  <title>R-pod Owners Forum : 😟 convinced My rpod  is a  Lemon</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Reviews and General Information : 😟 convinced My rpod  is a  Lemon</description>
  <pubDate>Sun, 25 Oct 2026 03:51:04 +0000</pubDate>
  <lastBuildDate>Sun, 15 Nov 2015 17:37:24 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=7222</WebWizForums:feedURL>
   <title>😟 convinced My rpod  is a  Lemon : FR has been known to fix major...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7222&amp;PID=67873#67873</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 7222<br /><strong>Posted:</strong> 15 Nov 2015 at 5:37pm<br /><br />FR has been known to fix major issues outside of warranty. &nbsp;Even if you didn't buy the 2nd year warranty from FR, I would contact them with your list.]]>
   <pubDate>Sun, 15 Nov 2015 17:37:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7222&amp;PID=67873#67873</guid>
   <title>😟 convinced My rpod  is a  Lemon : Where do I start I&amp;#039;ll try...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7222&amp;PID=67866#67866</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3542" rel="nofollow">Jpntime</a><br /><strong>Subject:</strong> 7222<br /><strong>Posted:</strong> 15 Nov 2015 at 3:39pm<br /><br />&nbsp;Where do I start I'll try to be short sink faucet falling off waterlines left loose inside &nbsp;so they leaked ,air conditioning mounting bolts one of them broke air-conditioner was moving around on top &nbsp;sure they over tighten them when they installed them , Side of the trailer opening up &nbsp;that's the big one that bothers me the most ,angle iron that holds the black tank gray tank and water tank about a quarter inch short from frame rail to frame rail with only one screw into the &nbsp;The frame holding the tanks up wouldn't be so bad if it would've been flush with the frame &nbsp;and put more than one self tapping screw on each side &nbsp;but all the electronics have been good but they didn't put them together , bathroom sink coming loose from wall they put-screws through that realthin wood with nothing for it to tighten up to , filler hose to Clearwater tank cut on the inside where it leaked on the floor when I filled it the hose clamp they tightened it with cut the hose &nbsp;that's all I can think of in the year and three quarters I've had it&nbsp;]]>
   <pubDate>Sun, 15 Nov 2015 15:39:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7222&amp;PID=67866#67866</guid>
   <title>😟 convinced My rpod  is a  Lemon : What other problems have you had...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7222&amp;PID=67863#67863</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=807" rel="nofollow">Keith-N-Dar</a><br /><strong>Subject:</strong> 7222<br /><strong>Posted:</strong> 15 Nov 2015 at 3:01pm<br /><br />What other problems have you had with your Pod?&nbsp; This is hardly enough to declare it a lemon.]]>
   <pubDate>Sun, 15 Nov 2015 15:01:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7222&amp;PID=67863#67863</guid>
   <title>😟 convinced My rpod  is a  Lemon : No it doesn&amp;#039;t you think it&amp;#039;s...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7222&amp;PID=67850#67850</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3542" rel="nofollow">Jpntime</a><br /><strong>Subject:</strong> 7222<br /><strong>Posted:</strong> 15 Nov 2015 at 9:35am<br /><br />&nbsp;No it doesn't you think it's just safe to silicone the holes on the top maybe drill little holes in the bottom&nbsp;]]>
   <pubDate>Sun, 15 Nov 2015 09:35:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7222&amp;PID=67850#67850</guid>
   <title>😟 convinced My rpod  is a  Lemon :   Originally posted by JpntimeThe...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7222&amp;PID=67849#67849</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=598" rel="nofollow">kymooses</a><br /><strong>Subject:</strong> 7222<br /><strong>Posted:</strong> 15 Nov 2015 at 9:31am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Jpntime</strong></em><br /><br />&nbsp;The back window has &nbsp;drain holes and mine are on top and &nbsp;the rpod I compared it too are on the bottom and on my side windows have drain holes that are all on the bottom 😭</td></tr></table><div><br></div><div>The windows usually have those weeping holes at top and bottom, they insert a piece of plastic into the top ones and leave the plastic out of the bottom ones.</div><div><br></div><div>Does the bottom of your window have the little pieces of plastic you can pop out? &nbsp;If so just pull them and put them in the top.</div>]]>
   <pubDate>Sun, 15 Nov 2015 09:31:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7222&amp;PID=67849#67849</guid>
   <title>😟 convinced My rpod  is a  Lemon : The back window has drain holes...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7222&amp;PID=67843#67843</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3542" rel="nofollow">Jpntime</a><br /><strong>Subject:</strong> 7222<br /><strong>Posted:</strong> 14 Nov 2015 at 9:55pm<br /><br />&nbsp;The back window has &nbsp;drain holes and mine are on top and &nbsp;the rpod I compared it too are on the bottom and on my side windows have drain holes that are all on the bottom 😭]]>
   <pubDate>Sat, 14 Nov 2015 21:55:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7222&amp;PID=67843#67843</guid>
   <title>😟 convinced My rpod  is a  Lemon :   Originally posted by JpntimeMy...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7222&amp;PID=67838#67838</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=598" rel="nofollow">kymooses</a><br /><strong>Subject:</strong> 7222<br /><strong>Posted:</strong> 14 Nov 2015 at 6:14pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Jpntime</strong></em><br /><br />&nbsp;My wife pointed out to me today at the back window is installed upside down do you think I need to get it flipped or just silicone off the drain holes that are at the top .? &nbsp;Read some of my other post and you understand why I think it's a lemon broke my heart today when I seen that so disappointed&nbsp;<img src="https://www.rpod-owners.com/smileys/smiley19.gif" border="0" alt="Cry" title="Cry" /><img src="https://www.rpod-owners.com/smileys/smiley19.gif" border="0" alt="Cry" title="Cry" /><img src="https://www.rpod-owners.com/smileys/smiley19.gif" border="0" alt="Cry" title="Cry" /></td></tr></table><div><br></div><div>If you mean upside down based on the writing from the window manufacturer then also look at your left and right windows on either side of your Pod, one side will likely be right side up and the other upside down.</div><div><br></div><div><br></div>]]>
   <pubDate>Sat, 14 Nov 2015 18:14:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7222&amp;PID=67838#67838</guid>
   <title>😟 convinced My rpod  is a  Lemon : My wife pointed out to me today...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7222&amp;PID=67835#67835</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3542" rel="nofollow">Jpntime</a><br /><strong>Subject:</strong> 7222<br /><strong>Posted:</strong> 14 Nov 2015 at 1:25pm<br /><br />&nbsp;My wife pointed out to me today at the back window is installed upside down do you think I need to get it flipped or just silicone off the drain holes that are at the top .? &nbsp;Read some of my other post and you understand why I think it's a lemon broke my heart today when I seen that so disappointed&nbsp;<img src="https://www.rpod-owners.com/smileys/smiley19.gif" border="0" alt="Cry" title="Cry" /><img src="https://www.rpod-owners.com/smileys/smiley19.gif" border="0" alt="Cry" title="Cry" /><img src="https://www.rpod-owners.com/smileys/smiley19.gif" border="0" alt="Cry" title="Cry" />]]>
   <pubDate>Sat, 14 Nov 2015 13:25:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7222&amp;PID=67835#67835</guid>
