  <title>R-pod Owners Forum : Roof Maybe Leaking</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Roof Maybe Leaking</description>
  <pubDate>Thu, 29 Oct 2026 07:40:55 +0000</pubDate>
  <lastBuildDate>Sat, 06 Feb 2016 10:07:55 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=7408</WebWizForums:feedURL>
   <title>Roof Maybe Leaking : You might also check the ac as...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7408&amp;PID=69638#69638</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3130" rel="nofollow">J&Jcf</a><br /><strong>Subject:</strong> 7408<br /><strong>Posted:</strong> 06 Feb 2016 at 10:07am<br /><br />You might also check the ac as well. That is the place of my leak.]]>
   <pubDate>Sat, 06 Feb 2016 10:07:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7408&amp;PID=69638#69638</guid>
   <title>Roof Maybe Leaking : Thanks Furpod,Good idea about...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7408&amp;PID=69609#69609</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4480" rel="nofollow">Elenaron</a><br /><strong>Subject:</strong> 7408<br /><strong>Posted:</strong> 04 Feb 2016 at 8:32pm<br /><br />Thanks Furpod,<div><div>Good idea about testing with a hose. I have the Dicor self-leveling Lap Sealant I plan to use.</div><div><br></div></div>]]>
   <pubDate>Thu, 04 Feb 2016 20:32:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7408&amp;PID=69609#69609</guid>
   <title>Roof Maybe Leaking :   It&amp;#039;s pretty much impossible...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7408&amp;PID=69555#69555</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 7408<br /><strong>Posted:</strong> 02 Feb 2016 at 7:16pm<br /><br />It's pretty much impossible to say, without being there, where it might be leaking, you will need to test it with a hose. As far as repair, once the bad spot is found, clean all the old sealant out, and away, then reseal. It's important to note silicone based caulk will stick to nearly everything on the planet.. except itself.&nbsp;<br><br>Checking, keeping track of, and replacing as needed the seals and caulk around a TT is fact of life..<br>]]>
   <pubDate>Tue, 02 Feb 2016 19:16:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7408&amp;PID=69555#69555</guid>
   <title>Roof Maybe Leaking : We have had lots of rain here...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7408&amp;PID=69554#69554</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4480" rel="nofollow">Elenaron</a><br /><strong>Subject:</strong> 7408<br /><strong>Posted:</strong> 02 Feb 2016 at 6:19pm<br /><br /><span style="line-height: 16.8px;">We have had lots of rain here recently in South Florida, and have our trailer in an outdoor storage lot. W</span>&nbsp;have some water damage in the left, back, inside corner, behind the Queen mattress. It is on the plywood decking and wall.&nbsp;<img src="https://www.rpod-owners.com/smileys/smiley19.gif" border="0" alt="Cry" title="Cry" />.&nbsp;<span style="line-height: 1.4;">We have a 2014 R-Pod 178.</span><div><br><div><span style="line-height: 1.4;">I'm wondering if the caulking at the seam on the roof between the roof and the sides needs to be replaced or infilled. I do see some small cracks in the caulking in places.&nbsp;</span><span style="line-height: 16.8px;">I don't think it is the rear window, as the seal around the window looks good.&nbsp;</span><span style="line-height: 1.4;">Does anyone have any experience in recaulking this roof seam?&nbsp;</span></div><div><span style="line-height: 1.4;">I worry that it may be more of a project than I want to start.</span></div><div><span style="line-height: 1.4;"><br></span></div><div><span style="line-height: 1.4;">Thanks&nbsp;</span></div></div>]]>
   <pubDate>Tue, 02 Feb 2016 18:19:26 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7408&amp;PID=69554#69554</guid>
