  <title>R-pod Owners Forum : zamp plug in ??</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : zamp plug in ??</description>
  <pubDate>Fri, 06 Nov 2026 22:41:13 +0000</pubDate>
  <lastBuildDate>Wed, 10 Feb 2016 16:54:09 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=7352</WebWizForums:feedURL>
   <title>zamp plug in ?? : We just got a Renology suitcase...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7352&amp;PID=69822#69822</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4232" rel="nofollow">Patrick</a><br /><strong>Subject:</strong> 7352<br /><strong>Posted:</strong> 10 Feb 2016 at 4:54pm<br /><br />We just got a Renology suitcase with alligator clips, so today we got a 10' wire with a male SAE connector for the Zamp port on the 179. ]]>
   <pubDate>Wed, 10 Feb 2016 16:54:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7352&amp;PID=69822#69822</guid>
   <title>zamp plug in ?? :  I agree with Furpod, and I have...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7352&amp;PID=69112#69112</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2882" rel="nofollow">johnmaci</a><br /><strong>Subject:</strong> 7352<br /><strong>Posted:</strong> 15 Jan 2016 at 9:08pm<br /><br />I agree with Furpod, and I have the Renology Suitcase and it works very well.<br>Just be aware that the Renology uses SB type connectors and not SAE.<br>]]>
   <pubDate>Fri, 15 Jan 2016 21:08:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7352&amp;PID=69112#69112</guid>
   <title>zamp plug in ?? : No, I am saying exactly the opposite....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7352&amp;PID=69109#69109</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 7352<br /><strong>Posted:</strong> 15 Jan 2016 at 8:53pm<br /><br />No, I am saying exactly the opposite. The zamp port on the pod is ONLY a set of wires to the battery(ies). Most people use folding panel sets, and they have all had a built in controller on the panel. If you want something different, the sky is the limit, but you will have to have a controller and panels, and do the wiring yourself..<br><a href="http://www.amaz&#111;n.com/gp/product/B00HR8YNK6?psc=1&amp;redirect=true&amp;ref_=ox_sc_sfl_title_25&amp;smid=A05654602L3XUQ70M87BV" target="_blank"><br>This is a popular panel set..</a><br>]]>
   <pubDate>Fri, 15 Jan 2016 20:53:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7352&amp;PID=69109#69109</guid>
   <title>zamp plug in ?? : hey furpod are you saying that...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7352&amp;PID=69094#69094</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3411" rel="nofollow">preach4pod</a><br /><strong>Subject:</strong> 7352<br /><strong>Posted:</strong> 15 Jan 2016 at 5:00pm<br /><br />hey furpod are you saying that there is a built in controller on the pod<div id="UMS_TOOLTIP" style=": ; cursor: pointer; : 2147483647; top: -100000px; left: -100000px; : transparent;"></div><div><br></div>]]>
   <pubDate>Fri, 15 Jan 2016 17:00:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7352&amp;PID=69094#69094</guid>
   <title>zamp plug in ?? : Any system can be plugged in,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7352&amp;PID=69019#69019</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 7352<br /><strong>Posted:</strong> 13 Jan 2016 at 4:46pm<br /><br />Any system can be plugged in, you need a "SAE Plug".. widely available, many units come with that as one of the options. You do need a panel set with built in, or attached charge controller, to be truly plug and play.]]>
   <pubDate>Wed, 13 Jan 2016 16:46:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7352&amp;PID=69019#69019</guid>
   <title>zamp plug in ?? : Can I use another brand( other...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7352&amp;PID=69016#69016</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3411" rel="nofollow">preach4pod</a><br /><strong>Subject:</strong> 7352<br /><strong>Posted:</strong> 13 Jan 2016 at 4:05pm<br /><br />Can I use another brand( other than Zamp) to plug in to the sidewall plug in ?&nbsp; Is there any hardware needed to do that?&nbsp; thanks in advance, I have always found alot of wisdom here,<img src="https://www.rpod-owners.com/smileys/smiley1.gif" border="0" alt="Smile" title="Smile" /><br><br>]]>
   <pubDate>Wed, 13 Jan 2016 16:05:26 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7352&amp;PID=69016#69016</guid>
