  <title>R-pod Owners Forum : Clean up isle two!</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Wish List : Clean up isle two!</description>
  <pubDate>Fri, 23 Oct 2026 19:30:03 +0000</pubDate>
  <lastBuildDate>Mon, 10 Aug 2015 20:59:23 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=6776</WebWizForums:feedURL>
   <title>Clean up isle two! : I will say that RV Nation is working...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6776&amp;PID=64556#64556</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4365" rel="nofollow">Pilot</a><br /><strong>Subject:</strong> 6776<br /><strong>Posted:</strong> 10 Aug 2015 at 8:59pm<br /><br />I will say that RV Nation is working with me.]]>
   <pubDate>Mon, 10 Aug 2015 20:59:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6776&amp;PID=64556#64556</guid>
   <title>Clean up isle two! : Unfortunately that is &amp;#034;normal&amp;#034;...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6776&amp;PID=64531#64531</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 6776<br /><strong>Posted:</strong> 10 Aug 2015 at 3:25pm<br /><br />Unfortunately that is "normal" for the pods post-delivery.]]>
   <pubDate>Mon, 10 Aug 2015 15:25:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6776&amp;PID=64531#64531</guid>
   <title>Clean up isle two! : Kind of tee&amp;#039;s me off too....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6776&amp;PID=64519#64519</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4277" rel="nofollow">hammockmadness</a><br /><strong>Subject:</strong> 6776<br /><strong>Posted:</strong> 10 Aug 2015 at 2:06pm<br /><br />Kind of tee's me off too. &nbsp;It would just add a little more quality and workmanship.]]>
   <pubDate>Mon, 10 Aug 2015 14:06:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6776&amp;PID=64519#64519</guid>
   <title>Clean up isle two! : Had a little problem with the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6776&amp;PID=64498#64498</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4365" rel="nofollow">Pilot</a><br /><strong>Subject:</strong> 6776<br /><strong>Posted:</strong> 10 Aug 2015 at 10:49am<br /><br />Had a little problem with the flex drain line from kitchen sink coming loose from drain pipe to the gray water tank this weekend.<br>It happened when I closed the bumpout. The hose was to short and it pulled right off pipe.<br>I had to pull a couple panels to get into trouble shooting.<br>Forest River, don't you think you could clean up after yourselves? Just because it's in a hidden area doesn't cut it. It's a sign of professionalism. There were screws, wiring debris, cutout hole pieces,and a lot of sawdust.<br>It would take less than 5 minutes to clean these areas before installing the last panels.<br>]]>
   <pubDate>Mon, 10 Aug 2015 10:49:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6776&amp;PID=64498#64498</guid>
