  <title>R-pod Owners Forum : Anode Rod question?</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Anode Rod question?</description>
  <pubDate>Thu, 27 Aug 2026 17:46:49 +0000</pubDate>
  <lastBuildDate>Sat, 02 Jul 2016 20:56:11 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=8300</WebWizForums:feedURL>
   <title>Anode Rod question? : Advice .......................fingers...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8300&amp;PID=78320#78320</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1100" rel="nofollow">Leo B</a><br /><strong>Subject:</strong> 8300<br /><strong>Posted:</strong> 02 Jul 2016 at 8:56pm<br /><br />Advice .......................fingers are going bad!]]>
   <pubDate>Sat, 02 Jul 2016 20:56:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8300&amp;PID=78320#78320</guid>
   <title>Anode Rod question? : Good advise!   </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8300&amp;PID=78318#78318</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1100" rel="nofollow">Leo B</a><br /><strong>Subject:</strong> 8300<br /><strong>Posted:</strong> 02 Jul 2016 at 8:55pm<br /><br />Good advise!]]>
   <pubDate>Sat, 02 Jul 2016 20:55:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8300&amp;PID=78318#78318</guid>
   <title>Anode Rod question? : My two cents. The hose rinse attachment...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8300&amp;PID=78303#78303</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1014" rel="nofollow">Camper Bob</a><br /><strong>Subject:</strong> 8300<br /><strong>Posted:</strong> 02 Jul 2016 at 6:22pm<br /><br />My two cents. &nbsp;The hose rinse attachment is use to flush out your water heater with the debris from the sacrificial anode. &nbsp;Cheap enough to buy and not a problem to flush out each time you replace the anode. &nbsp;Safe Travels. &nbsp;]]>
   <pubDate>Sat, 02 Jul 2016 18:22:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8300&amp;PID=78303#78303</guid>
   <title>Anode Rod question? :   Originally posted by cdsmithMy...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8300&amp;PID=78299#78299</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2942" rel="nofollow">WillThrill</a><br /><strong>Subject:</strong> 8300<br /><strong>Posted:</strong> 02 Jul 2016 at 4:31pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by cdsmith</strong></em><br /><br />My thoughts were the same - it's out so just replace it... &nbsp;<div><br></div><div>Now the question is magnesium or aluminum - the owners manual says either - is there a better choice?</div><div><br><div>The water tank rinser is "Camco 11691 Water Heater Tank Rinser" - just a hose attachment that has a reducer wand on the end that can be inserted into the hot water tank - not sure if it is really needed.</div><div>Thanks</div><div>cd<br><div><br></div></div></div></td></tr></table><div><br></div><div>I've not heard of a preference for the material that the anode is made out of, so whatever you can get easily and cheaply would work for me.</div><div><br></div><div>Since I've never even heard of anyone rinsing out their water heater tank, I would not worry about it. &nbsp;Camco sells a number of RV accessories that are very much unnecessary.</div>]]>
   <pubDate>Sat, 02 Jul 2016 16:31:26 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8300&amp;PID=78299#78299</guid>
   <title>Anode Rod question? : My thoughts were the same - it&amp;#039;s...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8300&amp;PID=78298#78298</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4825" rel="nofollow">cdsmith</a><br /><strong>Subject:</strong> 8300<br /><strong>Posted:</strong> 02 Jul 2016 at 3:47pm<br /><br />My thoughts were the same - it's out so just replace it... &nbsp;<div><br></div><div>Now the question is magnesium or aluminum - the owners manual says either - is there a better choice?</div><div><br><div>The water tank rinser is "Camco 11691 Water Heater Tank Rinser" - just a hose attachment that has a reducer wand on the end that can be inserted into the hot water tank - not sure if it is really needed.</div><div>Thanks</div><div>cd<br><div><br></div></div></div>]]>
   <pubDate>Sat, 02 Jul 2016 15:47:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8300&amp;PID=78298#78298</guid>
   <title>Anode Rod question? :   Originally posted by cdsmithI...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8300&amp;PID=78292#78292</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2942" rel="nofollow">WillThrill</a><br /><strong>Subject:</strong> 8300<br /><strong>Posted:</strong> 02 Jul 2016 at 2:59pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by cdsmith</strong></em><br /><br /><span style="line-height: 16.8px;">I pulled out the anode rod - I've attached a picture - now I need opinions on should I replace it... &nbsp;If so which one do I get? &nbsp;Are they all the same?</span><div style="line-height: 16.8px;">Also... &nbsp;does anyone have opinions on the tool: "Water heater tank rinser"?</div><div style="line-height: 16.8px;">It is an 2013 R-Pod 171.</div><div style="line-height: 16.8px;">Thanks</div><div style="line-height: 16.8px;">cd</div><div style="line-height: 16.8px;"><br></div><div style="line-height: 16.8px;"><br></div><div style="line-height: 16.8px;"><img src="uploads/4825/anode_rod_small.jpg" height="187" width="332" border="0" /><br></div></td></tr></table><div><br></div><div>Since the top of the rod is pretty much gone, I would recommend replacing it. &nbsp;You could probably get a bit more use out of it, but they're too cheap to not replace since you already have it out.</div><div><br></div><div>I've never heard of a water heater tank rinser and don't see why you would really need one unless your tank was quite old.</div>]]>
   <pubDate>Sat, 02 Jul 2016 14:59:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8300&amp;PID=78292#78292</guid>
   <title>Anode Rod question? : I pulled out the anode rod - I&amp;#039;ve...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=8300&amp;PID=78291#78291</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4825" rel="nofollow">cdsmith</a><br /><strong>Subject:</strong> 8300<br /><strong>Posted:</strong> 02 Jul 2016 at 2:56pm<br /><br /><span style="line-height: 16.8px;">I pulled out the anode rod - I've attached a picture - now I need opinions on should I replace it... &nbsp;If so which one do I get? &nbsp;Are they all the same?</span><div style="line-height: 16.8px;">Also... &nbsp;does anyone have opinions on the tool: "Water heater tank rinser"?</div><div style="line-height: 16.8px;">It is an 2013 R-Pod 171.</div><div style="line-height: 16.8px;">Thanks</div><div style="line-height: 16.8px;">cd</div><div style="line-height: 16.8px;"><br></div><div style="line-height: 16.8px;"><br></div><div style="line-height: 16.8px;"><img src="uploads/4825/anode_rod_small.jpg" height="187" width="332" border="0" /><br></div>]]>
   <pubDate>Sat, 02 Jul 2016 14:56:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=8300&amp;PID=78291#78291</guid>
