  <title>R-pod Owners Forum : Water heater problems.</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Water heater problems.</description>
  <pubDate>Thu, 26 Nov 2026 16:18:03 +0000</pubDate>
  <lastBuildDate>Wed, 22 Jul 2015 21:26:56 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=6664</WebWizForums:feedURL>
   <title>Water heater problems. : A tip on controlling the electric...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6664&amp;PID=63771#63771</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 6664<br /><strong>Posted:</strong> 22 Jul 2015 at 9:26pm<br /><br />A tip on controlling the electric element, it is easier to leave the outside switch on and use the circuit breaker on the converter to turn it on and off. &nbsp;]]>
   <pubDate>Wed, 22 Jul 2015 21:26:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6664&amp;PID=63771#63771</guid>
   <title>Water heater problems. : Thanks everyone, because of your...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6664&amp;PID=63652#63652</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4123" rel="nofollow">Derek</a><br /><strong>Subject:</strong> 6664<br /><strong>Posted:</strong> 20 Jul 2015 at 3:48pm<br /><br />Thanks everyone, because of your help we now have everything working.<div>Derek and Alison.</div>]]>
   <pubDate>Mon, 20 Jul 2015 15:48:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6664&amp;PID=63652#63652</guid>
   <title>Water heater problems. : I do the same. Go habit! </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6664&amp;PID=63640#63640</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1100" rel="nofollow">Leo B</a><br /><strong>Subject:</strong> 6664<br /><strong>Posted:</strong> 20 Jul 2015 at 8:26am<br /><br />I do the same. Go habit!]]>
   <pubDate>Mon, 20 Jul 2015 08:26:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6664&amp;PID=63640#63640</guid>
   <title>Water heater problems. :   Originally posted by hammockmadnessThrough...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6664&amp;PID=63629#63629</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 6664<br /><strong>Posted:</strong> 19 Jul 2015 at 5:53pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by hammockmadness</strong></em><br /><br />Through the years, I've gotten into the habit of shutting off the electrical switch for the hot water heater everytime I leave a campsite. &nbsp;Is this necessary since the only way to drain the water heater is to pull the anode?</td></tr></table><br><br>I do the same. I mostly do it because at home we have full hookups.. but I am not going to need an emergency shower, so don't want to heat water between trips needlessly..<br>]]>
   <pubDate>Sun, 19 Jul 2015 17:53:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6664&amp;PID=63629#63629</guid>
   <title>Water heater problems. : Through the years, I&amp;#039;ve gotten...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6664&amp;PID=63623#63623</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4277" rel="nofollow">hammockmadness</a><br /><strong>Subject:</strong> 6664<br /><strong>Posted:</strong> 19 Jul 2015 at 4:19pm<br /><br />Through the years, I've gotten into the habit of shutting off the electrical switch for the hot water heater everytime I leave a campsite. &nbsp;Is this necessary since the only way to drain the water heater is to pull the anode?]]>
   <pubDate>Sun, 19 Jul 2015 16:19:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6664&amp;PID=63623#63623</guid>
   <title>Water heater problems. : To run on propane, open propane...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6664&amp;PID=63616#63616</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 6664<br /><strong>Posted:</strong> 19 Jul 2015 at 3:19pm<br /><br />To run on propane, open propane bottle, go inside the pod, turn on the water heater switch. If you get a DSI fault light, turn off the switch wait 10 seconds, turn it back on. It may need to purge some air in the lines.<br><br>To run on electric, hookup to shore power, go to the outside water heater compartment, hidden, down in the lower left corner is a switch, turn it on.<br>]]>
   <pubDate>Sun, 19 Jul 2015 15:19:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6664&amp;PID=63616#63616</guid>
   <title>Water heater problems. : Hi Charlie,thanks for your help,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6664&amp;PID=63614#63614</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4123" rel="nofollow">Derek</a><br /><strong>Subject:</strong> 6664<br /><strong>Posted:</strong> 19 Jul 2015 at 3:06pm<br /><br />Hi Charlie,<div>thanks for your help, so how do I run the water heater on propane ? do I just turn on the propane bottle? How do I choose the water heater to be run on electric? Thanks Derek.</div>]]>
   <pubDate>Sun, 19 Jul 2015 15:06:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6664&amp;PID=63614#63614</guid>
   <title>Water heater problems. : OK, you had hot water, and then...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6664&amp;PID=63613#63613</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 6664<br /><strong>Posted:</strong> 19 Jul 2015 at 3:02pm<br /><br />OK, you had hot water, and then didn't? Or you had some hot water, then didn't, then did.. etc?<br><br>Lets address that first. If you had hot water at all.. the water heater has water in it. To check, trip the manual pressure relief valve near the top of the WH, outside in the compartment. <br><br>If you had fluctuating water temps, or some hot water, then none right away. then next time, same thing.. (and since it's a first time out) your winterization valves are set wrong. Lift the mattress and open the panel above the WH. You will need to remove some screws to do this. On the back of the water heater, there is plumbing, going and coming from the WH. There are 3 valves on that plumbing. The top and bottom ones need to be open, and the center one closed.<br><br><img src="http://i174.photobucket.com/albums/w88/maypo59/R-Pod/bypass%20valves_zps8ef2rfes.jpg" border="0" /><br>]]>
   <pubDate>Sun, 19 Jul 2015 15:02:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6664&amp;PID=63613#63613</guid>
   <title>Water heater problems. :   Derek,There should be three...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6664&amp;PID=63608#63608</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1573" rel="nofollow">CharlieM</a><br /><strong>Subject:</strong> 6664<br /><strong>Posted:</strong> 19 Jul 2015 at 1:59pm<br /><br /><font size="3">Derek,<br><br>There should be three valves near the water heater. For normal operation the one crosswise, connecting the inlet and outlet, should be off (handle perpendicular to pipe). The other two should be on (handle aligned with pipe). None of these should have any effect on the cold water to any cold faucets.<br><br>The way to fill the water heater is, with the valves set as above, open a hot faucet and run water until it stops sputtering, indicating all the air is out and the tank is full.&nbsp; The electric heater element is very fragile and will burn out with even short operation without water in the tank. If you ran the electric side of the water heater without a full tank you probably burned the element out. Try it on propane. The heating element is easily replaced with a part from Lowes or HD. <br><br>The pump should not be damaged. Can't say on the fridge except you have to press <i>and hold </i>the button to make it turn off. <br><br>As for dealer prep, you should not be surprised. Normal behavior.<br></font>]]>
   <pubDate>Sun, 19 Jul 2015 13:59:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6664&amp;PID=63608#63608</guid>
   <title>Water heater problems. : We just got back from our first...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6664&amp;PID=63602#63602</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4123" rel="nofollow">Derek</a><br /><strong>Subject:</strong> 6664<br /><strong>Posted:</strong> 19 Jul 2015 at 12:31pm<br /><br />We just got back from our first trip in our 2015 179, all in all had a great one week holiday in the eastern Kootenays, our 2002 Grand Cherokee towed well and we didn't push it too hard on the steeper climbs. Didn't experience any sway even in some strong cross winds due I think to the Blue ox wdh. &nbsp;Problems .. &nbsp; &nbsp;couldn't get the water to flow properly, we followed all the instructions for the initial start up with no joy. Went the weekend without water and then phoned Rangeland rv Balzac on Monday, they informed us that they had probably left one of the valves shut under the bed, so I took the mattress out and unscrewed the wood panels to reveal that the one valve was indeed closed. Opened it up and the water flowed. We are now experiencing problems with the water heater, it worked on and off but now seems to have packed up altogether. The instructions say to ensure that the &nbsp;hot water tank is full before turning it on, how do you do that? &nbsp; I hope that my trying to start the water pump with the valve closed hasn't damaged it. I hope also that the hot water heater hasn't been damaged. &nbsp;I will be phoning the dealer tomorrow. We had a free membership with Coachnet but found that they were only available weekdays and Rangeland weren't any help until Monday. &nbsp;When we got home we couldn't get the fridge to switch off, I eventually took the control panel out and it then switched off. &nbsp;Just a few problems to mar an otherwise great first trip but never the less we were told that the pod was ready to go camping with and the problems did waste some of our time. Unfortunately we didn't have a computer with us to contact you guys while we were away, would appreciate any assistance or ideas. Derek and Alison.<div><br></div><div><br></div>]]>
   <pubDate>Sun, 19 Jul 2015 12:31:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6664&amp;PID=63602#63602</guid>
