  <title>R-pod Owners Forum : Attaching Safety Chains</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Attaching Safety Chains</description>
  <pubDate>Thu, 29 Oct 2026 07:39:21 +0000</pubDate>
  <lastBuildDate>Thu, 15 Oct 2015 11:33:12 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=7089</WebWizForums:feedURL>
   <title>Attaching Safety Chains : Hooks up or down is a &amp;#034;boxers...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7089&amp;PID=67045#67045</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3829" rel="nofollow">JohnBG</a><br /><strong>Subject:</strong> 7089<br /><strong>Posted:</strong> 15 Oct 2015 at 11:33am<br /><br />Hooks up or down is a "boxers or briefs" question that there is no correct answer to, but everyone has a preference or opinion. &nbsp;However, you decide be sure to cross the chains though.]]>
   <pubDate>Thu, 15 Oct 2015 11:33:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7089&amp;PID=67045#67045</guid>
   <title>Attaching Safety Chains : Make sure you cross them before...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7089&amp;PID=67002#67002</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 7089<br /><strong>Posted:</strong> 13 Oct 2015 at 9:19pm<br /><br />Make sure you cross them before attaching them to the TV. &nbsp;Theoretically this will catch the hitch if it comes off of the ball. &nbsp;I've always done it with the ends of the hooks facing down.]]>
   <pubDate>Tue, 13 Oct 2015 21:19:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7089&amp;PID=67002#67002</guid>
   <title>Attaching Safety Chains : Hooks down would give some slight...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7089&amp;PID=66997#66997</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1573" rel="nofollow">CharlieM</a><br /><strong>Subject:</strong> 7089<br /><strong>Posted:</strong> 13 Oct 2015 at 7:47pm<br /><br /><font size="3">Hooks down would give <i>some slight</i> advantage due to gravity if the keeper was broken. Not much though.&nbsp;</font>]]>
   <pubDate>Tue, 13 Oct 2015 19:47:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7089&amp;PID=66997#66997</guid>
   <title>Attaching Safety Chains : Is there a correct method to hooking...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7089&amp;PID=66996#66996</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3407" rel="nofollow">Yessaco</a><br /><strong>Subject:</strong> 7089<br /><strong>Posted:</strong> 13 Oct 2015 at 7:29pm<br /><br />Is there a correct method to hooking the safety chains to the TV? Should the hooks go up or down. I've heard both recommended, but I'd like to know for sure which way is correct. Thanks for the help.]]>
   <pubDate>Tue, 13 Oct 2015 19:29:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7089&amp;PID=66996#66996</guid>
