with a controller.&nbsp; We do love our solar set up.&nbsp; We can camp off grid indefinitely.&nbsp; Our only limitations are water and waste.<br>]]>
   <pubDate>Fri, 07 Oct 2016 16:44:36 +0000</pubDate>
   <guid isPermaLink="true">http://www.rpod-owners.com/forum_posts.asp?TID=8880&amp;PID=83259#83259</guid>
   <title>Solar Panel : Does this mean when you order...</title>
   <link>http://www.rpod-owners.com/forum_posts.asp?TID=8880&amp;PID=83258#83258</link>
    <![CDATA[<strong>Author:</strong> <a href="http://www.rpod-owners.com/member_profile.asp?PF=6158" rel="nofollow">Chuckfsc</a><br /><strong>Subject:</strong> 8880<br /><strong>Posted:</strong> 07 Oct 2016 at 3:32pm<br /><br />Does this mean when you order any RPod with a solar panel it comes with an inverter?]]>
   <pubDate>Fri, 07 Oct 2016 15:32:21 +0000</pubDate>
   <guid isPermaLink="true">http://www.rpod-owners.com/forum_posts.asp?TID=8880&amp;PID=83258#83258</guid>
   <title>Solar Panel : We purchased a 2017 rpod 178 in...</title>
   <link>http://www.rpod-owners.com/forum_posts.asp?TID=8880&amp;PID=83254#83254</link>
    <![CDATA[<strong>Author:</strong> <a href="http://www.rpod-owners.com/member_profile.asp?PF=5490" rel="nofollow">will910</a><br /><strong>Subject:</strong> 8880<br /><strong>Posted:</strong> 07 Oct 2016 at 2:33pm<br /><br /><p style="margin-bottom: 0in">We purchased a 2017 rpod 178 in June Iwould like to add a solar panel The 178 come with </p><p style="margin-bottom: 0in">Go Power ,solar on the side connector.The 178 already wired in invertor. What panel would work </p><p style="margin-bottom: 0in">Best for the Rpod . P. S don't needcharge controller</p><p style="margin-bottom: 0in"><img src="http://www.rpod-owners.com/smileys/smiley1.gif" border="0" alt="Smile" title="Smile" />&nbsp;Thanks Bill<br></p>]]>
   <pubDate>Fri, 07 Oct 2016 14:33:23 +0000</pubDate>
   <guid isPermaLink="true">http://www.rpod-owners.com/forum_posts.asp?TID=8880&amp;PID=83254#83254</guid>
