  <title>R-pod Owners Forum : Oil Droplets In RP179 Kitchen Cabinet</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Oil Droplets In RP179 Kitchen Cabinet</description>
  <pubDate>Thu, 29 Oct 2026 12:02:44 +0000</pubDate>
  <lastBuildDate>Sun, 25 Sep 2016 14:44:12 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=8830</WebWizForums:feedURL>
   <title>Oil Droplets In RP179 Kitchen Cabinet : Makes sense, water is hygroscopic....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8830&amp;PID=82786#82786</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 8830<br /><strong>Posted:</strong> 25 Sep 2016 at 2:44pm<br /><br />Makes sense, water is hygroscopic.]]>
   <pubDate>Sun, 25 Sep 2016 14:44:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8830&amp;PID=82786#82786</guid>
   <title>Oil Droplets In RP179 Kitchen Cabinet : Thanks Osage for thinking about...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8830&amp;PID=82782#82782</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5822" rel="nofollow">Woodchuck</a><br /><strong>Subject:</strong> 8830<br /><strong>Posted:</strong> 25 Sep 2016 at 2:26pm<br /><br />Thanks Osage for thinking about my question. &nbsp;I believe that I have found out what it is that I am seeing. &nbsp;Salt. &nbsp;We have had the salt shaker in the drawers fall over while traveling. &nbsp;I believe that the scattered salt changed into a kind of liquid in a high humidity situation. &nbsp;"When it rains it pours"??]]>
   <pubDate>Sun, 25 Sep 2016 14:26:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8830&amp;PID=82782#82782</guid>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8830&amp;PID=82780#82780</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5822" rel="nofollow">Woodchuck</a><br /><strong>Subject:</strong> 8830<br /><strong>Posted:</strong> 25 Sep 2016 at 2:18pm<br /><br />Thanks Osage for thinking about my question. &nbsp;I believe that I have found out what it is that I am seeing. &nbsp;Salt. &nbsp;We have had the salt shaker in the drawers fall over while traveling. &nbsp;I believe that the scattered salt changed into a kind of liquid in a high humidity situation. &nbsp;"When it rains it pours"??]]>
   <pubDate>Sun, 25 Sep 2016 14:18:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8830&amp;PID=82780#82780</guid>
   <title>Oil Droplets In RP179 Kitchen Cabinet : could it be that someone lube...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8830&amp;PID=82765#82765</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5077" rel="nofollow">osage</a><br /><strong>Subject:</strong> 8830<br /><strong>Posted:</strong> 25 Sep 2016 at 9:46am<br /><br />could it be that someone lube the drawer slides at sometime&nbsp;]]>
   <pubDate>Sun, 25 Sep 2016 09:46:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8830&amp;PID=82765#82765</guid>
   <title>Oil Droplets In RP179 Kitchen Cabinet : Today I was completing a Mod to...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8830&amp;PID=82758#82758</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5822" rel="nofollow">Woodchuck</a><br /><strong>Subject:</strong> 8830<br /><strong>Posted:</strong> 24 Sep 2016 at 10:07pm<br /><br />Today I was completing a Mod to install the recessed two burner gas stove insert in my 179. &nbsp;While cleaning I found what I first thought to be water in the drawers next to the cabinet I was working in. &nbsp;While looking for a source I discovered that this was really small droplets of an oil material. &nbsp;Very small drops like it had been sprayed. &nbsp;These drawers are located under the kitchen sink and the spray was both in the two lower drawers and on the floor under the lowest drawer. &nbsp; The vent piping on the sink has (what I will call a dry cap) on the vent piping.<div><br></div><div>Does anyone have any thoughts on this situation? &nbsp;Any idea how this vent works and could it be the source of the spray?</div><div><br></div><div>Jeff Sundberg</div>]]>
   <pubDate>Sat, 24 Sep 2016 22:07:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8830&amp;PID=82758#82758</guid>
