  <title>R-pod Owners Forum : Honda Pilot TV</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Honda Pilot TV</description>
  <pubDate>Thu, 29 Oct 2026 14:27:20 +0000</pubDate>
  <lastBuildDate>Tue, 12 Jul 2016 09:17:00 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=8310</WebWizForums:feedURL>
   <title>Honda Pilot TV : We&amp;#039;ve been towing our 176T...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8310&amp;PID=78857#78857</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1816" rel="nofollow">HappyCampers</a><br /><strong>Subject:</strong> 8310<br /><strong>Posted:</strong> 12 Jul 2016 at 9:17am<br /><br />We've been towing our 176T with a 2005 4WD Pilot with tow package for 3 summers, works well for us. &nbsp;No big mountains, though, so we don't have any information for you about that.]]>
   <pubDate>Tue, 12 Jul 2016 09:17:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8310&amp;PID=78857#78857</guid>
   <title>Honda Pilot TV : For comparison on your mountain...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8310&amp;PID=78438#78438</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2486" rel="nofollow">COSPod</a><br /><strong>Subject:</strong> 8310<br /><strong>Posted:</strong> 05 Jul 2016 at 11:30am<br /><br />For comparison on your mountain pass speeds, I tow with a '12 Tahoe, and 172, which i think is the lightest Rpod as mentioned, and I still struggle to get up to 65 (or 55.. sometimes even 45) on the big passes out here. Vail eastbound and Monarch are a couple of the more brutal ones I've had the pleasure of towing up, they are just looooonnnngggg and pushing up over 10/11k pretty much sucks the power out of anything (particularly w/o a Turbo).<div><br></div><div>If you were east or west at lower elevations I think the Pilot would be ok, but out here given the base elevation is 5-6k, and up from there, I'd expect it'll make for some very slow and stressful towing, in particular on I-70 out of Denver... that's a painful drive even w/o towing.&nbsp;</div><div><br></div><div><br><div><br></div><div><div><br></div></div></div>]]>
   <pubDate>Tue, 05 Jul 2016 11:30:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8310&amp;PID=78438#78438</guid>
   <title>Honda Pilot TV : We have a 2007 pilot (4WD) and...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8310&amp;PID=78437#78437</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1037" rel="nofollow">podsuperior</a><br /><strong>Subject:</strong> 8310<br /><strong>Posted:</strong> 05 Jul 2016 at 10:25am<br /><br />We have a 2007 pilot (4WD) and a 177 - it is fine for us for local trips - going 55 - 60 MPH.<br><br>Mountains, I think would be a challenge for it.<br><br>It works for us - but when we can afford it - we will get a new TV with a higher towing capacity.<br>]]>
   <pubDate>Tue, 05 Jul 2016 10:25:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8310&amp;PID=78437#78437</guid>
   <title>Honda Pilot TV : I&amp;#039;m wondering what is involved...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8310&amp;PID=78381#78381</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1573" rel="nofollow">CharlieM</a><br /><strong>Subject:</strong> 8310<br /><strong>Posted:</strong> 04 Jul 2016 at 9:58am<br /><br /><font size="3">I'm wondering what is involved with the tow package you're considering for the Pilot. My 4WD 2010 Pilot came stock with the transmission cooler, hitch, and HD alternator. The only thing Honda left off was the short cable and 7 pin Bargman connector. If you present Pilot is not 4WD I'd reconsider. <br><br>Do the math on the differential and gear ratios for the Pilot and Jeep. Honda has a 4.375 differential which is pretty high for SUVs. They compensate with transmission ratios, but it means 4th and 5th are both overdrives and you tow in 3rd. One problem I did have with the Pilot was the low ratio 1.888 reverse gear. The Pilot was unable to back the 172 up even a slight incline. Honda really blew it there! A strong argument for high ratio reverse gears (low speed) and two speed transfer cases.&nbsp; <br></font>]]>
   <pubDate>Mon, 04 Jul 2016 09:58:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8310&amp;PID=78381#78381</guid>
   <title>Honda Pilot TV : Thanks for the input. With the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8310&amp;PID=78378#78378</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1920" rel="nofollow">gpod</a><br /><strong>Subject:</strong> 8310<br /><strong>Posted:</strong> 04 Jul 2016 at 9:36am<br /><br />Thanks for the input. &nbsp;With the Jeep, we have trouble getting up to 65 mph going up steep highways in Colorado, but overall the Jeep meets our needs. &nbsp;However, the wife wants an Outback and we're thinking of getting rid of the Jeep and keeping the Pilot since it is newer. &nbsp;Just want to know if we will get comparable performance before we go through the expense of putting a tow package on the Pilot.]]>
   <pubDate>Mon, 04 Jul 2016 09:36:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8310&amp;PID=78378#78378</guid>
   <title>Honda Pilot TV : I towed a 172 with a 4WD 2010...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8310&amp;PID=78377#78377</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1573" rel="nofollow">CharlieM</a><br /><strong>Subject:</strong> 8310<br /><strong>Posted:</strong> 04 Jul 2016 at 8:50am<br /><br /><font size="3">I towed a 172 with a 4WD 2010 Pilot for over a year with reasonable success. I specifically chose the 172 to keep the weight down since I was planning to travel the Rockies. </font><font size="3">The 172/Pilot combination worked fine at lower altitudes and reasonably flat terrain, but it was marginal in the mountains. </font><font size="3">The combination of mountain grades and altitude tax small engines.&nbsp;Your 182G is at least 600# heavier than the 172 and that will further degrade performance. That said, if you don't plan Rocky Mountain excursions and/or can take your time climbing the hills it should work OK. If you're satisfied with the Jeep it's probably comparable. However, this assumes the Pilot will be 4WD. The 4WD model has much greater towing capacity and a transmission cooler. Don't even consider a 2WD (front wheel drive) Pilot.&nbsp;</font>]]>
   <pubDate>Mon, 04 Jul 2016 08:50:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8310&amp;PID=78377#78377</guid>
   <title>Honda Pilot TV : I am thinking of switching my...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8310&amp;PID=78375#78375</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1920" rel="nofollow">gpod</a><br /><strong>Subject:</strong> 8310<br /><strong>Posted:</strong> 04 Jul 2016 at 1:06am<br /><br />I am thinking of switching my tow vehicle to an '06 Honda Pilot. &nbsp;Anyone using a Pilot to tow? &nbsp;I have a 182G and currently use an '05 Jeep Grand Cherokee 3.7L. &nbsp;Any input would be greatly appreciated!]]>
   <pubDate>Mon, 04 Jul 2016 01:06:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8310&amp;PID=78375#78375</guid>
