  <title>R-pod Owners Forum : Hello Newbie in the house</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Introduce Yourself : Hello Newbie in the house</description>
  <pubDate>Fri, 25 Sep 2026 00:50:09 +0000</pubDate>
  <lastBuildDate>Sat, 04 Jul 2015 22:54:58 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=6504</WebWizForums:feedURL>
   <title>Hello Newbie in the house : dsnbm - welcome, it has been a...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6504&amp;PID=62853#62853</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 6504<br /><strong>Posted:</strong> 04 Jul 2015 at 10:54pm<br /><br />dsnbm - welcome, it has been a little while since you were on here, if you are still having a problem let us know.]]>
   <pubDate>Sat, 04 Jul 2015 22:54:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6504&amp;PID=62853#62853</guid>
   <title>Hello Newbie in the house : Agree. Better safe then sorry....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6504&amp;PID=62815#62815</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1100" rel="nofollow">Leo B</a><br /><strong>Subject:</strong> 6504<br /><strong>Posted:</strong> 04 Jul 2015 at 7:36am<br /><br />Agree. Better safe then sorry. A little rink out of the tank could save a lot!]]>
   <pubDate>Sat, 04 Jul 2015 07:36:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6504&amp;PID=62815#62815</guid>
   <title>Hello Newbie in the house :   Originally posted by alanebellthanks!...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6504&amp;PID=62431#62431</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3006" rel="nofollow">Marx</a><br /><strong>Subject:</strong> 6504<br /><strong>Posted:</strong> 27 Jun 2015 at 6:49pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by alanebell</strong></em><br /><br />thanks!  I made it from Bakersfield without incident.  Not to much difficulty.  Even managed to back it into the driveway so I feel pretty good.<br><br>the van pulled up the Grapevine (very steep pass) without an trouble.  <br><br>Question about the water tank.  If I hook up to city water is that bypassing my water tank?  Or is it going to fill the tank at the same time as giving me water while hooked up?<br><br>Not sure if I need to manually fill via the hole above the city hook up?<br><br>Thanks<br>Alan</td></tr></table><br><br>Welcome aboard!&nbsp; The city water line is a direct connection and will not go into the tank.&nbsp; You will have to fill the tank if you want to pump from it.&nbsp; The tank is more for being off the grid.&nbsp; I would suggest a clean out of the tank prior to using for your purposes.&nbsp; I just don't trust the dealerships completely.&nbsp; <br>]]>
   <pubDate>Sat, 27 Jun 2015 18:49:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6504&amp;PID=62431#62431</guid>
   <title>Hello Newbie in the house : thanks!  I made it from Bakersfield...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6504&amp;PID=62419#62419</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4070" rel="nofollow">alanebell</a><br /><strong>Subject:</strong> 6504<br /><strong>Posted:</strong> 27 Jun 2015 at 5:04pm<br /><br />thanks!  I made it from Bakersfield without incident.  Not to much difficulty.  Even managed to back it into the driveway so I feel pretty good.<br /><br />the van pulled up the Grapevine (very steep pass) without an trouble.  <br /><br />Question about the water tank.  If I hook up to city water is that bypassing my water tank?  Or is it going to fill the tank at the same time as giving me water while hooked up?<br /><br />Not sure if I need to manually fill via the hole above the city hook up?<br /><br />Thanks<br />Alan]]>
   <pubDate>Sat, 27 Jun 2015 17:04:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6504&amp;PID=62419#62419</guid>
   <title>Hello Newbie in the house : Welcome to the group!! Congrats...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6504&amp;PID=62415#62415</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1100" rel="nofollow">Leo B</a><br /><strong>Subject:</strong> 6504<br /><strong>Posted:</strong> 27 Jun 2015 at 2:29pm<br /><br />Welcome to the group!! Congrats on your pods!!!]]>
   <pubDate>Sat, 27 Jun 2015 14:29:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6504&amp;PID=62415#62415</guid>
   <title>Hello Newbie in the house : Welcome, Alan. I hope you&amp;#039;ll...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6504&amp;PID=62414#62414</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4076" rel="nofollow">DebbieHM</a><br /><strong>Subject:</strong> 6504<br /><strong>Posted:</strong> 27 Jun 2015 at 12:15pm<br /><br />Welcome, Alan. &nbsp;I hope you'll enjoy your podding experience as much as we do! &nbsp;<img src="https://www.rpod-owners.com/smileys/smiley4.gif" border="0" alt="Big smile" title="Big smile" />&nbsp; I find it very easy to pull with the tanks empty. &nbsp;]]>
   <pubDate>Sat, 27 Jun 2015 12:15:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6504&amp;PID=62414#62414</guid>
   <title>Hello Newbie in the house : Congratulations, We are also new...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6504&amp;PID=62410#62410</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4213" rel="nofollow">dsnbm</a><br /><strong>Subject:</strong> 6504<br /><strong>Posted:</strong> 27 Jun 2015 at 10:08am<br /><br />Congratulations, We are also new R-pod owners.  Brand new R-pod, everything works when hooked up to the car but when we just plug into electricity at home nothing works.  Do we need the battery in place and hooked up for the electricity to work?<br />]]>
   <pubDate>Sat, 27 Jun 2015 10:08:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6504&amp;PID=62410#62410</guid>
   <title>Hello Newbie in the house : Hello,  Going to pick up my used...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=6504&amp;PID=62409#62409</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4070" rel="nofollow">alanebell</a><br /><strong>Subject:</strong> 6504<br /><strong>Posted:</strong> 27 Jun 2015 at 9:34am<br /><br />Hello,<br /><br />Going to pick up my used 2013 172 today.  Never pulled a trailer before.  After setting up the Honda Odessy with a new hitch and Transmission cooler and a brake controller I think I am ready.<br /><br />Feeling a bit nervous but I suppose that makes sense after all.<br /><br />So far I have only been lurking on this forum and it's been a big help.<br /><br />Thanks<br /><br />Alan E Bell<br />]]>
   <pubDate>Sat, 27 Jun 2015 09:34:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=6504&amp;PID=62409#62409</guid>
