  <title>R-pod Owners Forum : Tires and wheels</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Tires and wheels</description>
  <pubDate>Thu, 29 Oct 2026 12:40:36 +0000</pubDate>
  <lastBuildDate>Mon, 29 Jun 2015 09:29:39 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=6519</WebWizForums:feedURL>
   <title>Tires and wheels : Something to remember, as you...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6519&amp;PID=62547#62547</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1346" rel="nofollow">Old Dingo&Mrs.Dingo</a><br /><strong>Subject:</strong> 6519<br /><strong>Posted:</strong> 29 Jun 2015 at 9:29am<br /><br /><font size="4">Something to remember, as you increase the outside diameter of your tires you decrease the mechanical advantage of your brakes. &nbsp;This may require increasing the "gain" on your brake controller to maintain your present stopping distances. &nbsp;Also, as you increase the tire size, you increase the "unspring" weight of your 'pod, affecting both ride (and wheel control) and further increasing braking distances. &nbsp;The effect of either by itself may be small, but add both and it could be significant.&nbsp;</font>]]>
   <pubDate>Mon, 29 Jun 2015 09:29:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6519&amp;PID=62547#62547</guid>
   <title>Tires and wheels : No. I only know of a few podders...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6519&amp;PID=62539#62539</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 6519<br /><strong>Posted:</strong> 29 Jun 2015 at 8:09am<br /><br />No. I only know of a few podders who have switched to larger wheels and tires than those on the pod when delivered. West coast pods, "HRE", come with LT 15's standard.. just because.<br><br>There is a better selection of trailer tires available at the 15" size, but lots at 14" also. The biggest issue would be if you have decided you need "D" rated tires, only 2 or 3 in 14".. But "C"'s get it done just fine. Lot's of different D rated tires at 15".<br>]]>
   <pubDate>Mon, 29 Jun 2015 08:09:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6519&amp;PID=62539#62539</guid>
   <title>Tires and wheels : I would like to know if it is...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6519&amp;PID=62509#62509</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3871" rel="nofollow">Band Leader</a><br /><strong>Subject:</strong> 6519<br /><strong>Posted:</strong> 28 Jun 2015 at 8:36pm<br /><br />I would like to know if it is important to switch wheels and tires to 15 inch. I've seen several indications that this done.]]>
   <pubDate>Sun, 28 Jun 2015 20:36:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6519&amp;PID=62509#62509</guid>
