  <title>R-pod Owners Forum : Shore power on 2010 173</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Shore power on 2010 173</description>
  <pubDate>Thu, 29 Oct 2026 09:52:17 +0000</pubDate>
  <lastBuildDate>Sun, 17 Apr 2016 12:13:09 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=7769</WebWizForums:feedURL>
   <title>Shore power on 2010 173 : Kinda what I figured. Thank you....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7769&amp;PID=73345#73345</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5234" rel="nofollow">Gaangel77</a><br /><strong>Subject:</strong> 7769<br /><strong>Posted:</strong> 17 Apr 2016 at 12:13pm<br /><br />Kinda what I figured. Thank you.]]>
   <pubDate>Sun, 17 Apr 2016 12:13:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7769&amp;PID=73345#73345</guid>
   <title>Shore power on 2010 173 : The R-pod has a standard 3 prong...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7769&amp;PID=73344#73344</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4133" rel="nofollow">sailor323</a><br /><strong>Subject:</strong> 7769<br /><strong>Posted:</strong> 17 Apr 2016 at 12:00pm<br /><br />The R-pod has a standard 3 prong male 30 Amp hook-up]]>
   <pubDate>Sun, 17 Apr 2016 12:00:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7769&amp;PID=73344#73344</guid>
   <title>Shore power on 2010 173 : Good afternoon all! I have some...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7769&amp;PID=73343#73343</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5234" rel="nofollow">Gaangel77</a><br /><strong>Subject:</strong> 7769<br /><strong>Posted:</strong> 17 Apr 2016 at 11:48am<br /><br /><p ="Ms&#111;normal" style="margin-bottom:0in;margin-bottom:.0001pt;line-height:  normal"><span style="font-size: 9pt; font-family: Verdana, sans-serif; -: initial; -attachment: initial; -size: initial; -origin: initial; -clip: initial; -: initial; -repeat: initial;">Good afternoon all! I have some questions aboutthis R-pod and I figure this is the best place to start.</span></p><p ="Ms&#111;normal" style="margin-bottom:0in;margin-bottom:.0001pt;line-height:  12.6pt"><span style="font-size: 9pt; font-family: Verdana, sans-serif;">We have begun renting travel trailers and RV's through RV sharerecently. This gives us an opportunity to try several different things beforewe purchase. In two weeks we will be renting our first R-pod. It is a 2010 173model. I have a 6500 watt generator with a 4 prong NEMA twist lock. pretty mucheverything we have ever seen has a standard 3 prong 30 amp twist lock shorepower hook up that allows us to hook up the generator.</span></p><p ="Ms&#111;normal" style="margin-bottom:0in;margin-bottom:.0001pt;line-height:  12.6pt"><span style="font-size: 9pt; font-family: Verdana, sans-serif;">Here is my problem, the first time I lay eyes on this R-pod willbe the day I pick it up for the weekend. I keep seeing postings about chargingthe batteries. Do these units have a standard shore power hook up? Is there aproprietary cable specific only to these R-pods? I have the large adapter to gofrom a 30 amp 3 prong to my 4 prong, but do I need to purchase the 30 amp to 15amp for a standard household plug?<o:p></o:p></span></p><p ="Ms&#111;normal" style="margin-bottom:0in;margin-bottom:.0001pt;line-height:  12.6pt"><span style="font-size: 9pt; font-family: Verdana, sans-serif;">Any help or photos of the hook ups and the cords needed would be much appreciated.</span></p><p ="Ms&#111;normal" style="margin-bottom:0in;margin-bottom:.0001pt;line-height:  12.6pt"><span style="font-size: 9pt; font-family: Verdana, sans-serif;">Thank you in advance, and I hope y'all are having a great weekend!!</span></p>]]>
   <pubDate>Sun, 17 Apr 2016 11:48:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7769&amp;PID=73343#73343</guid>
