  <title>R-pod Owners Forum : Dehumidifiers</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Wish List : Dehumidifiers</description>
  <pubDate>Fri, 23 Oct 2026 05:34:26 +0000</pubDate>
  <lastBuildDate>Tue, 06 Nov 2018 23:15:38 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=8515</WebWizForums:feedURL>
   <title>Dehumidifiers : Thank you all! I just ordered...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8515&amp;PID=117884#117884</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8929" rel="nofollow">BoulderGal</a><br /><strong>Subject:</strong> 8515<br /><strong>Posted:</strong> 06 Nov 2018 at 11:15pm<br /><br />Thank you all! &nbsp;I just ordered one I hope solves the problem. &nbsp;Gotta love Amazon Prime!]]>
   <pubDate>Tue, 06 Nov 2018 23:15:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8515&amp;PID=117884#117884</guid>
   <title>Dehumidifiers : A lot of dehumidifiers have a...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8515&amp;PID=80240#80240</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5860" rel="nofollow">kcecc54</a><br /><strong>Subject:</strong> 8515<br /><strong>Posted:</strong> 08 Aug 2016 at 6:24pm<br /><br />A lot of dehumidifiers have a "continuous" operations mode that allows you to add a hose that runs to a drain and bypasses the internal tank.  I use one for my basement and I have an extra one that I use in our recently purchased R-Pod 171.&nbsp;&nbsp;&nbsp;You only need a small capacity unit since the air volume in your unit is so low.  My "extra" unit is a 5 quart capacity unit and it's overkill in a big way.  Both of my units are Frigidaire and you just set the % humidity that you want to stay under and the unit will turn off and on as needed.  You definitely want to set it under 70% (over 70% is sure fire habitat for mold).  I set mine around 45-50%.  That's a good compromise setting - doesn't run too much and I don't have to worry about the variation in humidity throughout the R-Pod.  Good luck! ]]>
   <pubDate>Mon, 08 Aug 2016 18:24:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8515&amp;PID=80240#80240</guid>
   <title>Dehumidifiers : We got this one to use in the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8515&amp;PID=80089#80089</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2642" rel="nofollow">JandL</a><br /><strong>Subject:</strong> 8515<br /><strong>Posted:</strong> 05 Aug 2016 at 8:36pm<br /><br />We got this one to use in the house in the winter and if there is a big rain storm I put in the trailer for 1/2 day and there is no condensation at all. We picked one up from Amazon Warehouse deals, $180 new $156 thru Warehouse Deals. It has a hose port if you don't want to dump the tank<br /><br />https://www.amazon.com/Frigidaire-FAD504DWD-Energy-50-pint-Dehumidifier/dp/B00AU7GYXA/ref=sr_1_2?s=home-garden&ie=UTF8&qid=1470443515&sr=1-2&keywords=dehumidifier]]>
   <pubDate>Fri, 05 Aug 2016 20:36:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8515&amp;PID=80089#80089</guid>
   <title>Dehumidifiers : Iv&amp;#039;e been using one of these...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8515&amp;PID=80026#80026</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3238" rel="nofollow">Podster</a><br /><strong>Subject:</strong> 8515<br /><strong>Posted:</strong> 04 Aug 2016 at 9:54am<br /><br />Iv'e been using one of these and it works pretty good. It's renewable. In Florida, you may need a couple of them.&nbsp;<div><br></div><div><p ="Ms&#111;normal"><a href="https://www.amaz&#111;n.com/s/ref=nb_sb_ss_c_1_12/157-4559602-6504344?url=search-alias%3Daps&amp;field-keywords=renewable+dehumidifier&amp;sprefix=renewable+de%2Caps%2C154" target="_blank">https://www.amazon.com/s/ref=nb_sb_ss_c_1_12/157-4559602-6504344?url=search-alias%3Daps&amp;field-keywords=renewable+dehumidifier&amp;sprefix=renewable+de%2Caps%2C154</a><o:p></o:p></p></div>]]>
   <pubDate>Thu, 04 Aug 2016 09:54:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8515&amp;PID=80026#80026</guid>
   <title>Dehumidifiers : In an effort to eliminate atmospheric...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8515&amp;PID=80018#80018</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1464" rel="nofollow">coopercdrkey</a><br /><strong>Subject:</strong> 8515<br /><strong>Posted:</strong> 04 Aug 2016 at 8:07am<br /><br />In an effort to eliminate atmospheric moisture from the 'Pod, (and the mold / mildew that often results), we have been using the <i>DampRid</i>&nbsp;line of products. &nbsp;They seem to work as advertised, but here in North Central (Gulf Coast) Florida, we go through a fair number of them between outings.<div><br></div><div>I have been searching for a small, reasonably priced dehumidifier with a drain outlet instead of, (or in addition to) the collection cup that is typical in this class of products. &nbsp;I figure that the outlet hose could be positioned to drain into the sink and have the collected moisture drain into the gray tank. &nbsp;(If ever there was more than 30 gal. collected we would have other problems to deal with!)</div><div><br></div><div>Any experience or recommendations would be very welcome! &nbsp;<img src="https://www.rpod-owners.com/smileys/smiley1.gif" border="0" alt="Smile" title="Smile" /></div><div><br></div><div><br></div>]]>
   <pubDate>Thu, 04 Aug 2016 08:07:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8515&amp;PID=80018#80018</guid>
