  <title>R-pod Owners Forum : Keder rail tips</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Keder rail tips</description>
  <pubDate>Thu, 27 Aug 2026 17:48:33 +0000</pubDate>
  <lastBuildDate>Tue, 13 Oct 2015 19:03:50 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=7084</WebWizForums:feedURL>
   <title>Keder rail tips : Our 2009 r-pod had the same problem...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7084&amp;PID=66995#66995</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=428" rel="nofollow">David and Danette</a><br /><strong>Subject:</strong> 7084<br /><strong>Posted:</strong> 13 Oct 2015 at 7:03pm<br /><br />&nbsp; &nbsp;Our 2009 r-pod had the same problem as others did too. You would think Forest River would have made a correction after all these years. Their is obviously a problem.]]>
   <pubDate>Tue, 13 Oct 2015 19:03:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7084&amp;PID=66995#66995</guid>
   <title>Keder rail tips : Initially I dreaded going through...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7084&amp;PID=66990#66990</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3467" rel="nofollow">Grandpa Hiker</a><br /><strong>Subject:</strong> 7084<br /><strong>Posted:</strong> 13 Oct 2015 at 5:30pm<br /><br />Initially I dreaded going through the process of getting the R-Dome setup. Even after spraying the keder rail with silicone, I stood on a step stool &amp; pulled while my wife pushed from the &nbsp;other end. Grinding down the heads of the screws did not help.&nbsp;<div><br></div><div>&nbsp;So next I removed all of the factory screws &amp; carefully stored them in the circular file (trash can). I then used a drill bit with a tapered end &amp; slightly drilled each screw hole in the rail. This made it so that the rail would accept a screw with a counter sunk head. I bought # 8 stainless steel counter sunk screws &amp; installed them. Now the heads of the screws are flush with the surface of the rail. Also, as marwayne suggested, I used a utility knife to taper the end of dome lip.</div><div><br></div><div><span style="line-height: 16.8px;">I am now a very happy camper! Setting up the dome is easy &amp; takes just a few minutes. I can easily push the dome lip all the way to the other end with no effort or assistance.</span></div><div>&nbsp;</div><div><br></div>]]>
   <pubDate>Tue, 13 Oct 2015 17:30:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7084&amp;PID=66990#66990</guid>
   <title>Keder rail tips : Try silicone spray instead of...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7084&amp;PID=66985#66985</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3829" rel="nofollow">JohnBG</a><br /><strong>Subject:</strong> 7084<br /><strong>Posted:</strong> 13 Oct 2015 at 4:13pm<br /><br />Try silicone spray instead of grinding the heads. &nbsp;If you ever have to pull the rail off for some reason, you're hosed. &nbsp;<div><br></div><div>Angling the ends is a cool idea, I need to try that.</div>]]>
   <pubDate>Tue, 13 Oct 2015 16:13:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7084&amp;PID=66985#66985</guid>
   <title>Keder rail tips : Keep filing off the screw heads....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7084&amp;PID=66949#66949</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 7084<br /><strong>Posted:</strong> 12 Oct 2015 at 9:27pm<br /><br />Keep filing off the screw heads. &nbsp;Might go faster if you put a cutting disk on the Dremel instead of a grinding head. &nbsp;Don't use soap, that will get messy. &nbsp;Also bend open the ends of the channel slightly.]]>
   <pubDate>Mon, 12 Oct 2015 21:27:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7084&amp;PID=66949#66949</guid>
   <title>Keder rail tips : Angle the ends a little bit.  ...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7084&amp;PID=66945#66945</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1045" rel="nofollow">marwayne</a><br /><strong>Subject:</strong> 7084<br /><strong>Posted:</strong> 12 Oct 2015 at 8:48pm<br /><br />Angle the ends a little bit.<br /><br /><img src="http://www.rpod-owners.com/uploads/1045/100_1015.JPG" border="0" />  <img src="http://www.rpod-owners.com/uploads/1045/100_1016.JPG" border="0" />]]>
   <pubDate>Mon, 12 Oct 2015 20:48:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7084&amp;PID=66945#66945</guid>
   <title>Keder rail tips :  I use a can of spray silicone....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7084&amp;PID=66944#66944</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1941" rel="nofollow">podrunner</a><br /><strong>Subject:</strong> 7084<br /><strong>Posted:</strong> 12 Oct 2015 at 7:47pm<br /><br />I use a can of spray silicone. &nbsp;Just spray it into the track. &nbsp;Seems to work fine.]]>
   <pubDate>Mon, 12 Oct 2015 19:47:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7084&amp;PID=66944#66944</guid>
   <title>Keder rail tips : Please post any or all tips you...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7084&amp;PID=66943#66943</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4242" rel="nofollow">GLBCamper</a><br /><strong>Subject:</strong> 7084<br /><strong>Posted:</strong> 12 Oct 2015 at 7:34pm<br /><br />Please post any or all tips you have for overcoming those stinking screw heads that stick out on the keder rail and catch the rDome lip when you are pushing it through.<div><br></div><div>I tried using a dremmel with a very small grinding tip, but after two screws and little improvement, I thought there must be a better way.</div><div><br></div><div>Another podder at a campground said his sales guy told him to put dishwashing liquid on it. But he hadn't tried it and I wasn't sure if that meant to put it on the dome lip or rail, or if it would even work.</div><div><br></div><div>Any tips would be appreciated.</div><div><br></div>]]>
   <pubDate>Mon, 12 Oct 2015 19:34:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7084&amp;PID=66943#66943</guid>
