  <title>R-pod Owners Forum : Mods to R-Pod 179</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Mods to R-Pod 179</description>
  <pubDate>Thu, 29 Oct 2026 09:51:14 +0000</pubDate>
  <lastBuildDate>Mon, 13 Jun 2016 11:09:28 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=7988</WebWizForums:feedURL>
   <title>Mods to R-Pod 179 : I thought about a peep hole, but...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7988&amp;PID=77213#77213</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 7988<br /><strong>Posted:</strong> 13 Jun 2016 at 11:09am<br /><br />I thought about a peep hole, but we still would have wanted the window. It is nice to have the window that can be opened a bit for ventilation without having the whole door open. It also brings in more light in that corner for the pantry.]]>
   <pubDate>Mon, 13 Jun 2016 11:09:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7988&amp;PID=77213#77213</guid>
   <title>Mods to R-Pod 179 :  I have a 179 also and like the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7988&amp;PID=77204#77204</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5529" rel="nofollow">Westgl</a><br /><strong>Subject:</strong> 7988<br /><strong>Posted:</strong> 13 Jun 2016 at 9:59am<br /><br /><div>I have a 179 also and like the mods you have done. </div><div><br></div><div>I also use a cpap and would like to see pictures of all the Mods.</div><div><br></div><div>I was looking at&nbsp;instead of a window in the door installing a Large Peep hole in the door.</div><div><br></div><div>Like this one, but in Black</div><div>https://www.amazon.com/Angle-Peephole-Viewer-Doorscope-Silver/dp/B000S2FJZQ?ie=UTF8&amp;*Version*=1&amp;*entries*=0&nbsp;</div>]]>
   <pubDate>Mon, 13 Jun 2016 09:59:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7988&amp;PID=77204#77204</guid>
   <title>Mods to R-Pod 179 : Use a photo editing program (The...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7988&amp;PID=77039#77039</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 7988<br /><strong>Posted:</strong> 10 Jun 2016 at 4:17pm<br /><br />Use a photo editing program (The open-source GIMP is cross-platform and runs on Linux, OS X, and Windows) to resize the photo to 640x480. Save it and export it as a .png file. It then should be under 500 KB. I am pretty sure other photo editing programs are also capable of scaling the image to a size that is small enough to upload. I just happen to use Linux, so the GIMP is an obvious choice for me.<br><br>The GIMP menu items are Image/Scale Image. <br>]]>
   <pubDate>Fri, 10 Jun 2016 16:17:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7988&amp;PID=77039#77039</guid>
   <title>Mods to R-Pod 179 : I have tried a few times to add...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7988&amp;PID=77026#77026</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5418" rel="nofollow">B&K-Joslin</a><br /><strong>Subject:</strong> 7988<br /><strong>Posted:</strong> 10 Jun 2016 at 2:29pm<br /><br />I have tried a few times to add photos to this, but I receive a message, the photos are too " large" to enter. I will keep trying.]]>
   <pubDate>Fri, 10 Jun 2016 14:29:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7988&amp;PID=77026#77026</guid>
   <title>Mods to R-Pod 179 : The person I purchased the window,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7988&amp;PID=77025#77025</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5418" rel="nofollow">B&K-Joslin</a><br /><strong>Subject:</strong> 7988<br /><strong>Posted:</strong> 10 Jun 2016 at 2:22pm<br /><br />The person I purchased the window, for the door, was Frank Bear 517-741-5000. The window,frame, S&H was around $130.00. It is a good DIY project. ]]>
   <pubDate>Fri, 10 Jun 2016 14:22:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7988&amp;PID=77025#77025</guid>
   <title>Mods to R-Pod 179 : I would like to see some pictures...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7988&amp;PID=76516#76516</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3902" rel="nofollow">Appocalexx</a><br /><strong>Subject:</strong> 7988<br /><strong>Posted:</strong> 04 Jun 2016 at 6:22pm<br /><br />I would like to see some pictures for these mods. ]]>
   <pubDate>Sat, 04 Jun 2016 18:22:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7988&amp;PID=76516#76516</guid>
   <title>Mods to R-Pod 179 : I would love to see the pull-out...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7988&amp;PID=76351#76351</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4626" rel="nofollow">rmw454</a><br /><strong>Subject:</strong> 7988<br /><strong>Posted:</strong> 02 Jun 2016 at 12:53pm<br /><br />I would love to see the pull-out shelf for the cabinet under the stove.  I love the 2 steps also, I will have to check into that.  We are also looking at putting in the window in the door.  Did you install it or have someone install it for you?  Great mods.]]>
   <pubDate>Thu, 02 Jun 2016 12:53:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7988&amp;PID=76351#76351</guid>
   <title>Mods to R-Pod 179 : I made 3/4 x 3/4 x 10 square rods...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7988&amp;PID=75892#75892</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5418" rel="nofollow">B&K-Joslin</a><br /><strong>Subject:</strong> 7988<br /><strong>Posted:</strong> 26 May 2016 at 8:35pm<br /><br />I made 3/4 x 3/4 x 10 square rods to hold up the sides of the metal shelves. The shelf was made, using "Closest Maid" wire shelves. I measured the tubs, that I planed to use for height. Added an extra 1/4" or so, to have 6 tubs. As for the screws I used 1" drywall screw with glue on the wall side. ]]>
   <pubDate>Thu, 26 May 2016 20:35:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7988&amp;PID=75892#75892</guid>
   <title>Mods to R-Pod 179 : As for steps, I installed these...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7988&amp;PID=75891#75891</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4242" rel="nofollow">GLBCamper</a><br /><strong>Subject:</strong> 7988<br /><strong>Posted:</strong> 26 May 2016 at 8:05pm<br /><br />As for steps, I installed these from eTrailer. I just had to enlarge the back screw holes a bit. Otherwise a perfect fit.<div><br></div><div><span style="font-family: UICTFontTextStyleTall; font-size: 21px;">https://www.etrailer.com/RV-Stairs-and-Steps/Stromberg-Carlson/SMFP-2100.html</span></div><div><span style="font-family: UICTFontTextStyleTall; font-size: 21px;"><br></span></div><div><span style="font-family: UICTFontTextStyleTall; font-size: 21px;"><img src="uploads/4242/rPodSteps.JPG" height="434" width="558" border="0" /><br></span></div>]]>
   <pubDate>Thu, 26 May 2016 20:05:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7988&amp;PID=75891#75891</guid>
   <title>Mods to R-Pod 179 : Ha!! Good one!   </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7988&amp;PID=75888#75888</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1100" rel="nofollow">Leo B</a><br /><strong>Subject:</strong> 7988<br /><strong>Posted:</strong> 26 May 2016 at 7:40pm<br /><br />Ha!! Good one!]]>
   <pubDate>Thu, 26 May 2016 19:40:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7988&amp;PID=75888#75888</guid>
   <title>Mods to R-Pod 179 :   Originally posted by Pea PodHa...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7988&amp;PID=75887#75887</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4242" rel="nofollow">GLBCamper</a><br /><strong>Subject:</strong> 7988<br /><strong>Posted:</strong> 26 May 2016 at 7:30pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Pea Pod</strong></em><br /><br />&nbsp;Ha ha......you wrote 'coroner' cabinet.<br>What's in there, skeletons&nbsp;&nbsp; ? LOL<br><br><br></td></tr></table><div><br></div><div>I wondered the same thing! I kept picturing one of those long body drawers at the morgue. I guess the 179 has a LOT more room then the 177!</div>]]>
   <pubDate>Thu, 26 May 2016 19:30:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7988&amp;PID=75887#75887</guid>
   <title>Mods to R-Pod 179 : What size nails or screws did...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7988&amp;PID=75886#75886</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5050" rel="nofollow">Polly</a><br /><strong>Subject:</strong> 7988<br /><strong>Posted:</strong> 26 May 2016 at 7:06pm<br /><br />What size nails or screws did you use and what type of board for the shelves you put in the closet?]]>
   <pubDate>Thu, 26 May 2016 19:06:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7988&amp;PID=75886#75886</guid>
   <title>Mods to R-Pod 179 : Ha ha......you wrote &amp;#039;coroner&amp;#039;...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7988&amp;PID=75609#75609</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4109" rel="nofollow">Pea Pod</a><br /><strong>Subject:</strong> 7988<br /><strong>Posted:</strong> 22 May 2016 at 12:21pm<br /><br />&nbsp;Ha ha......you wrote 'coroner' cabinet.<br>What's in there, skeletons&nbsp;&nbsp; ? LOL<br><br><br>]]>
   <pubDate>Sun, 22 May 2016 12:21:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7988&amp;PID=75609#75609</guid>
   <title>Mods to R-Pod 179 : I called my dealer, where I purchased...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7988&amp;PID=75566#75566</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5418" rel="nofollow">B&K-Joslin</a><br /><strong>Subject:</strong> 7988<br /><strong>Posted:</strong> 21 May 2016 at 7:12pm<br /><br />I called my dealer, where I purchased the R-Pod.  He sold it to me at cost, $86.00<br />The spets were 1/2 narrower the the original.  Nothing a couple washers could not make up for. <br />P.S. I am in Meadville, PA ]]>
   <pubDate>Sat, 21 May 2016 19:12:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7988&amp;PID=75566#75566</guid>
   <title>Mods to R-Pod 179 : Do you recall where you got the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7988&amp;PID=75561#75561</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3363" rel="nofollow">john in idaho</a><br /><strong>Subject:</strong> 7988<br /><strong>Posted:</strong> 21 May 2016 at 6:33pm<br /><br />Do you recall where you got the two steps?]]>
   <pubDate>Sat, 21 May 2016 18:33:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7988&amp;PID=75561#75561</guid>
   <title>Mods to R-Pod 179 : 1. Change entrance step to 2-steps. 2....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7988&amp;PID=75543#75543</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5418" rel="nofollow">B&K-Joslin</a><br /><strong>Subject:</strong> 7988<br /><strong>Posted:</strong> 21 May 2016 at 4:18pm<br /><br />1. Change entrance step to 2-steps.<br />2. Installed a window in the door.<br />3. Installed a "pull-out" shelf in the coroner cabinet, under the cook top.<br />4. Installed a T-paper holder up and under the bathroom sink.<br />5. Moved the 3 pouch holder, in the bathroom, up 6", so it will stay UP, when being used.<br />6. Removed the hanging rod in the closet and added 6 shelves, to store 6 tubs.<br />7. Added a shelf over the bedroom bed, to hold "C-Paps"<br />8. Replaced the couches with a 7" thick  futon mattress.<br />9. Attached Velcro to the shower curtain and to the wall. To help keep curtain closed.<br />]]>
   <pubDate>Sat, 21 May 2016 16:18:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7988&amp;PID=75543#75543</guid>
