  <title>R-pod Owners Forum : A/C power useage</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Reviews and General Information : A/C power useage</description>
  <pubDate>Sun, 25 Oct 2026 09:41:02 +0000</pubDate>
  <lastBuildDate>Wed, 07 Oct 2015 12:27:31 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=7060</WebWizForums:feedURL>
   <title>A/C power useage : OK, well...based on your input...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7060&amp;PID=66832#66832</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3238" rel="nofollow">Podster</a><br /><strong>Subject:</strong> 7060<br /><strong>Posted:</strong> 07 Oct 2015 at 12:27pm<br /><br />OK, well...based on your input and my readings I contacted Dometic and they suggested the draw was on the high side and suggested I have it checked out. I now have an appointment at my local Camping World Nov 2. Will follow up with the results, that is if I can find this thread afterwards! Thanks again!&nbsp;]]>
   <pubDate>Wed, 07 Oct 2015 12:27:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7060&amp;PID=66832#66832</guid>
   <title>A/C power useage :   Originally posted by David...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7060&amp;PID=66829#66829</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3238" rel="nofollow">Podster</a><br /><strong>Subject:</strong> 7060<br /><strong>Posted:</strong> 07 Oct 2015 at 10:22am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by David and Danette</strong></em><br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Podster</strong></em><br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by David and Danette</strong></em><br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Podster</strong></em><br /><br />Hmm, with the 13.5 btu A/C, I have the hardwired EMSHW30C system with digital read out and I get higher draw ratings that titter between 16/17 amps. Not during start up, but during cooling. I let it run for 30 minutes to stabilize. No other draws...starting amp draw was 0. I am, however, using 50' of RV feed-line.&nbsp;</td></tr></table> Our AC using our surge protector was reading between 15 and 16 amps. I took it to camping world and their amp meter was showing the same. It was still under warranty and Dometic replaced it. The new AC is colder and quieter now and surge protector shows between 12 and 13 amps.</td></tr></table><div><br></div><div>What was the underlying problem. Are you suggesting you took it in b/c of the amp draw and they replaced it for the same?&nbsp;</div></td></tr></table>Yes and I am thankful for the members on this forum who told me something was wrong and that it should be checked out. The technician at camping world said that Dometic allows if I remember about 15 % amperage from normal which I believe is 12.75 amps. Dometic approved replacement under warranty. And their is definitely a noticeable difference in the performance of the AC. The technician also mentioned that sometimes from the factory they can add to much Freon and that will affect the amount of amps. it draws. The exact problem that was causing the high amperage I was never told.</td></tr></table><div><br></div><div><span style="line-height: 16.8px; : rgb251, 251, 253;">I just checked the specs. The amp draw on my unit is 15.4 amps. Add a 50' RV extension cord and 16amps seems reasonable. Plus, mine is really not all that loud so I'm going to stick with the one I have. Thanks for the feedback.</span></div>]]>
   <pubDate>Wed, 07 Oct 2015 10:22:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7060&amp;PID=66829#66829</guid>
   <title>A/C power useage :   Originally posted by Podster  Originally...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7060&amp;PID=66827#66827</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=428" rel="nofollow">David and Danette</a><br /><strong>Subject:</strong> 7060<br /><strong>Posted:</strong> 07 Oct 2015 at 9:56am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Podster</strong></em><br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by David and Danette</strong></em><br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Podster</strong></em><br /><br />Hmm, with the 13.5 btu A/C, I have the hardwired EMSHW30C system with digital read out and I get higher draw ratings that titter between 16/17 amps. Not during start up, but during cooling. I let it run for 30 minutes to stabilize. No other draws...starting amp draw was 0. I am, however, using 50' of RV feed-line.&nbsp;</td></tr></table> Our AC using our surge protector was reading between 15 and 16 amps. I took it to camping world and their amp meter was showing the same. It was still under warranty and Dometic replaced it. The new AC is colder and quieter now and surge protector shows between 12 and 13 amps.</td></tr></table><div><br></div><div>What was the underlying problem. Are you suggesting you took it in b/c of the amp draw and they replaced it for the same?&nbsp;</div></td></tr></table>Yes and I am thankful for the members on this forum who told me something was wrong and that it should be checked out. The technician at camping world said that Dometic allows if I remember about 15 % amperage from normal which I believe is 12.75 amps. Dometic approved replacement under warranty. And their is definitely a noticeable difference in the performance of the AC. The technician also mentioned that sometimes from the factory they can add to much Freon and that will affect the amount of amps. it draws. The exact problem that was causing the high amperage I was never told.]]>
   <pubDate>Wed, 07 Oct 2015 09:56:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7060&amp;PID=66827#66827</guid>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7060&amp;PID=66826#66826</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3238" rel="nofollow">Podster</a><br /><strong>Subject:</strong> 7060<br /><strong>Posted:</strong> 07 Oct 2015 at 9:37am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by David and Danette</strong></em><br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Podster</strong></em><br /><br />Hmm, with the 13.5 btu A/C, I have the hardwired EMSHW30C system with digital read out and I get higher draw ratings that titter between 16/17 amps. Not during start up, but during cooling. I let it run for 30 minutes to stabilize. No other draws...starting amp draw was 0. I am, however, using 50' of RV feed-line.&nbsp;</td></tr></table> Our AC using our surge protector was reading between 15 and 16 amps. I took it to camping world and their amp meter was showing the same. It was still under warranty and Dometic replaced it. The new AC is colder and quieter now and surge protector shows between 12 and 13 amps.</td></tr></table><div><br></div><div>What was the underlying problem. Are you suggesting you took it in b/c of the amp draw and they replaced it for the same?&nbsp;</div>]]>
   <pubDate>Wed, 07 Oct 2015 09:37:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7060&amp;PID=66826#66826</guid>
   <title>A/C power useage :    Originally posted by PodsterHmm,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7060&amp;PID=66825#66825</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=428" rel="nofollow">David and Danette</a><br /><strong>Subject:</strong> 7060<br /><strong>Posted:</strong> 07 Oct 2015 at 8:54am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Podster</strong></em><br /><br />Hmm, with the 13.5 btu A/C, I have the hardwired EMSHW30C system with digital read out and I get higher draw ratings that titter between 16/17 amps. Not during start up, but during cooling. I let it run for 30 minutes to stabilize. No other draws...starting amp draw was 0. I am, however, using 50' of RV feed-line.&nbsp;</td></tr></table> Our AC using our surge protector was reading between 15 and 16 amps. I took it to camping world and their amp meter was showing the same. It was still under warranty and Dometic replaced it. The new AC is colder and quieter now and surge protector shows between 12 and 13 amps.]]>
   <pubDate>Wed, 07 Oct 2015 08:54:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7060&amp;PID=66825#66825</guid>
   <title>A/C power useage :   Originally posted by Capt...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7060&amp;PID=66804#66804</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 7060<br /><strong>Posted:</strong> 06 Oct 2015 at 5:03pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Capt Kidd</strong></em><br /><br />Where do you get a hard start and how does it work?</td></tr></table><br><br>I got mine on Amazon, but any decent appliance parts store will have one. It is a second capacitor that piggy backs on the factory one, it gives an extra boost when starting the compressor..<br><br><a href="http://www.amaz&#111;n.com/SUPCO-SPP6-Start-Relay-Capacitor/dp/B0002YTLFE/ref=sr_1_2?ie=UTF8&amp;qid=1444165327&amp;sr=8-2&amp;keywords=hard+start+capacitor" target="_blank">Capacitor.</a><br>]]>
   <pubDate>Tue, 06 Oct 2015 17:03:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7060&amp;PID=66804#66804</guid>
   <title>A/C power useage : Hmm, with the 13.5 btu A/C, I...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7060&amp;PID=66775#66775</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3238" rel="nofollow">Podster</a><br /><strong>Subject:</strong> 7060<br /><strong>Posted:</strong> 05 Oct 2015 at 9:25pm<br /><br />Hmm, with the 13.5 btu A/C, I have the hardwired EMSHW30C system with digital read out and I get higher draw ratings that titter between 16/17 amps. Not during start up, but during cooling. I let it run for 30 minutes to stabilize. No other draws...starting amp draw was 0. I am, however, using 50' of RV feed-line.&nbsp;]]>
   <pubDate>Mon, 05 Oct 2015 21:25:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7060&amp;PID=66775#66775</guid>
   <title>A/C power useage : Where do you get a hard start...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7060&amp;PID=66766#66766</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4498" rel="nofollow">Capt Kidd</a><br /><strong>Subject:</strong> 7060<br /><strong>Posted:</strong> 05 Oct 2015 at 4:43pm<br /><br />Where do you get a hard start and how does it work?]]>
   <pubDate>Mon, 05 Oct 2015 16:43:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7060&amp;PID=66766#66766</guid>
   <title>A/C power useage : +2...very mixed. Mine will start...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7060&amp;PID=66762#66762</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 7060<br /><strong>Posted:</strong> 05 Oct 2015 at 2:57pm<br /><br />+2...<br><br>very mixed. Mine will start and run on a buddies Honda 2000i.. his, same brand/model a/c.. won't. <br><br>I do have a hard start cap.<br>]]>
   <pubDate>Mon, 05 Oct 2015 14:57:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7060&amp;PID=66762#66762</guid>
   <title>A/C power useage : +1 </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7060&amp;PID=66754#66754</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 7060<br /><strong>Posted:</strong> 05 Oct 2015 at 2:48pm<br /><br />+1]]>
   <pubDate>Mon, 05 Oct 2015 14:48:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7060&amp;PID=66754#66754</guid>
   <title>A/C power useage : The standard 13.5k BTU A/C, when...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7060&amp;PID=66746#66746</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1573" rel="nofollow">CharlieM</a><br /><strong>Subject:</strong> 7060<br /><strong>Posted:</strong> 05 Oct 2015 at 11:18am<br /><br /><font size="3">The standard 13.5k BTU A/C, when running, will draw ~13A. The problem is the starting current when the compressor tries to start.&nbsp; Success with a single Honda 2000 varies depending on altitude and outside temperature. Altitude reduces the performance of any internal combustion engine and high temperatures increase the starting current of the compressor. Adding a hard start capacitor to the A/C helps in some cases, but user experience with the single 2000W genny is mixed.</font>]]>
   <pubDate>Mon, 05 Oct 2015 11:18:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7060&amp;PID=66746#66746</guid>
   <title>A/C power useage : How many watts and/or amps does...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=7060&amp;PID=66742#66742</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4498" rel="nofollow">Capt Kidd</a><br /><strong>Subject:</strong> 7060<br /><strong>Posted:</strong> 05 Oct 2015 at 11:05am<br /><br />How many watts and/or amps does the A/C on a 2016 r-179 draw?  I'm wondering if I can run it on just one Honda 2000.  I'm thinking I might have to turn the converter/charger off to do this.]]>
   <pubDate>Mon, 05 Oct 2015 11:05:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=7060&amp;PID=66742#66742</guid>
