  <title>R-pod Owners Forum : 2011 r-pod 177</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : 2011 r-pod 177</description>
  <pubDate>Thu, 29 Oct 2026 13:34:04 +0000</pubDate>
  <lastBuildDate>Tue, 23 Aug 2016 16:52:15 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=8623</WebWizForums:feedURL>
   <title>2011 r-pod 177 :   Originally posted by jatoWe...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8623&amp;PID=80996#80996</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=807" rel="nofollow">Keith-N-Dar</a><br /><strong>Subject:</strong> 8623<br /><strong>Posted:</strong> 23 Aug 2016 at 4:52pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by jato</strong></em><br /><br />We have the same model 177 and year 2011.&nbsp; As furpod noted, "why?"&nbsp; Just dump the black water first (in front of the axle) and then the gray water (behind the axle) and this will help clean your hose a bit before cleaning it at the dump station with the water provided.&nbsp; Not a big deal. &nbsp;</td></tr></table><br><br>+1&nbsp; Couldn't be easier.<br>]]>
   <pubDate>Tue, 23 Aug 2016 16:52:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8623&amp;PID=80996#80996</guid>
   <title>2011 r-pod 177 : Thanks! All this input based on...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8623&amp;PID=80934#80934</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5941" rel="nofollow">Rebecca Dees</a><br /><strong>Subject:</strong> 8623<br /><strong>Posted:</strong> 22 Aug 2016 at 8:12pm<br /><br />Thanks! All this input based on experience is very helpful. Appreciate this group.]]>
   <pubDate>Mon, 22 Aug 2016 20:12:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8623&amp;PID=80934#80934</guid>
   <title>2011 r-pod 177 : We have the same model 177 and...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8623&amp;PID=80933#80933</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 8623<br /><strong>Posted:</strong> 22 Aug 2016 at 8:10pm<br /><br />We have the same model 177 and year 2011.&nbsp; As furpod noted, "why?"&nbsp; Just dump the black water first (in front of the axle) and then the gray water (behind the axle) and this will help clean your hose a bit before cleaning it at the dump station with the water provided.&nbsp; Not a big deal. &nbsp;]]>
   <pubDate>Mon, 22 Aug 2016 20:10:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8623&amp;PID=80933#80933</guid>
   <title>2011 r-pod 177 :   Originally posted by Rebecca...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8623&amp;PID=80886#80886</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 8623<br /><strong>Posted:</strong> 22 Aug 2016 at 8:53am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Rebecca Dees</strong></em><br /><br />Thanks. It doesn't look hard at all. I'm going to see what comes with my r-pod and then decide if I want to order the Sewer Solution system I saw on YouTube. It looks like it works really well. If you haven't seen it YouTube has a good video.</td></tr></table><br><br>Unless you have a specific need for that.. why? poop runs downhill. Hooking that up and running it at a dump station is not going to be fun, or quick. <br>]]>
   <pubDate>Mon, 22 Aug 2016 08:53:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8623&amp;PID=80886#80886</guid>
   <title>2011 r-pod 177 : Thanks. It doesn&amp;#039;t look hard...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8623&amp;PID=80875#80875</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5941" rel="nofollow">Rebecca Dees</a><br /><strong>Subject:</strong> 8623<br /><strong>Posted:</strong> 21 Aug 2016 at 11:19pm<br /><br />Thanks. It doesn't look hard at all. I'm going to see what comes with my r-pod and then decide if I want to order the Sewer Solution system I saw on YouTube. It looks like it works really well. If you haven't seen it YouTube has a good video.]]>
   <pubDate>Sun, 21 Aug 2016 23:19:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8623&amp;PID=80875#80875</guid>
   <title>2011 r-pod 177 : Yep, split dumps are not a issue...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8623&amp;PID=80872#80872</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3238" rel="nofollow">Podster</a><br /><strong>Subject:</strong> 8623<br /><strong>Posted:</strong> 21 Aug 2016 at 10:33pm<br /><br />Yep, split dumps are not a issue here. Takes like 5 seconds to remove and re-attach.&nbsp;]]>
   <pubDate>Sun, 21 Aug 2016 22:33:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8623&amp;PID=80872#80872</guid>
   <title>2011 r-pod 177 : Thanks. I&amp;#039;ve been watching...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8623&amp;PID=80863#80863</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5941" rel="nofollow">Rebecca Dees</a><br /><strong>Subject:</strong> 8623<br /><strong>Posted:</strong> 21 Aug 2016 at 8:54pm<br /><br />Thanks. I've been watching YouTube videos and it never occurred to me that the outlets were separate.]]>
   <pubDate>Sun, 21 Aug 2016 20:54:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8623&amp;PID=80863#80863</guid>
   <title>2011 r-pod 177 : Separate.It&amp;#039;s no big deal...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8623&amp;PID=80861#80861</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 8623<br /><strong>Posted:</strong> 21 Aug 2016 at 8:52pm<br /><br />Separate.It's no big deal either way.<br>]]>
   <pubDate>Sun, 21 Aug 2016 20:52:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8623&amp;PID=80861#80861</guid>
   <title>2011 r-pod 177 : I haven&amp;#039;t picked up my r-pod...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8623&amp;PID=80859#80859</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5941" rel="nofollow">Rebecca Dees</a><br /><strong>Subject:</strong> 8623<br /><strong>Posted:</strong> 21 Aug 2016 at 8:09pm<br /><br />I haven't picked up my r-pod yet and I've been reading about the black and grey water outlets. Does anyone have this model and if so are the outlets separate(2 different outlets)or is there one outlet used to drain both black and grey water? Thanks.]]>
   <pubDate>Sun, 21 Aug 2016 20:09:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8623&amp;PID=80859#80859</guid>
