  <title>R-pod Owners Forum : Setting up trailer alone</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Setting up trailer alone</description>
  <pubDate>Sun, 28 Jun 2026 14:48:36 +0000</pubDate>
  <lastBuildDate>Mon, 05 Sep 2016 15:07:39 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=7973</WebWizForums:feedURL>
   <title>Setting up trailer alone : Hi Jewel59! You will do great!...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=81783#81783</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6022" rel="nofollow">AZ Hiker</a><br /><strong>Subject:</strong> 7973<br /><strong>Posted:</strong> 05 Sep 2016 at 3:07pm<br /><br />Hi Jewel59! &nbsp;You will do great! &nbsp;I am 51 and just purchased a 177 and immediately went for a 2 week adventure with my dog from AZ to Teton National Park. &nbsp;First time towing an RV. &nbsp;Like anything else - practice is the key! &nbsp;I went to a local high school and practiced backing up - I also bought a portable back up camera for the Pod. &nbsp;I have a back up camera on my 2011 Jeep GC - which I tow with. &nbsp;That camera helps a ton for hitching as it even has a ball "line" for exact alignment. &nbsp;However - you do need to make sure the trailer tongue height is correct first - and if the sun hits your car rear cameras - the glare can make them useless. &nbsp;I found that the folks in the RV parks were super helpful - especially as a solo woman! People are more than willing to assist you backing up / hitching / or general advice.<div><br></div><div>One mistake I made was with leveling the Pod and unhitching. &nbsp;I leveled the low side tire on some of the plastic lego leveling blocks - all good! &nbsp;But could not figure out how to chock that tire since it was on blocks. &nbsp;So I figured I was ok since the other tire was chocked. &nbsp; I also put my slide out before unhitching &nbsp;- for some dumb reason. &nbsp;So when I unhitched from my Jeep the Pod was ok for a few seconds - but then fell sideways off my tongue jack blocks. &nbsp;The jack was in the dirt and since I did not have a "foot" on the jack at the time - I was toast. &nbsp;Luckily a super nice guy came by and helped me picked the Pod back up hitched back on the Jeep. &nbsp;I felt really stupid - but its part of the learning - and luckily I did not get hurt nor did my Jeep! &nbsp;So lesson learned! &nbsp;Have both wheels chocked on all sides and get everything level and un-hithced before putting slide out!</div><div><br></div><div>I left my Jeep hitched to the POD a lot at night. &nbsp;Maybe because of my experience above and I was afraid the POD would slide off again - but I found the POD super stable hitched up - and I slept much better!!</div><div><br></div><div>Also - have good checklists and go thru them every time methodically. It will become habit eventually. &nbsp;Practice and Have confidence. &nbsp;You will do fine.</div><div><br></div><div>Enjoy!!</div>]]>
   <pubDate>Mon, 05 Sep 2016 15:07:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=81783#81783</guid>
   <title>Setting up trailer alone : I always hook-up solo.  I have...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=79523#79523</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5668" rel="nofollow">MDPaddlersPod</a><br /><strong>Subject:</strong> 7973<br /><strong>Posted:</strong> 26 Jul 2016 at 11:18am<br /><br />I always hook-up solo.  I have found from hauling my cargo trailer through the years that the telescopic yellow balls with a magnetic base work well for me.  They are cheap (around ten dollars) and easy to find at either Harbor Freight or Walmart in the trailer sections.]]>
   <pubDate>Tue, 26 Jul 2016 11:18:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=79523#79523</guid>
   <title>Setting up trailer alone : You&amp;#039;ll be fine!  I&amp;#039;m...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=79521#79521</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2418" rel="nofollow">Netter</a><br /><strong>Subject:</strong> 7973<br /><strong>Posted:</strong> 26 Jul 2016 at 11:06am<br /><br />You'll be fine!  I'm 48 with back issues and I can do it with no problem.  After a few times you will get into a habit of what to do in what order.  Pod on!!]]>
   <pubDate>Tue, 26 Jul 2016 11:06:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=79521#79521</guid>
   <title>Setting up trailer alone : A lot of the new cars come with...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=79511#79511</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 7973<br /><strong>Posted:</strong> 25 Jul 2016 at 10:22pm<br /><br />A lot of the new cars come with a backup camera. We got one with our 2016 Ford Escape SE. It has been extremely valuable. I had often thought of adding a camera. Now that I have one, I would not want to be without it. I thought about the yellow balls, but with the camera, I don't need them.]]>
   <pubDate>Mon, 25 Jul 2016 22:22:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=79511#79511</guid>
   <title>Setting up trailer alone :   Originally posted by ChetCAs...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=79504#79504</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=807" rel="nofollow">Keith-N-Dar</a><br /><strong>Subject:</strong> 7973<br /><strong>Posted:</strong> 25 Jul 2016 at 6:45pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by ChetC</strong></em><br /><br />As someone who hitches and unhitches a lot, I have one helpful tidbit of advice. &nbsp;Go to your local hardware store and purchase a cordless "driver" gun. &nbsp;Looks just like a cordless drill, but if designed to drive screws, bolts, etc... &nbsp;With that, get a socket adapter (it may come with one) and a 19mm socket to fit. &nbsp;Use this driver to run your stabilizer jacks up and down. &nbsp;Much faster and easier.<br><div><br></div><div>The only time I don't use the driver for the jacks is if I arrive at a campground late or leave early. &nbsp;They are a touch loud and I don't like to disturb my neighbors. &nbsp;<img src="https://www.rpod-owners.com/smileys/smiley1.gif" border="0" alt="Smile" title="Smile" /></div></td></tr></table><br><br>I still have to get out and look but the yellow balls help me get close.&nbsp; Lots cheaper than the TV camera.<br>]]>
   <pubDate>Mon, 25 Jul 2016 18:45:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=79504#79504</guid>
   <title>Setting up trailer alone : It&amp;#039;s like backing the trailer...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=79483#79483</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1100" rel="nofollow">Leo B</a><br /><strong>Subject:</strong> 7973<br /><strong>Posted:</strong> 25 Jul 2016 at 3:51pm<br /><br />It's like backing the trailer up..............practice<img src="https://www.rpod-owners.com/smileys/smiley20.gif" border="0" alt="Thumbs Up" title="Thumbs Up" />]]>
   <pubDate>Mon, 25 Jul 2016 15:51:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=79483#79483</guid>
   <title>Setting up trailer alone : The R dome is a little painful...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=79481#79481</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5668" rel="nofollow">MDPaddlersPod</a><br /><strong>Subject:</strong> 7973<br /><strong>Posted:</strong> 25 Jul 2016 at 3:40pm<br /><br />The R dome is a little painful the first time or two. I have only set mine up three times and on the third time I cut my time in half and found it pretty easy.  Don't let it frustrate you the first time.]]>
   <pubDate>Mon, 25 Jul 2016 15:40:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=79481#79481</guid>
   <title>Setting up trailer alone : As someone who hitches and unhitches...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=79438#79438</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5731" rel="nofollow">ChetC</a><br /><strong>Subject:</strong> 7973<br /><strong>Posted:</strong> 24 Jul 2016 at 9:37pm<br /><br />As someone who hitches and unhitches a lot, I have one helpful tidbit of advice. &nbsp;Go to your local hardware store and purchase a cordless "driver" gun. &nbsp;Looks just like a cordless drill, but if designed to drive screws, bolts, etc... &nbsp;With that, get a socket adapter (it may come with one) and a 19mm socket to fit. &nbsp;Use this driver to run your stabilizer jacks up and down. &nbsp;Much faster and easier.<br><div><br></div><div>The only time I don't use the driver for the jacks is if I arrive at a campground late or leave early. &nbsp;They are a touch loud and I don't like to disturb my neighbors. &nbsp;<img src="https://www.rpod-owners.com/smileys/smiley1.gif" border="0" alt="Smile" title="Smile" /></div>]]>
   <pubDate>Sun, 24 Jul 2016 21:37:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=79438#79438</guid>
   <title>Setting up trailer alone :  To help line up the trailer...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=79398#79398</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5595" rel="nofollow">TheLoneRanger</a><br /><strong>Subject:</strong> 7973<br /><strong>Posted:</strong> 23 Jul 2016 at 10:10pm<br /><br />To help line up the trailer to the tow vehicle I purchased this $10.00 solution from Harbor Freight.<br><br><br><img src="http://www.rpod-owners.com/uploads/5595/TrailerHitchAlignment.jpg" border="0" /><br><br><a href="http://www.harborfreight.com/catalogsearch/result?q=trailer+alignment" target="_blank">http://www.harborfreight.com/catalogsearch/result?q=trailer+alignment</a><br><br>The 1st time I tried it I still had to get out and check it was aligned a couple of times. However, I am sure after some practice I will be able to get it aligned correctly the 1st time.<br><br><br>]]>
   <pubDate>Sat, 23 Jul 2016 22:10:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=79398#79398</guid>
   <title>Setting up trailer alone : You might want to consider getting...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75488#75488</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4498" rel="nofollow">Capt Kidd</a><br /><strong>Subject:</strong> 7973<br /><strong>Posted:</strong> 20 May 2016 at 11:13am<br /><br />You might want to consider getting an electric jack in place of the hand one on the trailer. &nbsp;As I get older I find this to be a nice, not too costly, up grade. &nbsp;Makes it much easier to get on and off the ball.]]>
   <pubDate>Fri, 20 May 2016 11:13:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75488#75488</guid>
   <title>Setting up trailer alone :  As was mentioned earlier, backing...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75486#75486</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3887" rel="nofollow">David D</a><br /><strong>Subject:</strong> 7973<br /><strong>Posted:</strong> 20 May 2016 at 11:03am<br /><br />As was mentioned earlier, backing up might be the toughest when on your own. &nbsp;In cases like this, I've adopted a method which is tedious but works.... back up the trailer a few feet, get out of truck walk to back to study progress, get back in truck, and repeat process over and over until your good. &nbsp;I actually learned this the hard way.... backed up into a tree once... embarassing! &nbsp;;-) &nbsp; And, if you have to unhitch and still need to move your trailer, another item which has been super helpful is the Trailer Valet. &nbsp;I absolutely love this product. &nbsp;https://www.trailervalet.com/5x]]>
   <pubDate>Fri, 20 May 2016 11:03:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75486#75486</guid>
   <title>Setting up trailer alone : I have a back up camera which...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75480#75480</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4646" rel="nofollow">pnwcamper</a><br /><strong>Subject:</strong> 7973<br /><strong>Posted:</strong> 20 May 2016 at 9:59am<br /><br />I have a back up camera which makes it much easier. With a little practice you wont have any problem, just go slow and easy when backing up. Unhooking is easy.<br>]]>
   <pubDate>Fri, 20 May 2016 09:59:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75480#75480</guid>
   <title>Setting up trailer alone : It&amp;#039;s fine to connect water...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75479#75479</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1573" rel="nofollow">CharlieM</a><br /><strong>Subject:</strong> 7973<br /><strong>Posted:</strong> 20 May 2016 at 9:32am<br /><br /><font size="3">It's fine to connect water and shore power while connected to the BMW. I would add only one caution. Tow vehicles are generally wired to charge the trailer battery while traveling, but electrically disconnect when the engine is off. I say <i>generally</i>, but stuff happens and mistakes are made. The consequences are possible discharge of the BMW battery if shore power is not used. This can really ruin your morning. It's worth checking out. There are ways to check using a voltmeter, and even a way to check without a meter if you don't mind disconnecting the trailer battery. Let me know and I can talk you through it. Have fun and enjoy your camper and dogs <img src="https://www.rpod-owners.com/smileys/smiley1.gif" border="0" alt="Smile" title="Smile" /> .<br><br>&nbsp;&nbsp;</font>]]>
   <pubDate>Fri, 20 May 2016 09:32:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75479#75479</guid>
   <title>Setting up trailer alone :    Originally posted by techntrekIf...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75468#75468</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5410" rel="nofollow">Jewel59</a><br /><strong>Subject:</strong> 7973<br /><strong>Posted:</strong> 20 May 2016 at 8:14am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by techntrek</strong></em><br /><br />If you don't need to drive anywhere you can leave it hitched up, which saves some aggravation. &nbsp;You may find you can deal with it being somewhat out-of-level, so there will be times you can just back it in and put it in park. &nbsp;This is often the case for us at truck stops. &nbsp;I might crank up the tongue jack some to level it front-to-back a bit.</td></tr></table><div><br></div><div>I was wondering if this would be ok...leaving it hitched? &nbsp;Can you still hook to water and electricity safely? &nbsp;the type of sites at shows are very level. &nbsp;I'm super excited. &nbsp;I pick it up on Monday. &nbsp;I was supposed to get it yesterday but we had horrible rain in the area and I didn't want to start my first time on the road with it in horrible weather. &nbsp;Had a huge box from Camping World arrive and another from Amazon. &nbsp;I think I have all the necessities (leveling blocks, chocks, stabilizer pads and all the stuff for the inside to make it functional).<br>&nbsp;<div><br></div><div><br></div></div>]]>
   <pubDate>Fri, 20 May 2016 08:14:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75468#75468</guid>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75460#75460</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2" rel="nofollow">Guests</a><br /><strong>Subject:</strong> 7973<br /><strong>Posted:</strong> 20 May 2016 at 7:44am<br /><br /> <table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by techntrek</strong></em><br /><br />If you don't need to drive anywhere you can leave it hitched up, which saves some aggravation.  You may find you can deal with it being somewhat out-of-level, so there will be times you can just back it in and put it in park.  This is often the case for us at truck stops.  I might crank up the tongue jack some to level it front-to-back a bit.</td></tr></table> <br /><br />+1<br />I do this most anytime that I don't need to use the truck to run around and the campsite is close to level.<br /><br />It sounds like you'll have a nice setup.  I'll add, if you are not familiar with backing a trailer, you might want to find an empty parking lot to practice backing up.  Again, this is something that gets easier with time/practice.]]>
   <pubDate>Fri, 20 May 2016 07:44:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75460#75460</guid>
   <title>Setting up trailer alone : Thanks for asking the questions...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75458#75458</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5337" rel="nofollow">Rustler</a><br /><strong>Subject:</strong> 7973<br /><strong>Posted:</strong> 20 May 2016 at 5:30am<br /><br />Thanks for asking the questions about single person setup. My wife and I just bought a Rpod 171. But my first trip will be solo, going to the Golden State Star Party by myself. So the answers to your questions have been most useful. Later my wife will be with me for other camping trips this summer. I hope you and your four-legged companions enjoy the trips.]]>
   <pubDate>Fri, 20 May 2016 05:30:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75458#75458</guid>
   <title>Setting up trailer alone : to hook up.... buy a pvc pipe...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75456#75456</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5391" rel="nofollow">fredtello1</a><br /><strong>Subject:</strong> 7973<br /><strong>Posted:</strong> 20 May 2016 at 2:28am<br /><br />to hook up.... buy a pvc pipe to fit over the crank.... glue an elbow on it and then glue another pipe at length to just touch the middle of your back window.... &nbsp;it will help you line up.. they sell metal ones that stay on the hitch with magnets....... google hitch alignments..... https://www.bing.com/search?q=hitch%20alinements&amp;pc=cosp&amp;ptag=C1AE89FD93123&amp;form=CONBDF&amp;conlogo=CT3210127]]>
   <pubDate>Fri, 20 May 2016 02:28:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75456#75456</guid>
   <title>Setting up trailer alone : If you don&amp;#039;t need to drive...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75439#75439</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 7973<br /><strong>Posted:</strong> 19 May 2016 at 8:26pm<br /><br />If you don't need to drive anywhere you can leave it hitched up, which saves some aggravation. &nbsp;You may find you can deal with it being somewhat out-of-level, so there will be times you can just back it in and put it in park. &nbsp;This is often the case for us at truck stops. &nbsp;I might crank up the tongue jack some to level it front-to-back a bit.]]>
   <pubDate>Thu, 19 May 2016 20:26:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75439#75439</guid>
   <title>Setting up trailer alone : ......I&amp;#039;ll worry about the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75436#75436</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5410" rel="nofollow">Jewel59</a><br /><strong>Subject:</strong> 7973<br /><strong>Posted:</strong> 19 May 2016 at 7:53pm<br /><br />......I'll worry about the r-dome on my second trip (great shaded space for the dogs so I had to have it)]]>
   <pubDate>Thu, 19 May 2016 19:53:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75436#75436</guid>
   <title>Setting up trailer alone :    Originally posted by David Congratulations...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75435#75435</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5410" rel="nofollow">Jewel59</a><br /><strong>Subject:</strong> 7973<br /><strong>Posted:</strong> 19 May 2016 at 7:49pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by David</strong></em><br /><br /><br>Congratulations and welcome to the group!  <img src="https://www.rpod-owners.com/smileys/smiley1.gif" border="0" align="middle" /> <br><br>You should do just fine.  I travel alone with my dog 100% of the time.  The worst part is lining up the tow vehicle and trailer.  This gets easier with time/practice.  Some purchase a camera (but not me).<br><br>Most everything else doesn't require super-human strength, or a genius IQ (thank goodness).  Level your trailer, side to side, with leveling blocks before unhitching - just back up onto them and then "chock" the wheels.  Level front/back using the tongue jack when you unhitch.  The stabilizers are not difficult, just a lot of turning the crank.  There is an attachment for cordless drills that can be used, if desired.  <br><br>So, can you do it alone....YES!  If you have any particular questions, just ask!</td></tr></table><div><br></div><div>Thanks for the words of support. &nbsp;I consider myself capable (LOL, we'll see). &nbsp;I have a BMW X3, I went with the tow package from BMW although it cost a lot more than I had hoped (comes with integrated brake control, all parts, and a reprogramming of the back up and parking sensors on the vehicle). &nbsp;I'm told once the trailef is hitched, the back-up cam has been programmed to allow you to hitch with guidelines projected to the back-up cam screen....like docking the space station). &nbsp;I am sure hoping this is the case! &nbsp;<br>&nbsp;<div><br></div><div><br></div></div>]]>
   <pubDate>Thu, 19 May 2016 19:49:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75435#75435</guid>
   <title>Setting up trailer alone : Welcome to the group and sure...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75411#75411</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=428" rel="nofollow">David and Danette</a><br /><strong>Subject:</strong> 7973<br /><strong>Posted:</strong> 19 May 2016 at 2:56pm<br /><br />Welcome to the group and sure you will do fine, that's the advantage of having a small camper it makes things easier. I agree with David- " weird guy with a wolf " gets easier with "time/practice".]]>
   <pubDate>Thu, 19 May 2016 14:56:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75411#75411</guid>
   <title>Setting up trailer alone :  Congratulations and welcome to...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75407#75407</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2" rel="nofollow">Guests</a><br /><strong>Subject:</strong> 7973<br /><strong>Posted:</strong> 19 May 2016 at 2:38pm<br /><br /><br />Congratulations and welcome to the group!  <img src="https://www.rpod-owners.com/smileys/smiley1.gif" border="0" align="middle" /> <br /><br />You should do just fine.  I travel alone with my dog 100% of the time.  The worst part is lining up the tow vehicle and trailer.  This gets easier with time/practice.  Some purchase a camera (but not me).<br /><br />Most everything else doesn't require super-human strength, or a genius IQ (thank goodness).  Level your trailer, side to side, with leveling blocks before unhitching - just back up onto them and then "chock" the wheels.  Level front/back using the tongue jack when you unhitch.  The stabilizers are not difficult, just a lot of turning the crank.  There is an attachment for cordless drills that can be used, if desired.  <br /><br />So, can you do it alone....YES!  If you have any particular questions, just ask!]]>
   <pubDate>Thu, 19 May 2016 14:38:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75407#75407</guid>
   <title>Setting up trailer alone : You will be perfectly fine doing...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75406#75406</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5088" rel="nofollow">Retroactive</a><br /><strong>Subject:</strong> 7973<br /><strong>Posted:</strong> 19 May 2016 at 2:12pm<br /><br />You will be perfectly fine doing the unhitch and setup on your own, more time consuming than anything else.<div><br></div><div>Getting the camper back on the hitch will require a helper at first. Most importantly so you get the socket and ball aligned when backing up, and sometimes you need a second set of hands to slide the camper an inch or so for final alignment. Eventually most people can learn to back the truck up quite literally by feel, when it makes contact with the trailer. Sliding the trailer can be done solo too, with such a tiny camper it is more a matter of technique than strength.&nbsp;</div>]]>
   <pubDate>Thu, 19 May 2016 14:12:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75406#75406</guid>
   <title>Setting up trailer alone : Welcome to the group!   </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75404#75404</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1100" rel="nofollow">Leo B</a><br /><strong>Subject:</strong> 7973<br /><strong>Posted:</strong> 19 May 2016 at 2:08pm<br /><br />Welcome to the group!]]>
   <pubDate>Thu, 19 May 2016 14:08:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75404#75404</guid>
   <title>Setting up trailer alone :   Originally posted by dr.beckyYou...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75401#75401</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5410" rel="nofollow">Jewel59</a><br /><strong>Subject:</strong> 7973<br /><strong>Posted:</strong> 19 May 2016 at 12:48pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by dr.becky</strong></em><br /><br />You will do great. &nbsp;My husband and usually travel together and one person tackles the indoor stuff and<div>&nbsp;one the outdoor stuff, independently. &nbsp;We laugh when folks have tiny dogs in huge rv's. &nbsp;As we have a huge dog in our tiny trailer, 120 lb Bernese Mountain dog. &nbsp;He does great, just sleeps by the door and has yet to steal anything off the table that is at his nose height. &nbsp;</div></td></tr></table><div><br></div><div>Oh my, that is a big dog. &nbsp;Chihuahuas are definitely a good size for the r-pod. &nbsp;My husband only occasionally comes to shows so mostly I'm on my own (which is fun)!</div>]]>
   <pubDate>Thu, 19 May 2016 12:48:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75401#75401</guid>
   <title>Setting up trailer alone : You will do great. My husband...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75400#75400</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5222" rel="nofollow">dr.becky</a><br /><strong>Subject:</strong> 7973<br /><strong>Posted:</strong> 19 May 2016 at 12:42pm<br /><br />You will do great. &nbsp;My husband and usually travel together and one person tackles the indoor stuff and<div>&nbsp;one the outdoor stuff, independently. &nbsp;We laugh when folks have tiny dogs in huge rv's. &nbsp;As we have a huge dog in our tiny trailer, 120 lb Bernese Mountain dog. &nbsp;He does great, just sleeps by the door and has yet to steal anything off the table that is at his nose height. &nbsp;</div>]]>
   <pubDate>Thu, 19 May 2016 12:42:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75400#75400</guid>
   <title>Setting up trailer alone :  Hello- I just purchased a new...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75399#75399</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5410" rel="nofollow">Jewel59</a><br /><strong>Subject:</strong> 7973<br /><strong>Posted:</strong> 19 May 2016 at 12:37pm<br /><br />Hello- I just purchased a new 2016 R-pod 180. &nbsp;I show chihuahuas and the main purpose of the trailer is to take to shows (and avoid hotel costs). &nbsp;Shows are typically at fairgrounds and agricultural centers that provide camping facilities. &nbsp;My question is this, how easy is it to unhitch and level the R-pod on you own? I consider myself a fit, active, strong and capable 51 year old woman. &nbsp;Can I do this on my own? &nbsp;It's kind of to late to back out as I've paid for R-pod and will pick it up Monday. &nbsp;I'd like an honest appraisal of how many do the set up alone. &nbsp;(since I know some people are laughing, yes it's good thing I show chihuahuas with such a small trailer)<div><br></div><div><br></div>]]>
   <pubDate>Thu, 19 May 2016 12:37:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7973&amp;PID=75399#75399</guid>
