  <title>R-pod Owners Forum : Trailer beeping</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Reviews and General Information : Trailer beeping</description>
  <pubDate>Sat, 24 Oct 2026 10:53:55 +0000</pubDate>
  <lastBuildDate>Sun, 18 Sep 2016 16:51:10 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=8805</WebWizForums:feedURL>
   <title>Trailer beeping :   Even better have them plug...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8805&amp;PID=82471#82471</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 8805<br /><strong>Posted:</strong> 18 Sep 2016 at 4:51pm<br /><br /><div>Even better have them plug the pod in, if it isn't currently. &nbsp;Leaving the battery discharged isn't good for it.</div>]]>
   <pubDate>Sun, 18 Sep 2016 16:51:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8805&amp;PID=82471#82471</guid>
   <title>Trailer beeping : Ok will do thanks </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8805&amp;PID=82450#82450</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5925" rel="nofollow">CYQX Discovery</a><br /><strong>Subject:</strong> 8805<br /><strong>Posted:</strong> 17 Sep 2016 at 8:11pm<br /><br />Ok will do thanks]]>
   <pubDate>Sat, 17 Sep 2016 20:11:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8805&amp;PID=82450#82450</guid>
   <title>Trailer beeping : The most probable is the propane/CO...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8805&amp;PID=82448#82448</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1573" rel="nofollow">CharlieM</a><br /><strong>Subject:</strong> 8805<br /><strong>Posted:</strong> 17 Sep 2016 at 7:56pm<br /><br /><font size="3">The most probable is the propane/CO detector. It will beep if the main battery is low and the battery will discharge if left unplugged. It could also be the fridge, which has a number of causes for beeping. Your best bet is to have the local person disconnect one of the battery terminals if they can. You can deal with the problem when you get home.&nbsp;</font>]]>
   <pubDate>Sat, 17 Sep 2016 19:56:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8805&amp;PID=82448#82448</guid>
   <title>Trailer beeping : On holidays (flew, so we couldn&amp;#039;t...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8805&amp;PID=82446#82446</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5925" rel="nofollow">CYQX Discovery</a><br /><strong>Subject:</strong> 8805<br /><strong>Posted:</strong> 17 Sep 2016 at 7:34pm<br /><br />On holidays (flew, so we couldn't take the pod) and the person staying at our place says our pod is beeping. I only picked it up a week ago&nbsp;&nbsp;&nbsp;Is it something I should be concerned about?<br /><br /><br />It's not the smoke detector but that's what it sounds like<br /><br />Thanks]]>
   <pubDate>Sat, 17 Sep 2016 19:34:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8805&amp;PID=82446#82446</guid>
