  <title>R-pod Owners Forum : R Pod ride height</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Reviews and General Information : R Pod ride height</description>
  <pubDate>Sat, 24 Oct 2026 10:52:14 +0000</pubDate>
  <lastBuildDate>Fri, 29 Jul 2016 07:14:18 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=8383</WebWizForums:feedURL>
   <title>R Pod ride height : So with the trailer loaded for...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8383&amp;PID=79693#79693</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5656" rel="nofollow">ragadas</a><br /><strong>Subject:</strong> 8383<br /><strong>Posted:</strong> 29 Jul 2016 at 7:14am<br /><br />So with the trailer loaded for camping but dry, I put a 4' level from the AC to a tape alongside the R pod and came up with a height of 9' 4.5".<br />My wife called the campground and found out that even they state the clearance is 10' it's actually only 9'7".<br />We'll still watch on the way through!]]>
   <pubDate>Fri, 29 Jul 2016 07:14:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8383&amp;PID=79693#79693</guid>
   <title>R Pod ride height : Good luck, let us know how you...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8383&amp;PID=79030#79030</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1100" rel="nofollow">Leo B</a><br /><strong>Subject:</strong> 8383<br /><strong>Posted:</strong> 15 Jul 2016 at 8:40am<br /><br />Good luck, let us know how you fare.]]>
   <pubDate>Fri, 15 Jul 2016 08:40:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8383&amp;PID=79030#79030</guid>
   <title>R Pod ride height : Thanks folks. I guess I need to...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8383&amp;PID=79025#79025</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5656" rel="nofollow">ragadas</a><br /><strong>Subject:</strong> 8383<br /><strong>Posted:</strong> 15 Jul 2016 at 7:30am<br /><br />Thanks folks. I guess I need to hook up to the TV and see what the actual measurement is to the AC unit.]]>
   <pubDate>Fri, 15 Jul 2016 07:30:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8383&amp;PID=79025#79025</guid>
   <title>R Pod ride height : If it comes to it, you could temporarily...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8383&amp;PID=78981#78981</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 8383<br /><strong>Posted:</strong> 14 Jul 2016 at 11:26am<br /><br />If it comes to it, you could temporarily let some air out of the tires on one side of the obstruction and then reinflate them on the other side. You would not want to deflate them all the way, just enough to lower the height by an inch or two.]]>
   <pubDate>Thu, 14 Jul 2016 11:26:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8383&amp;PID=78981#78981</guid>
   <title>R Pod ride height :  Yes, the Dexter axles work the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8383&amp;PID=78980#78980</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1573" rel="nofollow">CharlieM</a><br /><strong>Subject:</strong> 8383<br /><strong>Posted:</strong> 14 Jul 2016 at 11:23am<br /><br /><font size="3">Yes, the Dexter axles work the same as springs in that regard. HOWEVER, I'd sure have someone get out and watch as I drove under a 10' obstruction. So much depends on ground level, shape, speed, angle, etc.&nbsp;</font>]]>
   <pubDate>Thu, 14 Jul 2016 11:23:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8383&amp;PID=78980#78980</guid>
   <title>R Pod ride height : Given the torsion suspension system...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8383&amp;PID=78963#78963</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5656" rel="nofollow">ragadas</a><br /><strong>Subject:</strong> 8383<br /><strong>Posted:</strong> 14 Jul 2016 at 9:38am<br /><br />Given the torsion suspension system on the 179, does loading the trailer with gear cause it to "squat" as a spring suspension would?<br />My wife and I would like to visit a nearby campground, but the facility warns of an overpass on the entry road with a 10' clearance. <br />With the claimed stock height of 9'7" and four inch risers...that doesn't leave much room for error.]]>
   <pubDate>Thu, 14 Jul 2016 09:38:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8383&amp;PID=78963#78963</guid>
