  <title>R-pod Owners Forum : Cushion foam replacement</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Mods, Maintenance, Tips and Tricks : Cushion foam replacement</description>
  <pubDate>Fri, 23 Oct 2026 14:16:31 +0000</pubDate>
  <lastBuildDate>Tue, 08 Feb 2022 09:52:06 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=7303</WebWizForums:feedURL>
   <title>Cushion foam replacement : Hello Fred,	I know it&amp;#039;s been...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7303&amp;PID=146987#146987</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=12072" rel="nofollow">mpod</a><br /><strong>Subject:</strong> 7303<br /><strong>Posted:</strong> 08 Feb 2022 at 9:52am<br /><br />Hello Fred,&nbsp;<div><br></div><div><span style="white-space:pre">	</span>I know it's been a while since you ordered the cushion replacement - wondering if there was anything you would change as I need to order some for the 2016 Rpod I have---my 2 questions are :</div><div><br></div><div>1) the dimensions add up to 2" short in the case of&nbsp; the length and width of the "shorter" cushions-&nbsp; did all cushions fit properly and fill the bed area when converted?</div><div><br></div><div>2) I am looking at the HD36 High Quality Foam- is this what you purchased- how did it hold up?</div><div><br></div><div>Thanks,&nbsp;</div><div>Matt</div>]]>
   <pubDate>Tue, 08 Feb 2022 09:52:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7303&amp;PID=146987#146987</guid>
   <title>Cushion foam replacement : I replaced the dinette cushions...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7303&amp;PID=125136#125136</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4516" rel="nofollow">mesamie</a><br /><strong>Subject:</strong> 7303<br /><strong>Posted:</strong> 23 Jun 2019 at 9:21am<br /><br />I replaced the dinette cushions with one full sized memory foam mattress, with same sized plywood underneath. We never used the dinette to eat on and that table was a pain in the xxx to mess with, let alone my son loves his new bed....the whole thing slides in and out with slide.]]>
   <pubDate>Sun, 23 Jun 2019 09:21:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7303&amp;PID=125136#125136</guid>
   <title>Cushion foam replacement : I used a combination of 3&amp;#034;...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7303&amp;PID=120199#120199</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 7303<br /><strong>Posted:</strong> 30 Jan 2019 at 9:51pm<br /><br /><div>I used a combination of 3" of high density foam and 1" of standard density foam and then topped that with a layer of quilt batting when I made the cushions for my dinette modification. I wanted the back cushions to be the same thickness as the seat cushion. Since that is still in good shape, I did not replace the foam in it, but may do that some day.</div><div><a href="http://www.rpod-owners.com/forum_posts.asp?TID=7712&amp;PID=106418&amp;title=our-escapod-mods#106418" target="_blank">http://www.rpod-owners.com/forum_posts.asp?TID=7712&amp;PID=106418&amp;title=our-escapod-mods#106418</a><br></div>]]>
   <pubDate>Wed, 30 Jan 2019 21:51:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7303&amp;PID=120199#120199</guid>
   <title>Cushion foam replacement : Oh boy. another mod to do! </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7303&amp;PID=120195#120195</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7746" rel="nofollow">crw8sr</a><br /><strong>Subject:</strong> 7303<br /><strong>Posted:</strong> 30 Jan 2019 at 6:20pm<br /><br />Oh boy. another mod to do!]]>
   <pubDate>Wed, 30 Jan 2019 18:20:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7303&amp;PID=120195#120195</guid>
   <title>Cushion foam replacement :   Originally posted by David...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7303&amp;PID=120184#120184</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 7303<br /><strong>Posted:</strong> 30 Jan 2019 at 12:52pm<br /><br /><div><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by David and Danette</strong></em><br /><br />&nbsp; &nbsp; &nbsp;We bought ours from the foam factory too. We bought the HD 36 HQ 5" thick it is more dense and a little heavier than the original factory foam, provides better support. We bought a full sheet 82" x 76" &nbsp;$205.99 more than we needed for the camper but have some left over for another project. We have some long cushions about 42" and one I think was 48". I didn't like the factory covers for the back cushions so to save money I bought body pillow covers from ebay. They are easily removed to wash when needed.</td></tr></table> <br></div><div>Body pillow covers? I wish I had thought of that. I made the two covers for the cushions I made to replace the back dinette cushions for my dinette modification. Body pillow covers would have made the job much easier. However my cushions are 75" long so I would have had to stitch two of the covers together to make one long enough to fit.<br></div>]]>
   <pubDate>Wed, 30 Jan 2019 12:52:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7303&amp;PID=120184#120184</guid>
   <title>Cushion foam replacement : We are glad we made the decision...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7303&amp;PID=120177#120177</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 7303<br /><strong>Posted:</strong> 30 Jan 2019 at 9:58am<br /><br />We are glad we made the decision to change out the seat foam a while ago.&nbsp; We were like techntrek as the foam would compress to nothing.&nbsp; Went to a place in Traverse City which specializes in foam, called "Stuff It Upholstery."&nbsp; Good prices and very helpful owner who has myriads of options of foam from medium price to upper end, including virgin foam, which very few use due to the cost.&nbsp; In the world of golf carts, only Yamaha uses it (virgin foam), and what a difference over its competitors.&nbsp; We still have some Yamahas from the 1980's used by staff and rangers and those seats are more comfortable and give better support than 1 year old carts made by Club Car or E-Z-Go, you get what you pay for.&nbsp; We purchased a firm foam, not the firmest, and the cost came to $ 166.28.&nbsp; Wow, what a difference!]]>
   <pubDate>Wed, 30 Jan 2019 09:58:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7303&amp;PID=120177#120177</guid>
   <title>Cushion foam replacement : Agreed. I recently opted for some...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7303&amp;PID=120164#120164</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9087" rel="nofollow">Green3</a><br /><strong>Subject:</strong> 7303<br /><strong>Posted:</strong> 30 Jan 2019 at 6:25am<br /><br />Agreed. I recently opted for some new <a href="https://www.foamfactory.co.uk/" target="_blank">cushion foam</a> and its made such a difference.]]>
   <pubDate>Wed, 30 Jan 2019 06:25:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7303&amp;PID=120164#120164</guid>
   <title>Cushion foam replacement : Just what I was looking for, my...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7303&amp;PID=69777#69777</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=582" rel="nofollow">tturbo</a><br /><strong>Subject:</strong> 7303<br /><strong>Posted:</strong> 09 Feb 2016 at 12:44pm<br /><br />Just what I was looking for, my trailer is in storage right now, but I'm anxious to get this done. Sound like I just need to buy some good foam and do it myself.&nbsp;<br><br>Thanks]]>
   <pubDate>Tue, 09 Feb 2016 12:44:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7303&amp;PID=69777#69777</guid>
   <title>Cushion foam replacement : Good info, the cushions for the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7303&amp;PID=68573#68573</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 7303<br /><strong>Posted:</strong> 28 Dec 2015 at 9:38pm<br /><br />Good info, the cushions for the dinette in our Salem compress to nothing and should be replaced. &nbsp;Something to add to my to-do list.]]>
   <pubDate>Mon, 28 Dec 2015 21:38:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7303&amp;PID=68573#68573</guid>
   <title>Cushion foam replacement : We bought ours from the foam factory...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7303&amp;PID=68565#68565</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=428" rel="nofollow">David and Danette</a><br /><strong>Subject:</strong> 7303<br /><strong>Posted:</strong> 28 Dec 2015 at 1:25pm<br /><br />&nbsp; &nbsp; &nbsp;We bought ours from the foam factory too. We bought the HD 36 HQ 5" thick it is more dense and a little heavier than the original factory foam, provides better support. We bought a full sheet 82" x 76" &nbsp;$205.99 more than we needed for the camper but have some left over for another project. We have some long cushions about 42" and one I think was 48". I didn't like the factory covers for the back cushions so to save money I bought body pillow covers from ebay. They are easily removed to wash when needed.]]>
   <pubDate>Mon, 28 Dec 2015 13:25:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7303&amp;PID=68565#68565</guid>
   <title>Cushion foam replacement : We replaced the 178 dinette cushions...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7303&amp;PID=68559#68559</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2297" rel="nofollow">fwunder</a><br /><strong>Subject:</strong> 7303<br /><strong>Posted:</strong> 28 Dec 2015 at 10:38am<br /><br />We replaced the 178 dinette cushions last year. Big improvement. Details:<div><br></div><div><div><blockquote ="cite" style="font-family: Helvetica; font-size: 14px; border-left-style: n&#111;ne; color: inherit; padding: inherit; margin: inherit;"><a href="http://www.thefoamfactory.com/opencellfoam/HD36-HQ.html" target="_blank">http://www.thefoamfactory.com/opencellfoam/HD36-HQ.html</a></blockquote></div><div><br></div><div>2 @ 4" x 12" x 33” =&gt; $28.16</div><div>2 @ 4" x 24" x 33” =&gt; $56.32</div><div>1 @ 4" x 23" x 74” =&gt; $61.46</div><div><br></div><div>Total cost = &gt; $145.94</div></div><div><br></div><div>fred</div><div><br></div>]]>
   <pubDate>Mon, 28 Dec 2015 10:38:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7303&amp;PID=68559#68559</guid>
   <title>Cushion foam replacement : What type of foam did you use???...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7303&amp;PID=68554#68554</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3238" rel="nofollow">Podster</a><br /><strong>Subject:</strong> 7303<br /><strong>Posted:</strong> 27 Dec 2015 at 11:05pm<br /><br />What type of foam did you use???]]>
   <pubDate>Sun, 27 Dec 2015 23:05:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7303&amp;PID=68554#68554</guid>
   <title>Cushion foam replacement : From which company did you purchase...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7303&amp;PID=68548#68548</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2390" rel="nofollow">headcold</a><br /><strong>Subject:</strong> 7303<br /><strong>Posted:</strong> 27 Dec 2015 at 9:09pm<br /><br />From which company did you purchase the foam?]]>
   <pubDate>Sun, 27 Dec 2015 21:09:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7303&amp;PID=68548#68548</guid>
   <title>Cushion foam replacement : I changed my counter and used...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7303&amp;PID=68546#68546</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1045" rel="nofollow">marwayne</a><br /><strong>Subject:</strong> 7303<br /><strong>Posted:</strong> 27 Dec 2015 at 6:31pm<br /><br />I changed my counter and used 3/4" birch and almond laminate.]]>
   <pubDate>Sun, 27 Dec 2015 18:31:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7303&amp;PID=68546#68546</guid>
   <title>Cushion foam replacement : I second the suggestion on the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7303&amp;PID=68543#68543</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 7303<br /><strong>Posted:</strong> 27 Dec 2015 at 5:55pm<br /><br />I second the suggestion on the particle board, especially for the counter top.]]>
   <pubDate>Sun, 27 Dec 2015 17:55:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7303&amp;PID=68543#68543</guid>
   <title>Cushion foam replacement : I changed the foam in our cushions...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7303&amp;PID=68533#68533</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=428" rel="nofollow">David and Danette</a><br /><strong>Subject:</strong> 7303<br /><strong>Posted:</strong> 27 Dec 2015 at 9:21am<br /><br />&nbsp; &nbsp;I changed the foam in our cushions for a better quality foam. What a difference, wish I had made the change sooner. Ordered the foam over the internet then measured it and cut it with a kitchen knife, very easy mod. The two things I wish RV manufactures would spend a few extra dollars on that's cushion foam and plywood instead of using particle board. I am going out to our camper now more often to read and watch TV the comfortable cushions make it so much more enjoyable.]]>
   <pubDate>Sun, 27 Dec 2015 09:21:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7303&amp;PID=68533#68533</guid>
