  <title>R-pod Owners Forum : Generator</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Introduce Yourself : Generator</description>
  <pubDate>Fri, 25 Sep 2026 06:50:56 +0000</pubDate>
  <lastBuildDate>Tue, 12 Apr 2016 18:17:44 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=7738</WebWizForums:feedURL>
   <title>Generator : Thanks to everyone for the great...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7738&amp;PID=73109#73109</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5073" rel="nofollow">Hour Pod</a><br /><strong>Subject:</strong> 7738<br /><strong>Posted:</strong> 12 Apr 2016 at 6:17pm<br /><br />Thanks to everyone for the great information. Will go with 2, 2000 watt gens.]]>
   <pubDate>Tue, 12 Apr 2016 18:17:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7738&amp;PID=73109#73109</guid>
   <title>Generator :  Originally posted by furpodJust...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7738&amp;PID=73098#73098</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2" rel="nofollow">Guests</a><br /><strong>Subject:</strong> 7738<br /><strong>Posted:</strong> 12 Apr 2016 at 2:57pm<br /><br /> <table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by furpod</strong></em><br /><br />Just use a 20A to 30A puck adapter. It's a 2400 watt genny, it's only going to make 20A peak anyways. 2400w / 120v = 20AIt only has 1 ac circuit.</td></tr></table> <br /><br />What he said.<br /><br />You can get the adapters at Walmart, also.  <br /><br />I made up my own 20 amp cord from a 10ga. 25' extension cord.  I cut off the "female" end and installed the appropriate NEMA 30 amp twist lock plug (the end that plugs into the camper).  I use it at home for every day charging on a 20 amp circuit and take it with me when I plan to use the generator.  The 30 amp OEM cord just gets used when a 30 amp pedestal is available.<br /><br />I agree with Charlie, my adapters will get warm if much current is passed thru them.]]>
   <pubDate>Tue, 12 Apr 2016 14:57:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7738&amp;PID=73098#73098</guid>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7738&amp;PID=73097#73097</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1573" rel="nofollow">CharlieM</a><br /><strong>Subject:</strong> 7738<br /><strong>Posted:</strong> 12 Apr 2016 at 2:48pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by furpod</strong></em><br /><br />Just use a 20A to 30A puck adapter. It's a 2400 watt genny, it's only going to make 20A peak anyways. 2400w / 120v = 20A<br><br>It only has 1 ac circuit.<br></td></tr></table><br><br><font size="3">Yeah, you're right. I forgot I was only dealing with a 2000+ watt gen. At continuous running load of 2000W you're only at 16+ Amps. Is there a breaker associated with the outlet, and if so, what rating? And even at that level I would recommend a GOOD quality puck adapter. The nice yellow Camco version, not the cheap black plastic ones. They melt.</font><br>]]>
   <pubDate>Tue, 12 Apr 2016 14:48:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7738&amp;PID=73097#73097</guid>
   <title>Generator :   Originally posted by Happy...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7738&amp;PID=73095#73095</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 7738<br /><strong>Posted:</strong> 12 Apr 2016 at 2:28pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Happy Tripping</strong></em><br /><br /><div><br></div><div>In the Yamaha link, what is the significance of "<span style="color: rgb255, 69, 0; font-family: Lato, Helvetica, Arial, sans-serif; font-size: 13px; font-weight: bold; line-height: 18.2px;">does NOT have a 30 amp electrical receptacle" </span><span style="color: rgb255, 69, 0; font-family: Lato, Helvetica, Arial, sans-serif; font-size: 13px; line-height: 18.2px;">?</span></div><div><span style="color: rgb255, 69, 0; font-family: Lato, Helvetica, Arial, sans-serif; font-size: 13px; font-weight: bold; line-height: 18.2px;"><br></span></div><div><span style="color: rgb255, 69, 0; font-family: Lato, Helvetica, Arial, sans-serif; font-size: 13px; line-height: 18.2px;">Does it just mean we need an adapter??</span></div></td></tr></table><br><br>Yes, you just need an adapter.<br><br>Something like this.&nbsp; <a href="http://www.electricgeneratorsdirect.com/Reliance-C&#111;ntrols-AP15RV/p1067.html" target="_blank">Adapter.</a><br>]]>
   <pubDate>Tue, 12 Apr 2016 14:28:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7738&amp;PID=73095#73095</guid>
   <title>Generator : Just use a 20A to 30A puck adapter....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7738&amp;PID=73094#73094</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 7738<br /><strong>Posted:</strong> 12 Apr 2016 at 2:24pm<br /><br />Just use a 20A to 30A puck adapter. It's a 2400 watt genny, it's only going to make 20A peak anyways. 2400w / 120v = 20A<br><br>It only has 1 ac circuit.<br>]]>
   <pubDate>Tue, 12 Apr 2016 14:24:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7738&amp;PID=73094#73094</guid>
   <title>Generator :   Originally posted by TheBum...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7738&amp;PID=73093#73093</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1573" rel="nofollow">CharlieM</a><br /><strong>Subject:</strong> 7738<br /><strong>Posted:</strong> 12 Apr 2016 at 2:22pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by TheBum</strong></em><br /><br />&#091;QUOTE=CharlieM&#093; <br><br>Or open the panel with the outlets and see if there's more than one set of three wires coming in. The outlet in my Ryobi is essentially a house outlet.</td></tr></table><br><br><font size="3">That works</font> <img src="https://www.rpod-owners.com/smileys/smiley14.gif" border="0" alt="Approve" title="Approve" /><br>]]>
   <pubDate>Tue, 12 Apr 2016 14:22:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7738&amp;PID=73093#73093</guid>
   <title>Generator :  Originally posted by CharlieM  Originally...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7738&amp;PID=73092#73092</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5021" rel="nofollow">TheBum</a><br /><strong>Subject:</strong> 7738<br /><strong>Posted:</strong> 12 Apr 2016 at 2:16pm<br /><br /> <table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by CharlieM</strong></em><br /><br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by TheBum</strong></em><br /><br />Yes.  Ideally, you should have one that plugs into both outlets on the generator because those are typically only rated to 15A each.<br /><br /></td></tr></table><font size="3"><img src="https://www.rpod-owners.com/smileys/smiley37.gif" border="0" alt="Exclamati&#111;n" title="Exclamati&#111;n" />  <img src="https://www.rpod-owners.com/smileys/smiley37.gif" border="0" alt="Exclamati&#111;n" title="Exclamati&#111;n" /> Caution here! The two 115V receptacles are not necessarily "in phase". In non Geek speak that means they cannot be paralleled. If so and you do there will be lightening, noise, smoke, fire, and a dead generator. <img src="https://www.rpod-owners.com/smileys/smiley35.gif" border="0" alt="Censored" title="Censored" />  Best to check with a voltmeter first. </font></td></tr></table> <br /><br />Or open the panel with the outlets and see if there's more than one set of three wires coming in. The outlet in my Ryobi is essentially a house outlet.]]>
   <pubDate>Tue, 12 Apr 2016 14:16:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7738&amp;PID=73092#73092</guid>
   <title>Generator :   Originally posted by TheBumYes....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7738&amp;PID=73091#73091</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1573" rel="nofollow">CharlieM</a><br /><strong>Subject:</strong> 7738<br /><strong>Posted:</strong> 12 Apr 2016 at 2:05pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by TheBum</strong></em><br /><br /><br><br>Yes.  Ideally, you should have one that plugs into both outlets on the generator because those are typically only rated to 15A each.<br></td></tr></table><br><br><font size="3"><img src="https://www.rpod-owners.com/smileys/smiley37.gif" border="0" alt="Exclamati&#111;n" title="Exclamati&#111;n" />&nbsp; <img src="https://www.rpod-owners.com/smileys/smiley37.gif" border="0" alt="Exclamati&#111;n" title="Exclamati&#111;n" /> Caution here! The two 115V receptacles are not necessarily "in phase". In non Geek speak that means they cannot be paralleled. If so and you do there will be lightening, noise, smoke, fire, and a dead generator. <img src="https://www.rpod-owners.com/smileys/smiley35.gif" border="0" alt="Censored" title="Censored" />&nbsp; <br>Best to check with a voltmeter first. </font><br>]]>
   <pubDate>Tue, 12 Apr 2016 14:05:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7738&amp;PID=73091#73091</guid>
   <title>Generator : Yes.  Ideally, you should have...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7738&amp;PID=73084#73084</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5021" rel="nofollow">TheBum</a><br /><strong>Subject:</strong> 7738<br /><strong>Posted:</strong> 12 Apr 2016 at 12:19pm<br /><br />Yes.  Ideally, you should have one that plugs into both outlets on the generator because those are typically only rated to 15A each.<br /><br />The issue you might run into is if you're running anything else off 120VAC when the compressor kicks on, you may brown out the generator or, at the very worse, trip its breaker.  I suspect the 2400W is a surge rating, which means it'll probably only do about 2000W continuously.]]>
   <pubDate>Tue, 12 Apr 2016 12:19:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7738&amp;PID=73084#73084</guid>
   <title>Generator :   In the Yamaha link, what is...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7738&amp;PID=73083#73083</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2821" rel="nofollow">Happy Tripping</a><br /><strong>Subject:</strong> 7738<br /><strong>Posted:</strong> 12 Apr 2016 at 11:41am<br /><br /><div><br></div><div>In the Yamaha link, what is the significance of "<span style="color: rgb255, 69, 0; font-family: Lato, Helvetica, Arial, sans-serif; font-size: 13px; font-weight: bold; line-height: 18.2px;">does NOT have a 30 amp electrical receptacle" </span><span style="color: rgb255, 69, 0; font-family: Lato, Helvetica, Arial, sans-serif; font-size: 13px; line-height: 18.2px;">?</span></div><div><span style="color: rgb255, 69, 0; font-family: Lato, Helvetica, Arial, sans-serif; font-size: 13px; font-weight: bold; line-height: 18.2px;"><br></span></div><div><span style="color: rgb255, 69, 0; font-family: Lato, Helvetica, Arial, sans-serif; font-size: 13px; line-height: 18.2px;">Does it just mean we need an adapter??</span></div>]]>
   <pubDate>Tue, 12 Apr 2016 11:41:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7738&amp;PID=73083#73083</guid>
   <title>Generator :  Welcome to the forum!     I have...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7738&amp;PID=73065#73065</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2" rel="nofollow">Guests</a><br /><strong>Subject:</strong> 7738<br /><strong>Posted:</strong> 12 Apr 2016 at 8:16am<br /><br /><br />Welcome to the forum!  <img src="https://www.rpod-owners.com/smileys/smiley1.gif" border="0" align="middle" /> <br /><br />I have no personal experience with the Yamaha.  There have been posts in the past from members that indicated the 2400 would run the A/C.]]>
   <pubDate>Tue, 12 Apr 2016 08:16:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7738&amp;PID=73065#73065</guid>
   <title>Generator : Thanks for the link Dave. </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7738&amp;PID=73056#73056</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5073" rel="nofollow">Hour Pod</a><br /><strong>Subject:</strong> 7738<br /><strong>Posted:</strong> 12 Apr 2016 at 1:12am<br /><br />Thanks for the link Dave.]]>
   <pubDate>Tue, 12 Apr 2016 01:12:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7738&amp;PID=73056#73056</guid>
   <title>Generator : Welcome! There have been a few...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7738&amp;PID=73054#73054</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3880" rel="nofollow">dacolson</a><br /><strong>Subject:</strong> 7738<br /><strong>Posted:</strong> 12 Apr 2016 at 12:11am<br /><br />Welcome! There have been a few posts on generators recently. Here's one:<div><a href="http://www.rpod-owners.com/forum_posts.asp?TID=7426" target="_blank">Generator Size Question</a><br><div><br></div></div>]]>
   <pubDate>Tue, 12 Apr 2016 00:11:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7738&amp;PID=73054#73054</guid>
   <title>Generator : Hello all, picking up Hour Pod...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7738&amp;PID=73053#73053</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5073" rel="nofollow">Hour Pod</a><br /><strong>Subject:</strong> 7738<br /><strong>Posted:</strong> 12 Apr 2016 at 12:02am<br /><br />Hello all, picking up Hour Pod (& 1st RV) end of April.  In researching generators to run the ac, came across the Yamaha 2400iSHC.  The 2 dealers i've talked to say it will run the Pod's ac - but this Yamaha linked says they don't recommend this unit for RV ac units.  Wondering if anyone has experience w/this generator.<br /><br />http://www.yamahagenerators.com/Yamaha-EF2400iSHC-p/ef2400ishc.htm<br /><br />Thanks,]]>
   <pubDate>Tue, 12 Apr 2016 00:02:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7738&amp;PID=73053#73053</guid>
