  <title>R-pod Owners Forum : Operation of TV/CD Jensen AWM968</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Operation of TV/CD Jensen AWM968</description>
  <pubDate>Sun, 04 Oct 2026 02:18:48 +0000</pubDate>
  <lastBuildDate>Fri, 21 Aug 2015 23:00:25 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=6841</WebWizForums:feedURL>
   <title>Operation of TV/CD Jensen AWM968 : thanks for the info, discovered...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6841&amp;PID=65052#65052</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4505" rel="nofollow">landshark</a><br /><strong>Subject:</strong> 6841<br /><strong>Posted:</strong> 21 Aug 2015 at 11:00pm<br /><br />thanks for the info, discovered I have to hold the button down for a few seconds on the control panel to get it into CD &nbsp;mode. &nbsp;As for the wiring of the 12 v plug that will be on our todo list, have a few inverters laying around. &nbsp;cheers.&nbsp;<div>Bob</div>]]>
   <pubDate>Fri, 21 Aug 2015 23:00:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6841&amp;PID=65052#65052</guid>
   <title>Operation of TV/CD Jensen AWM968 : Your 1st mod will have to be adding...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6841&amp;PID=65000#65000</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3978" rel="nofollow">jstrenn</a><br /><strong>Subject:</strong> 6841<br /><strong>Posted:</strong> 20 Aug 2015 at 6:01pm<br /><br />Your 1st mod will have to be adding a 12V socket. &nbsp;I am going to do that before our next trip. &nbsp;Then you will just have to buy a 120V power inverter. &nbsp;I plan on just buying a Harbor Freight 200 watt one for about $30 or so.<div><br></div><div>Not sure about the CD, I only play DVD's in mine not sure if it plays CD's or not. &nbsp;You may want to make sure it is capable of &nbsp;playing CD's and if so the CD is formatted correctly for the player.</div>]]>
   <pubDate>Thu, 20 Aug 2015 18:01:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6841&amp;PID=65000#65000</guid>
   <title>Operation of TV/CD Jensen AWM968 : Welcome to the group! Congrats...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6841&amp;PID=64999#64999</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1100" rel="nofollow">Leo B</a><br /><strong>Subject:</strong> 6841<br /><strong>Posted:</strong> 20 Aug 2015 at 5:58pm<br /><br />Welcome to the group! Congrats on your pod!]]>
   <pubDate>Thu, 20 Aug 2015 17:58:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6841&amp;PID=64999#64999</guid>
   <title>Operation of TV/CD Jensen AWM968 : We just got our 2015 Pod 171 Hood...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6841&amp;PID=64998#64998</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4505" rel="nofollow">landshark</a><br /><strong>Subject:</strong> 6841<br /><strong>Posted:</strong> 20 Aug 2015 at 5:41pm<br /><br />We just got our 2015 Pod 171 Hood River Edition last week. Had to travel long way back home so did not go over some of the finer points with the dealer, so hopefully this forum can help us.<div><br></div><div>1. &nbsp;How do you get the TV TO WORK when dry camping?</div><div>2. &nbsp;We can not get the CD to work, error message no disc' I removed the unit to ensure the factory screw had been removed, it had, I hit the reset button, still nothing. &nbsp;Radio works fine.</div><div><br></div><div><br></div><div>I dropped into another Forest River Dealer on the way home, and got little help, they said TV likely would need an inverter to run off the battery. &nbsp;There are no "cigarette" plug in's in the Pod. &nbsp;What is the most popular way to power the TV? &nbsp;Unfortunetly we had not tested the Jesen Unit when connected to 110 shore power.</div><div><br></div><div>Thanks for any help, we moved up from being owners of a Teardrop trailer to the 171. &nbsp;So far we like it and are learning lots of tips from this forum.</div><div><br></div><div>Bob and Leah</div><div><br></div><div>Prince Rupert BC</div>]]>
   <pubDate>Thu, 20 Aug 2015 17:41:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6841&amp;PID=64998#64998</guid>
