  <title>R-pod Owners Forum : 2015 RPod 178</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Introduce Yourself : 2015 RPod 178</description>
  <pubDate>Fri, 25 Sep 2026 03:18:12 +0000</pubDate>
  <lastBuildDate>Thu, 29 Oct 2015 23:26:12 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=7128</WebWizForums:feedURL>
   <title>2015 RPod 178 : I see you&amp;#039;re in San Diego....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7128&amp;PID=67491#67491</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3092" rel="nofollow">kylekai</a><br /><strong>Subject:</strong> 7128<br /><strong>Posted:</strong> 29 Oct 2015 at 11:26pm<br /><br />I see you're in San Diego. &nbsp;Did you purchase your r-pod from Bobby Combs RV Center? &nbsp;I purchased my 2015 r-pod 179 from them, and whenever I have an issue, I send them an email. &nbsp;I almost always get a helpful response within 24 hours. &nbsp;Quite valuable when out camping.]]>
   <pubDate>Thu, 29 Oct 2015 23:26:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7128&amp;PID=67491#67491</guid>
   <title>2015 RPod 178 : Glad to help. </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7128&amp;PID=67301#67301</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 7128<br /><strong>Posted:</strong> 24 Oct 2015 at 2:39pm<br /><br />Glad to help.]]>
   <pubDate>Sat, 24 Oct 2015 14:39:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7128&amp;PID=67301#67301</guid>
   <title>2015 RPod 178 : Thank you so much! Found it and...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7128&amp;PID=67273#67273</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4738" rel="nofollow">Squirt2700</a><br /><strong>Subject:</strong> 7128<br /><strong>Posted:</strong> 22 Oct 2015 at 11:23am<br /><br />Thank you so much! Found it and turned it to on position for electric! You are a life saver! Thank you! The switch is so hidden I would not have found it without your help!<img src="https://www.rpod-owners.com/smileys/smiley1.gif" border="0" alt="Smile" title="Smile" />]]>
   <pubDate>Thu, 22 Oct 2015 11:23:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7128&amp;PID=67273#67273</guid>
   <title>2015 RPod 178 :  First make sure the water heater...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7128&amp;PID=67266#67266</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 7128<br /><strong>Posted:</strong> 21 Oct 2015 at 7:39pm<br /><br />First make sure the water heater is full. &nbsp;If there is still air in it you'll get a lot of sputtering when you open the hot water valve on the kitchen sink.<div><br></div><div>There are 2 modes for the WH, propane and electric. &nbsp;You can use either one separately or together. &nbsp;LP warms (or re-warms) the water faster, but if you use both together that is the fastest. &nbsp;Turn on the LP mode with a switch inside - a red light next to the switch will light up until it has lit. &nbsp;Turn on the electric mode with a black switch at the lower-left on the water heater - outside - after you open the outer cover. &nbsp;It is easiest to leave that switch on and turn it on/off using the circuit breaker on the converter inside the pod. &nbsp;</div><div><br></div><div>If the tank is empty you will burn out the electric element immediately which is why it is important to make sure it is full. &nbsp;Fill it at the start of the season and just leave it full all summer.</div>]]>
   <pubDate>Wed, 21 Oct 2015 19:39:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7128&amp;PID=67266#67266</guid>
   <title>2015 RPod 178 : Out camping and hooked up to electricity...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7128&amp;PID=67262#67262</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4738" rel="nofollow">Squirt2700</a><br /><strong>Subject:</strong> 7128<br /><strong>Posted:</strong> 21 Oct 2015 at 3:05pm<br /><br />Out camping and hooked up to electricity but no hot water. Confused on the two toggles inside doorway marked water(both at top) and left side heater at bottom- pump on right. To get hot water do I push toggle in on bottom or top?<img src="https://www.rpod-owners.com/smileys/smiley10.gif" border="0" alt="Star" title="Star" />]]>
   <pubDate>Wed, 21 Oct 2015 15:05:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7128&amp;PID=67262#67262</guid>
