  <title>R-pod Owners Forum : thoughts on maiden voyage</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Reviews and General Information : thoughts on maiden voyage</description>
  <pubDate>Sun, 25 Oct 2026 03:28:34 +0000</pubDate>
  <lastBuildDate>Thu, 05 Nov 2015 13:30:21 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=7184</WebWizForums:feedURL>
   <title>thoughts on maiden voyage : All closed with A/C.  It will...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7184&amp;PID=67649#67649</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 7184<br /><strong>Posted:</strong> 05 Nov 2015 at 1:30pm<br /><br />All closed with A/C.  It will take care of the humidity.  We ran ours on auto during the day so it was quieter between cycles, but always ran on low overnight for the white noise and to mask the cycling of the compressor.]]>
   <pubDate>Thu, 05 Nov 2015 13:30:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7184&amp;PID=67649#67649</guid>
   <title>thoughts on maiden voyage : I run the AC with all windows...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7184&amp;PID=67642#67642</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4087" rel="nofollow">ronahue</a><br /><strong>Subject:</strong> 7184<br /><strong>Posted:</strong> 05 Nov 2015 at 10:50am<br /><br />I run the AC with all windows and vents closed and have not had a humidity problem. That being said I believe I have only used it twice. In the 179 be sure you have the fan on HI or LO if it is on AUTO the fan will cycle of and on with the compressor and will drive you crazy.]]>
   <pubDate>Thu, 05 Nov 2015 10:50:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7184&amp;PID=67642#67642</guid>
   <title>thoughts on maiden voyage : What is the best combination of...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7184&amp;PID=67641#67641</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2080" rel="nofollow">Lefty</a><br /><strong>Subject:</strong> 7184<br /><strong>Posted:</strong> 05 Nov 2015 at 8:39am<br /><br />What is the best combination of vent/window when the air condition is running?]]>
   <pubDate>Thu, 05 Nov 2015 08:39:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7184&amp;PID=67641#67641</guid>
   <title>thoughts on maiden voyage : Yes, you need to leave the vent...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7184&amp;PID=67630#67630</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 7184<br /><strong>Posted:</strong> 04 Nov 2015 at 6:01pm<br /><br />Yes, you need to leave the vent and a window open a crack, any season, unless the A/C is on. &nbsp;That will create some convective air flow. &nbsp;Each person loses 1 liter a day, so figure 2 people will lose 2/3 of a liter over 8 hours while sleeping so it needs to be vented. &nbsp;Even camping at 10 F with both open a crack my electric heater had no problem keeping it warm, and there was little condensation.]]>
   <pubDate>Wed, 04 Nov 2015 18:01:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7184&amp;PID=67630#67630</guid>
   <title>thoughts on maiden voyage :   As for the speakers I believe...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7184&amp;PID=67627#67627</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4087" rel="nofollow">ronahue</a><br /><strong>Subject:</strong> 7184<br /><strong>Posted:</strong> 04 Nov 2015 at 5:02pm<br /><br /><div><br></div><div>As for the speakers I believe it is selection "B" on the Jenson. "A" is for the interior speakers and "C" gets me nothing probably for an AUX speaker. However I must say that radio/DVD is still a bit of a mystery to me. We use it only to play DVD's.&nbsp;</div>]]>
   <pubDate>Wed, 04 Nov 2015 17:02:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7184&amp;PID=67627#67627</guid>
   <title>thoughts on maiden voyage : I leave the roof vent open about...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7184&amp;PID=67626#67626</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4087" rel="nofollow">ronahue</a><br /><strong>Subject:</strong> 7184<br /><strong>Posted:</strong> 04 Nov 2015 at 4:57pm<br /><br /><div><br></div><div>I leave the roof vent open about 1" and open a window about 1/2" seems to work OK.</div>]]>
   <pubDate>Wed, 04 Nov 2015 16:57:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7184&amp;PID=67626#67626</guid>
   <title>thoughts on maiden voyage : Three days into maiden voyage...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7184&amp;PID=67616#67616</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4498" rel="nofollow">Capt Kidd</a><br /><strong>Subject:</strong> 7184<br /><strong>Posted:</strong> 04 Nov 2015 at 11:54am<br /><br />Three days into maiden voyage with our new 179 and happy with the new rig.<br /><br />Couple of questions, how do you get the outside speakers to work?  We have been in weather that is in the 30s at night so have been using the propane heater which except for being a little noisy works great, but we get a lot of condensation on the inside of the window.  Last night I tried leaving the roof vent slightly open but didn't seem to do any good.  Any ideas on how to deal with this or is this just something you have to live with,<br /><br />Had hard rain the first day and night and no leaks, which is a good thing.<br /><br />My sister who I travel with gets the big bed so I sleep on the dinette<br />thingy which works just fine for me.  The first night I used the collapsible table and cushions but found they tended to slide off and fall on the floor so last night I just used the couch part an\d that worked OK. ]]>
   <pubDate>Wed, 04 Nov 2015 11:54:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7184&amp;PID=67616#67616</guid>
