  <title>R-pod Owners Forum : r-pod TV : Selecting between CATV and Air Ant</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Warranty, Service and Recall Bulletins : r-pod TV : Selecting between CATV and Air Ant</description>
  <pubDate>Sat, 07 Nov 2026 05:41:49 +0000</pubDate>
  <lastBuildDate>Tue, 31 Mar 2009 12:21:06 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=66</WebWizForums:feedURL>
   <title>r-pod TV : Selecting between CATV and Air Ant : Some folks have asked how the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=66&amp;PID=303#303</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1" rel="nofollow">rpodadmin</a><br /><strong>Subject:</strong> 66<br /><strong>Posted:</strong> 31 Mar 2009 at 12:21pm<br /><br /><P>Some folks have asked how the LCD TV knows which input source to use, the park's cable tv or the over the air HD antenna. The answer is in the TV menu - you can select which source to autoscan - CATV or AIR ... it will scan, load the channels and use that input source accordingly.</P><DIV><img src="http://www.rpodnati&#111;n.com/uploads/1/DDL_4965.jpg" height="400" width="600" border="0" /></DIV>]]>
   <pubDate>Tue, 31 Mar 2009 12:21:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=66&amp;PID=303#303</guid>
