  <title>R-pod Owners Forum : Champion 2,800W Generator</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Reviews and General Information : Champion 2,800W Generator</description>
  <pubDate>Sun, 25 Oct 2026 03:31:06 +0000</pubDate>
  <lastBuildDate>Mon, 26 Oct 2015 21:20:55 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=7141</WebWizForums:feedURL>
   <title>Champion 2,800W Generator : This is the generator I have and...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7141&amp;PID=67393#67393</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3542" rel="nofollow">Jpntime</a><br /><strong>Subject:</strong> 7141<br /><strong>Posted:</strong> 26 Oct 2015 at 9:20pm<br /><br />&nbsp;This is the generator I have and it runs the AC just fine&nbsp;]]>
   <pubDate>Mon, 26 Oct 2015 21:20:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7141&amp;PID=67393#67393</guid>
   <title>Champion 2,800W Generator : Great price for the output. The...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7141&amp;PID=67371#67371</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 7141<br /><strong>Posted:</strong> 26 Oct 2015 at 3:54pm<br /><br />Great price for the output. &nbsp;The only thing I would worry about is the small gas tank (1.6 gallons) - if it doesn't have a fuel pump. &nbsp;It is much harder to add an external tank w/o it. &nbsp;My Yamaha EF2400 had a 1.5 gallon tank and it lasted exactly 8 hours running the pod with the A/C and the fan on low. &nbsp;Just a little bigger, like 2 gallons, would have worked much better for overnight stops, giving 12 hours of run time.]]>
   <pubDate>Mon, 26 Oct 2015 15:54:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7141&amp;PID=67371#67371</guid>
   <title>Champion 2,800W Generator : Thanks for posting this tip.  I...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7141&amp;PID=67360#67360</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2" rel="nofollow">Guests</a><br /><strong>Subject:</strong> 7141<br /><strong>Posted:</strong> 26 Oct 2015 at 7:27am<br /><br />Thanks for posting this tip.<br /><br />I bought the Champion 2000 watt inverter model at the beginning of this year.  So far, it hasn't missed a beat.  Based on this, I'd say Champions are worth looking at, if one is in the market for a generator.]]>
   <pubDate>Mon, 26 Oct 2015 07:27:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7141&amp;PID=67360#67360</guid>
   <title>Champion 2,800W Generator : In the latest Costco mailer starting...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7141&amp;PID=67340#67340</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2642" rel="nofollow">JandL</a><br /><strong>Subject:</strong> 7141<br /><strong>Posted:</strong> 25 Oct 2015 at 12:11pm<br /><br />In the latest Costco mailer starting 10/29/15 they had the Champion 2800 watt generator on sale for $699. This is the generator I have. It is enough to start my AC on my 2012 177<br /><br />Running/Rated Watts:  2800 (18 amps) Peak/Starting Watts; 3100 (25 amps)<br />Recoil Start; Engine Size: 171cc; Engine Type:4 stroke Champion OHV w/cast iron sleeve<br />Clean Sine Wave – less than 5% THD – safe to run sensitive electronics<br />Outlets: (1) 120V 20 Amp GFCI Duplex Outlet (5-20R); (1) 120V TT-30 Outlet – for RV’s<br />Weight: 83 Lbs.<br /><img src="uploads/2642/champ.jpg" border="0" />]]>
   <pubDate>Sun, 25 Oct 2015 12:11:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7141&amp;PID=67340#67340</guid>
